Old 03-14-2011, 02:13 AM   #337
Dimman
Kuruma Otaku
Dimman's Avatar
Originally Posted by Maxim View Post
Just based on the fact it's a boxer, it'll have a bit more torque than say....a Honda engine of the same size.
Getting the power down with an NA engine doing 200ish hp will not be a problem at all.
Originally Posted by Aki View Post
It really depends on how and where it's making the power. Honda's have lower torque because they make their horsepower at high RPMs, from 6000-8000. Horsepower is calculated from torque, and they always intersect at 5252 RPM. Any point beyond that, when horsepower gains you'll see the torque dropping on a dyno.
If the FT86's boxer engine makes say 200 hp with a 7000 redline, then yes it'll have more torque. If it makes that horsepower up higher, then you'll see similar torque figures to a Honda K20 engine.
^ The context was absolutely to do with engines of the same displacement. Both your incorrect statement, and my response. K20 also being a 2.0L motor.
No, you're simply not grasping the fact that the an engine like the F20C has to work at higher RPMs for its power, which is big part of why it's got less torque than say a Scion TC. Granted there are a lot of other factors that lead to the particular torque characteristics of an engine, but as a general principle it's true. Why else would they increases the displacement for the S2000 and have a lower redline? More torque.
You are changing the argument. Your original response was related to engines being the same size.
Sigh. I know how DI works, and it's irrelevant. You can explain all day bore and stroke, DI, VVT, iVtec, intake runner length or whatever, but it's completely irrelevant. How the horsepower number is derived is contingent upon the torque. The higher the RPM at peak horsepower, the less torque there is compared to an engine making the same horsepower at a lower RPM. Engines that are peakey are just less torquey. I'm not even comparing engines, because it's not relevant.
Then you should've been aware that it was also completely irrelevant argument given the context of same displacement, same aspiration motors.
Again, failure in comprehension. Power peaking low doesn't mean it automatically makes gobs of torque. You're mistaking causality here, and I'm not even sure why. There are many ways to get more torque, but you don't get it by purposely keeping the power peak low for sake of keeping it low... nor did I ever say that.
Really? My comprehension? No. Observe...
Diesels and FI have lots of torque because they hit their peak at low RPMs.
I am correcting and clarifying your misinformation. If you're not going to be clear and accurate don't post up tech stuff.
Because titanium.
Old 03-14-2011, 02:31 AM   #338
Aki
Drives: '96 beater Corolla
Erm no. Please point to the particular phrase/sentence where I said this is about the same displacement.
Aki is offline   Reply With Quote
Old 03-14-2011, 02:38 AM   #339
Dimman
Kuruma Otaku
Dimman's Avatar
First two quotes in the post above. Guy asking specifically about engines of the same size. You quoting him when you answered. And referencing another engine of the same size.
Don't throw the 'Net 'reading comprehension' excuse out when the issue fully lies on your lack of clarity. Assuming that you are not just back-tracking (which based on your first statement about torque dropping off on a dyno, looks exactly like that, and not a simple oversight error).
Because titanium.
Old 03-14-2011, 02:44 AM   #340
Aki
In other words, that's you just jumping to conclusions. Good job hinging your whole argument on a presumption.
No, this is where I throw in "winning an argument on the internet is like winning the special olympics." The issue lies in your getting riled up over something on the internet. And since this is thoroughly off-topic, I'm ending it at that.
Old 03-14-2011, 02:50 AM   #341
Dimman
Kuruma Otaku
Dimman's Avatar
In other words, that's you just jumping to conclusions. Good job hinging your whole argument on a presumption. Who's backtracking now?
So it would be wrong to assume that the guy you answered was expecting your answer, quoting his question, to be relevant in some small way to what he asked?
Does this argument have to do with your marketing background, spinning shit so that you're not wrong? Sigh...
Because titanium.
