Old 03-26-2018, 11:20 AM   #29
SCQTT
ZWEI KOLBEN
SCQTT's Avatar
Drives: 2017 86 Halo 6MT
Start noticing what the most visible and numerous cars are on the road. 14-16 Corollas are insane. Small, super bright and a little blue, they are crazy distinctive. I got flashed by oncoming traffic hourly when on the road. Once you start seeing them you will really notice. When driving they have a really strange pattern too. very sharp horizontal cutoff with zero light bleed. Super bright and daylight like below cutoff, total darkness above the cutoff. In certain situations they are the best headlights I have ever seen, in some cases they are the worst headlights I have ever seen. In areas with steep hills they have you driving into total darkness at times.
SCQTT is offline   Reply With Quote
The Following User Says Thank You to SCQTT For This Useful Post:
Ultramaroon (03-26-2018)
Old 03-26-2018, 07:58 PM   #30
p1l0t
p1l0t's Avatar
My 16 BRZ adjusts from in the cockpit... But I balled out on the Hyperblue which is above limited. It's about as loaded as you can get an 86 I think. Only thing I'm missing is the OEM Subwoofer...
#datThreadTitleDoe
Is my ECU flashed? Italian Software Tuning 13 07-08-2016 12:16 AM
Incoming... MisterSheep Off-Topic Lounge [WARNING: NO POLITICS] 19 04-02-2016 12:33 AM
Just flashed OFT Stage 2 UEL Luftwaffel Software Tuning 14 11-30-2015 09:33 PM
Just flashed 2015 FRS with OFT Flat_4_Life Software Tuning 4 03-23-2015 09:22 PM
Flashed ECU Djen Software Tuning 5 08-13-2013 09:00 AM
