06-27-2015, 07:09 PM | #323 | |
chicken tonight
edit: nvm lazy question. sorry.
06-27-2015, 08:51 PM | #324 | |
Drives: JDL Turbo FRS, 335SC BRZ (ret)
I think folks need to put this in perspective a bit as well. The 335 is about 50% bigger than the 210. Spinning a 210 with a 70mm pulley gets you about 15000 RPM by 6800 RPM. The 335 is spinning about 25% slower (rough math) with the larger pulley. Nothing huge at that drive level, especially on e85. For pump gas I'd definitely do the 85mm pulley on the 335. Those are cheaply available from us or sprintex. You can also cut the rib under the hood and get the 90 or even 100mm pulley from MRT in AU for about 200 bucks shipped to the US. Not a huge deal. Though really at that point I'd say just stick to the 210 and why we didn't bother importing them. We're going to focus more on the track side in the next few months, and for that we'll go down to the 85mm. Realistically over 250 torque on the track in this platform is a bit much on a road course without a full cage etc...so 300whp is a much better power level and we can hit that no problem with the 85mm. The challenge I expect sooner is the temperature management. Big power means major work there, and with the oil cooler and off the shelf koyorad I hope that'll be enough. |
The Following 5 Users Say Thank You to Xero-Limit For This Useful Post: | Calum (07-04-2015), CK_Bladesmith (06-28-2015), OilFieldTrash (06-27-2015), SprintexUSA (06-28-2015), stockysnail (07-12-2015) |
06-28-2015, 03:54 PM | #325 |
Drives: toyota mr2/ Toyota GT86
So how much boost pressure does the 335 make on an 85mm and what are the IAT's like post compressor?
The Following User Says Thank You to 350matt For This Useful Post: | Chad86 (07-04-2015) |
06-28-2015, 04:50 PM | #326 |
Thats pretty neat
Drives: LOADING......
@moto-mike Whats the max lb/min of the 335?
The Following User Says Thank You to WHITE For This Useful Post: | Chad86 (07-04-2015) |
07-04-2015, 12:54 PM | #327 |
Drives: 2017 Halo Toyota 86
So we just finished pulling off the stock exhaust which became a severe limitation as we were testing both the limits of the kit and the limits of the stock system. I would not recommend this kit without replacing the header back. It is just to much and this may seem like common sense but sometimes it still needs to be said!
Using a P&L Motosports Header HKS Front Pipe Nvidia Over pipe Perrin 3in Catback (Yes I was playing mix and match due to part availablity :P ) On the 85mm we managed 280whp / 245 trq on e85. This is on a very unforgiving mustang Dyno also. I am looking locally for a dynojet to get numbers from so I can show both. Some people have mentioned the throttle body being an issue, but to my knowledge people who are running much higher hp/trq set ups with turbos use the same throttle body. How would that be different for us?
previous build thread!
http://www.ft86club.com/forums/showt...236#post962236 |
07-04-2015, 01:28 PM | #328 | |
TechNINJA
Drives: Whiteout MT, 87 Mustang, 09 RUCKUS
I have a full exhaust except for the overpipe, but have been eyeballing Nameless' full 3" from header back... |
The Following User Says Thank You to DIE1000DEATHS For This Useful Post: | 20firestorm13 (07-04-2015) |
07-04-2015, 01:46 PM | #329 | |
If you go with a 3in over pipe be prepared for rubbing. There is not a lot of space at all under there.
And if you want to do it this year, you may want to order it now. Quote:
07-04-2015, 03:44 PM | #330 |
TechNINJA
07-04-2015, 04:31 PM | #331 |
Sucking vs blowing would be my guess. On turbos, the the throttle body is pressurized and all you have to do is open the intake valve for air to flow. The supercharger has to suck the air in, and its much easier to suck fast through a big straw...
07-06-2015, 01:03 PM | #332 |
Drives: '14 981CS, '99 NB1
This is exactly it. Turbo's push through the TB, which is much more efficient than a PD blower which generally pulls through.
07-12-2015, 08:57 PM | #333 |
Just the tip
Drives: 2013 Lightning Red Subaru BRZ Mt Lt
The Perrin intake with a metal charge tube instead of the plastic makes it much more noticable. Most of it is from the Perrin intake. I have a few videos of my car on the track in my build thread near the bottom of the first post in the build thread.
Current: 2013 Lightning Red Subaru BRZ Limited
Past (sold): Click here to see previous cars and bikes |
07-12-2015, 09:04 PM | #334 | |
Just the tip
I'm looking forward to seeing what you guys find out. Once next years tax return happens I'll probably be looking for AP Racing Sprint kit and the flex fuel kit for my 210 Sprintex, then 335 kit after that, or maybe before flex fuel if that turns out to be promising.
07-15-2015, 07:32 PM | #335 | |
Drives: Supercharged GT86
Would Perrin be your recommendation or is there anything else to consider? |
07-15-2015, 09:13 PM | #336 | |
Just the tip
Tags |
500whp or bust, sprintex, sprintex 335 |
Similar Threads | ||||
The new sprintex 335 supercharger | jet86 | Forced Induction | 39 | 11-01-2014 11:27 AM |
Innovate/sprintex SC | rudysaliby | Scion FR-S / Toyota 86 GT86 General Forum | 3 | 10-28-2014 03:14 PM |
Innovate/ Sprintex vs vortech | GeeTee86 | AFRICA | 24 | 04-04-2014 02:38 PM |
Innovate/ Sprintex vs vortech | GeeTee86 | AFRICA | 5 | 03-05-2014 07:26 AM |
TyperRspec789's Full Blown Stage 1 Base Turbo & e85 Progress and Testing | TyperRspec789 | Forced Induction | 63 | 12-31-2013 07:39 PM |
