11-03-2014, 12:28 PM | #393 |
Drives: 2013 Scion FR-S Hot Lava OFT Tuned
Shiv@Openflash:
Did you remove the 2.06 Off-The-Shelf from your Open Flash Tablet site? I am using them, and wanted to recommend to a friend but all I'm seeing is the V1.59 Maps. Is something wrong with them? Or just temporary? Others: When I was driving yesterday testing out the map my IAM was 1.0 for most of the low speed drive but once I accelerated in a higher gear at low RPMS and it dropped to .88, and settled at .82, is that bad? Will it go back up if I keep driving? ECU probably has about 1-2 hours of driving on it, mostly under 50 mph, until this last run where it dropped. Thanks! Akshay |
11-03-2014, 12:57 PM | #394 | |
Drives: 2013 FRS
Hi,
The v2.06 maps are definitely available for download: http://openflashtablet.com/Automotiv...ads/index.html Also, it's totally fine for the IAM to move around from time to time. I would only be concerned if it routinely dropped below .60. To me, a IAM that stays stuck at 1.00 indicates a map that may be too conservative, leaving good power on the table. Quote:
11-03-2014, 01:43 PM | #395 | |
I see them there now, at the bottom! Awesome, I will certainly pass the news along to my friend as well. Thank you for the quick reply, sir.
I'm also remembering back and the gas in my car might be from the boonies from when I took a trip, so hopefully filling it up with some better stuff soon... Quote:
11-03-2014, 04:51 PM | #396 |
Drives: 2013 Asphalt FRS
@Shiv@Openflash,
I have a question about my OFT. My CAL id show as A01C however when i plugged my OFT into my car it show B01C under the ECU info. I have the file loaded as A01C tune onto the OFT from OFM. Its wasn't like this before after i updated my OFT from OFM and downloaded the newest tune. Right now i have the A01C tuned loaded onto my car and start up fine. Has anyone notices this or is it only me? Should i worry about this? Thanks Ben |
11-03-2014, 04:57 PM | #397 | |
Drives: 2013 FRS
11-03-2014, 05:03 PM | #398 |
11-04-2014, 07:30 PM | #400 |
Drives: SWP BRZ
@Shiv@Openflash
Hello Shiv, i am just sharing my datalogging i had today. when i flashed when v2.06 out, i had IAM .98 I tried different gas and it's reading IAM 1 http://www.datazap.me/u/zc06kissther...ta=1-6-7-10-11 worth every penny spent on OFT |
11-05-2014, 01:59 PM | #401 |
Is it possible to use an oft tune with E0 89?
11-05-2014, 06:23 PM | #402 |
Drives: Asphalt FR-S MT
OFT v2.06 Non-Beta
Are you saying ethanol free 89 octane? Definitely not. Lowest octane that is compatible with the OFT (as well as our car) is 91 octane
11-05-2014, 06:54 PM | #403 |
Seņor Member
The tunes Shiv created would not be a good idea on that fuel. You could however alter the his tunes to work yourself. You would have to lessen the spark advance and possibly the AFRs. I am not sure why you would do this unless you were unable to by the proper fuel in your area.
1974 TA22 Celica
2013 86 GT |
11-05-2014, 09:28 PM | #404 |
Drives: 2014 Subaru BRZ Limited 6smt
So my cars CAL ID is B01C and so are all the tunes on my OFT, as it came from Shiv.
trying to change out St 2 EL for St 1 93OCT and when I select the bin file, it says wrong checksum or something like that? Still reading and trying to find a fix. |
11-05-2014, 09:37 PM | #405 |
I didn't think one would work.. We have Ethanol Free 89 + 87, 89, 93 and 100 octane here. I usually run 93 with the Stage 1 91 tune. I'm running the stock tune with ethanol Free right now just for fun. My car seems to hum along and sounds much quieter with ethanol free.
11-05-2014, 11:27 PM | #406 |
if you have not edited tune then just say yes correct checksum and all good
Similar Threads | ||||
OFT Tune for OFH+Phantom ESC with 1.5 Dump Pack [Beta] | Shiv@Openflash | Forced Induction | 226 | 03-12-2019 09:26 PM |
iOS 8 beta 1 not working on BRZ USB | Kids Heart | Off-Topic Lounge [WARNING: NO POLITICS] | 4 | 04-13-2015 08:17 PM |
v2.01 Phantom ESC 1.5+OFH (BETA)... now supports USDM 6AT | Shiv@Openflash | Forced Induction | 3 | 07-26-2014 12:23 PM |
OFT 1.42 vs 1.5x Beta Who notices a Difference? | Cross | Software Tuning | 11 | 03-21-2014 03:17 PM |
Anyone want to beta-test some door speaker spacers? | phenryiv1 | Electronics | Audio | NAV | Infotainment | 63 | 08-20-2012 09:02 PM |
