Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
06-01-2014, 03:49 AM | #29 | |
Drives: 2013 FRS
http://web.stagram.com/p/707997224129277089_31758082 here she is on the dyno a while back with a 9psi pulley before i went with the 11psi pulley on the vortech http://web.stagram.com/p/682623034882797191_31758082 hope this helps. |
The Following User Says Thank You to ft86me For This Useful Post: | Tromatic (06-01-2014) |
06-01-2014, 08:55 AM | #30 |
Drives: 2006 Toyota Prado 4.0V6
06-01-2014, 09:27 AM | #31 | |
It will? [ame="https://www.youtube.com/watch?v=zkJ9MaEdWcY"]2012 STi sedan with EL headers and Greddy Evo 3 exhaust - YouTube[/ame] [ame="https://www.youtube.com/watch?v=0CwgnWmtwgI"]2011 sti stock exhaust manifold vs perrin equal length manifold - YouTube[/ame] [ame="https://www.youtube.com/watch?v=sGdcre_3Mx4"]2012 Subaru Wrx Un Equal and Equal Length Headers before and after - YouTube[/ame]
06-01-2014, 08:55 PM | #32 | |
Drives: 2013 AT Firestorm FRS
Think about it, it's not called the "UEL rumble".. it's the BOXER rumble |
06-01-2014, 09:21 PM | #33 | |
Well, my car has zero rumble with EL. If you closed your eyes it sounds like any inline 4.
I'm pretty sure it's more about the crank timing than the cylinder layout. The rumble comes from the unequal length header. With the equal length header, the exhaust note is: [ame="https://www.youtube.com/watch?v=ryXsn7fLV-M&feature=kp"]7-UP Commercial featuring Geoffrey Holder - YouTube[/ame] Quote:
06-01-2014, 09:23 PM | #34 | |
If my car didn't sound the way it does with my exhaust mods, it would've stayed stock and quiet. |
06-01-2014, 09:32 PM | #35 | |
06-01-2014, 09:42 PM | #36 | |
I was referring to the exhaust note or frequency. Our cars still sound very unique I think with either type of header.
06-01-2014, 10:04 PM | #37 |
I agree with that. I wouldn't recommend an EL header for our cars, sounds out of place to me. But exhaust is very opinionated. I think UEL is the way to go for N/A
06-02-2014, 04:30 AM | #38 | |
Boxer engines do have their own characteristic sounds too but it's the exhaust and exhaust piping that does the music. |
06-02-2014, 05:06 AM | #39 |
Drives: 2004 VW Touareg 2013 Whiteout FR-S
This. It's the order in which the cylinders fire in a flat engine: LLRR (1,3,2,4). UEL runners make the "pulse" more pronounced. However, there's a video of a s2k on Youtube running custom fabricated UEL headers that has a similar pulse, albeit a lot higher pitched.
06-02-2014, 05:08 AM | #40 |
06-02-2014, 09:58 AM | #41 | |
Drives: 2008 Civic Si
06-02-2014, 10:34 AM | #42 | |
H6 swapped impreza (still a boxer) [ame="https://www.youtube.com/watch?v=wqnuj58lFQI"]EFI Logics Track Car - YouTube[/ame] Older 911 (yes, those are boxer engines too) [ame="https://www.youtube.com/watch?v=WMXH6I9ray0"]'89 Porsche 911 Carrera dyno run - twin exit exhaust - YouTube[/ame] New 911 (yep, still boxers) [ame="https://www.youtube.com/watch?v=20xhYn1QnCA"]Porsche 991 Carrera S Dyno Test and Tune Exhaust Bypass Pipes - YouTube[/ame] Yet another 911 (again, still a boxer) [ame="https://www.youtube.com/watch?v=-UQ-Psx0ZgU"]Porsche 993 RSR 2 61 litre twin turbo dyno - YouTube[/ame] There are two main reasons the (non FRS/BRZ) Subaru 4 cylinder boxers sound so different. 1) The stock manifolds are VERY UEL and merge the ports right at the head instead of having individual runners for each cylinder. 2) They have different firing orders than most engines, and fire both left cylinders then both right cylinders. The firing order combined with the manifold design is why they rumble so much stock. If you swap out to an EL manifold you'll definitely get rid of the rumble.
Similar Threads | ||||
stupid question about brz | andrewmay9 | BRZ First-Gen (2012+) -- General Topics | 55 | 05-17-2014 03:10 AM |
Really stupid question regarding oil | hansthegerman | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 9 | 10-08-2013 07:56 AM |
Potentially headlight stupid question | BentAnat | Cosmetic Modification (Interior/Exterior/Lighting) | 7 | 08-21-2013 02:32 AM |
Stupid Question on Controls | Naughty | AFRICA | 32 | 04-19-2013 04:51 AM |
Stupid Question | Canibuz | Engine, Exhaust, Transmission | 24 | 03-05-2012 09:50 AM |
