02-02-2020, 10:34 PM | #3375 | |
Drives: Asphalt FR-S
Sent from my Pixel 4 XL using Tapatalk |
02-06-2020, 11:53 AM | #3376 |
Drives: Halo 2016 6MT
Is there any long term solution for the bypass valve issue in the pipeline?
I've eyed this kit for as long as it's been on the market and as is, there's no way that I would touch this kit until the bypass valves are no longer a concern. |
The Following User Says Thank You to Corsus For This Useful Post: | HachiRokuX (02-06-2020) |
02-06-2020, 03:27 PM | #3377 | ||
Guilt free parts vulture!
Drives: 2013 FR-S - Asphalt 6MT
I know one user (@toast?) claims to have solved the problem by tapping the brake booster line so the actuator only sees vacuum, not boost... but I am very curious if others have duplicated his success.
The Following 2 Users Say Thank You to nextcar For This Useful Post: | Corsus (02-08-2020), HachiRokuX (02-06-2020) |
02-07-2020, 10:02 AM | #3378 |
Drives: 14 BSP Edelbrock BRZ
Some of us have had complaints about the performance of the car leaving a stop in first gear. Especially when cold. If you try and feed in gas while simultaneously letting out the clutch (as one does when driving a manual) you will sometimes get a little stumble in rpms and then a fast overshoot as it recovers. Makes you feel like you can't drive a stick. Last night I verified this is entirely due to the action of the bypass valve. With even light throttle application the valve begins to move, so when you go to 20-25% throttle to leave a stop the valve closes a significant amount, the engine registers extra air but the plenum is not really stuffed with air and the car goes rich for a beat. I removed the bypass valve actuator and held the valve open with a zip tie and this behavior totally went away.
Now that I know that I'm going to get back into my electronic valve actuation project. The last obstacle was how to reliably use cable actuation for the valve since I was thinking I would have to have the cable push to get the valve open. I've realized all I need to do is reverse the direction of motion. I will spring load the valve closed and run the actuator cable in from the front and have the linear actuator pull when it is time to get boost. Going on a ski trip next week, but I'm diving in hard when I get back. |
02-07-2020, 10:33 AM | #3379 |
Am I reading the specs for the TMAP sensor for this kit correctly? There is only 1 output signal and temperature information is in resistance and pressure is in voltage?
https://www.bmotorsports.com/shop/pr...oducts_id/1721 |
The Following User Says Thank You to toast For This Useful Post: | CSG Mike (02-07-2020) |
02-07-2020, 10:41 AM | #3380 |
Looks like it. They use a Negative Temperature Coefficient resistor to indicate temperature which is nonlinear.
Pressure supposedly linear and a voltage output. I'm interested in this project. I'm an EE/controls engineer. Sent from my Pixel 3 using Tapatalk |
02-07-2020, 01:35 PM | #3381 |
Ah, no then I wasn't reading it right. I thought the temp and pressure were somehow encoded on one output. The NTC line is the temp; That is great. Any idea if it is measured between the line and ground or line and 5v?
Since moving the MAP sensor to a separate box that isn't affected by the runner resonances I'm worried that I won't get good IAT measurements. I want to take the temp signal from the sensor in the runner and the pressure from the sensor in the closed box. |
02-07-2020, 01:56 PM | #3382 |
I would assume it would be between ground and the ntc output but you could easily measure it with a multimeter to be sure. There is a table of temp vs resistance. Measure at room temp then throw it in the freezer for a while and measure it again, or any way to get a known temp change that you can reference to that chart. Even body heat would be enough to see the change. The rest of the measurement circuitry must be in the ECU, probably a resistor divider. Most signals end up as a voltage into an analog to digital converter at some point.
02-07-2020, 01:58 PM | #3383 |
Out of curiosity where did you move the MAP sensor to? I have thought about doing something with that, or even some sort of snubber on the sensor to smooth stuff out. Just end up with some sort of phase delay, but I'm sure a little doesn't hurt.
02-07-2020, 02:07 PM | #3384 |
02-07-2020, 02:09 PM | #3385 |
Also, while I had my actuator off...
For anyone removing and reinstalling the actuator the nylock nuts on it are 8-24 nuts. The one on the left comes with the kit, the one on the right is from Home Depot. Having a lot more thread to engage should help with stripping the threads on the shaft. You don't have to make them very tight just snug. |
The Following User Says Thank You to toast For This Useful Post: | BirdTRD (02-07-2020) |
02-14-2020, 06:38 PM | #3386 |
Damned MAP sensor is reading pegged to maximum. bought new MAP sensor and same issue. ugh
02-15-2020, 01:10 PM | #3387 |
Pull out the Edelbrock extension harness that goes to the MAP and check for continuity across all the pins.
02-15-2020, 01:31 PM | #3388 |
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
