go_a_way1
Old 04-16-2016, 05:27 AM   #3067
wildpandaz
Drives: Scion Frs 2013
Planning to go for 17x9 +35 on Stock everything suspension wise. I do plan to drop it an inch in the future and wanted to know if these wheels will work on both stock suspension and after its dropped on springs. Any rubbing? And what tire sizes would you recommend?
wildpandaz is offline   Reply With Quote
Old 04-16-2016, 05:40 PM   #3068
Killerbee
Killerbee's Avatar
Drives: GR86 / Supra MK5 MT / MR-S / Z4
No issues on the wheel size (its tight but will fit). Will work on stock and lowered (springs or coilovers, works both)
Tires I would suggest 245/40/17
Killerbee is offline   Reply With Quote
Old 04-27-2016, 03:11 PM   #3069
nottabrzbobby
Drives: 2015 white scion Fr-S
18x9.5 +35
Originally Posted by JoeBoxer View Post
I'm here to help also guys better to ask than end up with less than ideal fitment.
Hey man im on BC racing coils lowered about 1.5 inches but going to change when I get my rims im putting 18x9.5 +35 an I am wanting stretch that will look good but still be sturdy
nottabrzbobby is offline   Reply With Quote
Old 04-28-2016, 01:17 AM   #3070
wildpandaz
Would you also suggest 245/40/18 on 18x8.5 +33 all around? Still stock suspension.
Old 04-28-2016, 01:29 AM   #3071
swarb
245/40-18 is a little tall. 245/35-18 is the best choice.
The Following User Says Thank You to swarb For This Useful Post:
Killerbee (04-29-2016)
Old 04-28-2016, 11:17 PM   #3072
2broke4turbo
Drives: '13 frs 6MT
will this rub? 17x9.5 and 245/40/17 tires on H&R super sport springs?
if so, please suggest a solution. (I know coilovers is one)
2broke4turbo is offline   Reply With Quote
Old 04-29-2016, 07:31 AM   #3073
Killerbee
Killerbee's Avatar
Agree on 245/35/18 as the choice for 18". The 245/40/18 can be done, but is too tall so your speedo will be a bit off.
Old 05-02-2016, 04:25 AM   #3074
BlaineWasHere
Grip>Drift
BlaineWasHere's Avatar
Drives: FRS
What's the offset? It'll probably rub.
Old 05-02-2016, 03:36 PM   #3075
2broke4turbo
Drives: '13 frs 6MT
+35 I believe
Old 05-07-2016, 07:18 PM   #3076
BlaineWasHere
Grip>Drift
Drives: FRS
+35 I believe
it's gonna be close. Might need a little spacer in the front. Depends on how much camber you have too.
The Following User Says Thank You to BlaineWasHere For This Useful Post:
2broke4turbo (05-08-2016)
Old 05-08-2016, 12:27 AM   #3077
LANI86
Drives: 2015 Scion FR-S
Sorry, can you help a noobie here?
I'm planning on doing the TRD lowering springs w/ stock struts on my FRS and going 18x8.0 (+48) and 18x9 (+52) or even 18x8.5 (+45) and 18x9.5 (+45) if they fit. Will these clear without ANY rubbing?
I am not sure what size tires are ideal for daily usage, but thinking of going 245 or 255; whichever is recommended.
What do you all think? Thank you.
LANI86 is offline   Reply With Quote
Old 05-08-2016, 10:06 AM   #3078
tdotBRZ
tdotBRZ's Avatar
Drives: 2014 BRZ Limited SWP 6MT
Originally Posted by Kendallkab View Post
I might be pushing it a bit but could this work maybe?
18x9.5 +38 all around
5mm spacer for the rear ( going for a flush look )
245/40 for tires
According to the frsproject site this would work on a 1.4 in drop using coilovers unless I'm reading it wrong
Would I need to drop it less?
Could I drop it at all?
I'm running 18x9.5 +38 in the rear without any spacers and it is flush and no rubbing. Tried 245/35/18 tires for them last season, they were slightly stretched, now switched to 255/35/18 look better and better for the track and no rubbing issues.
tdotBRZ is offline   Reply With Quote
The Following User Says Thank You to tdotBRZ For This Useful Post:
Kendallkab (05-09-2016)
Old 05-08-2016, 10:08 AM   #3079
tdotBRZ
tdotBRZ's Avatar
I'm running 18x8.5 and 9.5 staggered, I tried 215/40/18 and 245/35/18 last season they were slightly stretched, now I switched to 225/40/18 and 255/35/18 and loving it no issues of rubbing or anything.
Old 05-08-2016, 07:00 PM   #3080
LANI86
So if I have 1 inch drop with the TRD lowering springs on stock struts:
18x8.5 and 18x9.5 with +45 all around, with 245 or 255 tires, will these clear without any rubbing?
fitment, flush, offset, rays volk te37's, rims, rotas, size, spacers, width
Determining the proper width size of the tire CyberFormula Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 49 05-23-2014 09:11 AM
Correct tire width for each wheel width DarrenDriven Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 10 08-16-2012 02:03 PM
TIRE SIZE CALCULATOR White64Goat Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 6 08-15-2012 02:31 AM
Tire Width vs Wheel Width Synack Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack 40 08-12-2012 11:21 PM
