01-11-2022, 11:24 PM | #337 | |
Drives: 2023 BRZ Limited
01-11-2022, 11:26 PM | #338 |
Drives: 2022 BRZ
01-12-2022, 09:43 AM | #339 |
Drives: 2022 crystal white BRZ
Yea, it's exactly because it's a white pearl. The paint code for both the BRZ and the GR86 is K1X for white so I'm hopeful it'll clean up and match. I'll attempt to clean it when it's warms up a little and provide further photos.
01-12-2022, 03:10 PM | #340 |
Drives: Frs
Installed kw V3 White line rear lower control arms Vorshlog top hats Enkei wheels 18 9.5 +45 PS4S 255 35 18 Alignment/corner balance (for those in southern cali pls check out West End alignment shop awesome super detailed professional)
Ridiculous!
The Following User Says Thank You to Powersfrs For This Useful Post: | Midnightsky (01-12-2022) |
01-12-2022, 06:12 PM | #341 | |
Drives: 2022 BRZ Limited 6MT; '05 OB 5MT
01-13-2022, 01:04 PM | #342 |
Drives: '22 BRZ 6MT MGM
01-13-2022, 01:07 PM | #343 |
Drives: '22 BRZ Limited 6MT
Front looks good but the rear looks like it pokes? Any fender work?
01-13-2022, 01:19 PM | #344 | |
Meow
Drives: GT86, Volvo 996
You could also compare how much you're draining with the conventional method vs. with a pump, provided you work on an AOTBE basis (same draining method before both tests, same quantity of oil put in, same oil temp when changing it, etc.) I've heard those might not drain all the grime that is at the bottom of the pan, but then again some cars have no drain plug and seem to survive. |
01-13-2022, 04:44 PM | #345 |
Picked mine up today and had the winters put on.
My FRS had headers and a tune and the new car is MUCH more responsive. It's going to be a hoot. |
The Following 4 Users Say Thank You to jvincent For This Useful Post: |
01-13-2022, 05:31 PM | #346 |
Drives: Frs
At my height it doesn’t rub one bit even on three wheel motion. Folks seem to have issues with +35 offsets on the back +45 seems to be the way for a flush performance oriented stance.
Ridiculous!
The Following User Says Thank You to Powersfrs For This Useful Post: | beltax90 (01-15-2022) |
01-13-2022, 05:32 PM | #347 |
Drives: Frs
Ridiculous!
The Following 3 Users Say Thank You to Powersfrs For This Useful Post: |
01-13-2022, 05:39 PM | #348 |
Drives: 22 BRZ limited
01-13-2022, 06:38 PM | #349 |
Drives: Frs
Ridiculous!
The Following User Says Thank You to Powersfrs For This Useful Post: | dragoontwo (01-13-2022) |
01-13-2022, 08:04 PM | #350 |
Drives: 2022 BRZ, 1999 "touge-spec" Miata
Got Fortune Auto 500's installed on the car by Fortune Auto themselves. I'll post pics soon. Ended up with 7k spring rate in the front and 8k rear. The shocks are six clicks from full soft and the ride is only marginally stiffer than stock but car turns 10x better now.
Got the front to -1.5deg camber and the turn in has been improved 10x. It's very darty and sharp now on turn in. The car feels extremely balanced now with understeer only happening on very cold tires. I still haven't been able to push the limit of the handling but 60mph corners on my favorite backroad have now become 70+, along the way quicker turn in and being able to get on the gas quicker. |
Similar Threads | ||||
WHAT DID YOU DO TO YOUR FRS TODAY? | KalbiCool88 | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 11-04-2015 10:36 PM |
Do you know what today is? | Yruyur | Off-Topic Lounge [WARNING: NO POLITICS] | 26 | 01-21-2015 02:51 PM |
just got my OFT today...help please! | carlitosway6891 | Software Tuning | 9 | 02-20-2014 10:05 PM |
TODAY, TODAY, I GET IT TODAY!!!! :D | Trashed675 | Scion FR-S / Toyota 86 GT86 General Forum | 54 | 02-14-2013 01:16 AM |
sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 08:53 AM |