Old 03-14-2011, 03:16 AM   #342
Aki
That actually made me laugh, well played sir. Go outside, take a deep breath, breathe out slowly. It'll be alright man =)
Old 03-14-2011, 03:34 AM   #343
Dimman
Kuruma Otaku
Dimman's Avatar
That was half the intent.
And I would, but it's raining...
Because titanium.
Old 03-14-2011, 04:01 AM   #344
Snaps
Supra Owner
Snaps's Avatar
Drives: 1995 Toyota Supra UK Spec
Aki - assuming two engines are DESIGNED to have the same max. power, then yes, the one that makes that peak power higher in the rev range will have a lower torque at that point - that is basically all that Power equation states....
The argument here is NOT limited to a certain max. power... A 'peaky' powerband will be caused by a 'peaky' torque, which, as someone said, is related to the intake port sizes, and other things like VVT-i, V-TEC, etc. (as these change timing and the way the air flows into the combustion chamber.). However, because this argument is NOT limited to a max. power, then that doesn't matter....
Engines that rev high are DESIGNED that way - the heads are designed with larger intake/exhaust ports so the engine can flow more air at higher rpm's, and not get restricted. On the other hand, an engine that is DESIGNED to rev lower will have smaller ports, so will make more torque at a lower numerical rpm, however, compared to the whole rev range of both engines, at the respective points in each engine, the higher-revving engine should make roughly the same torque as the lower-revving engine. Provided they have the same displacement.
E.g.
Redline ------ Comparitive rpm point
5000 -------- 2500 (1/2)
9000 -------- 4500 (1/2)
That is how you should compare two engines with different rev limits, IMO...
It is COMPLETELY unfair to compare two engines with different displacements, as a higher displacement will ALWAYS produce a higher torque if the two engines have similar intake/exhaust port/exhaust/intake setups...
Snaps is offline   Reply With Quote
Old 03-14-2011, 11:32 AM   #345
Matador
hashiryu
Drives: Mk4 Supra
you are just back-tracking (which based on your first statement about torque dropping off on a dyno, looks exactly like that, and not a simple oversight error).
Fixed that there a little for you.
Matador is offline   Reply With Quote
Old 03-14-2011, 04:31 PM   #346
Aki
And that's all I was stating. Thought we were talking about a specific max power (ie 200hp), and it seems like the topic blew up into something else.
If you'd like to believe that then by all means do so.
Old 03-15-2011, 02:40 AM   #347
Snaps
Supra Owner
Snaps's Avatar
It just didn't sound like you were discussing it only to a specific max hp... You never stated it in your post, and it didn't sound like you implied it either.
(Not arguing, just clarifying )
Old 03-15-2011, 08:08 PM   #348
Aki
Ahh, yeah I definitely could've been a lot clearer and precise, so my humble apologies for that =)
Old 03-15-2011, 08:12 PM   #349
aliphian
Dreamer
aliphian's Avatar
Drives: Nutless Grocery Getter
Toyota/Subaru really need to give us some data. Without it, every thread disintegrates into speculative madness.
aliphian is offline   Reply With Quote
Old 03-15-2011, 10:14 PM   #350
NESW20
2.1L 3SGTE
Drives: MR2 Turbo & Tacoma
^^this x eleventybillion
1991 MR2 Turbo - 2.1L high compression stroker 3SGTE
2006 Tacoma 4x4 TRD Off Road - All-Pro front bumper, Old Man Emu shocks, Old Man Emu HD front coils, All-Pro leafs
1990 240SX Coupe - sold
2008 Civic Si Sedan
NESW20 is offline   Reply With Quote
Has anyone compared the rumored price range to.... demby123 Scion FR-S / Toyota 86 GT86 General Forum 22 10-09-2011 04:18 PM
Subaru BRZ Dimensions and More Teasers Released Ahead of Frankfurt BRZman BRZ First-Gen (2012+) — General Topics 48 09-04-2011 12:32 AM
Wheel size, what's your opinion? #87 Off-Topic Lounge [WARNING: NO POLITICS] 4 02-24-2010 04:06 PM
