04-28-2014, 11:57 AM | #295 | |
04-28-2014, 04:51 PM | #296 |
04-28-2014, 05:27 PM | #297 |
Kinda true... the OTS maps are built off the newest ROM, but tweaked to work like it's stock. So I'm running a 700c ROM (OLD!), but it's based off the A01C ROM (unless it was updated again to a newer one).
04-28-2014, 06:31 PM | #298 | |
The 700c to a01c was just a couple of parameter changes the b01c is complete structure change for some reason. |
04-28-2014, 06:58 PM | #299 |
Very true, forgot to mention about unmarrying it.
05-16-2014, 01:53 PM | #300 |
Drives: 13 White MT FR-S
bump
05-16-2014, 08:56 PM | #301 |
Still have to get to the dyno to look at comparisons.
05-16-2014, 08:57 PM | #302 |
Go-Kart Enthusiast
Drives: Toyota Scion FRS
I have the OFH, OFT stage 2 with the q300 which is a very quiet exhaust system. I hardly ever hear it.. go stage 2 if you hate the sound
FRS
Current mods: K&N air filter, OFT, OFH, berk high flow cat front pipe, Q300 exhaust, lighter wheels |
05-17-2014, 03:01 PM | #303 | |
I used Tatrix, ECUFLASH, and TD-D's rom&dev posts. I held my breath thru the flash but it went well and going from the original calib to the 2014 is like night and day. I almost feel comfortable reving this engine now, they (OEM's) had to have done some behind the scenes improvements.
2013 FRS Argento Silver 6MT
Mods: Clear fender side lights Tactrix ZA1JB01C 2014 Calib |
05-17-2014, 03:17 PM | #304 | |
05-17-2014, 03:19 PM | #305 | |
I added ROMs (well B01C and A01G) at end of the Tactrix info post http://www.ft86club.com/forums/showthread.php?t=62332 |
05-17-2014, 03:20 PM | #306 | |
05-17-2014, 03:30 PM | #307 | |
Th VVT noise is gone, but understand I went from the very first 2012 calib which we all know was junk.
05-17-2014, 03:50 PM | #308 |
Sanity check, then. If I use the ECUFlash to flash the latest B01C ROM, I can still use the OFT as well, correct? I'd zero the OFT and read the B01C from the car. IIRC, though, the ECUFlash will do just about any ROM, and is NOT idiot (moslty) proof.
Am I close? |
Similar Threads | ||||
Variable Valve "Butterfly" Exhaust | dlux | Southern California | 19 | 02-22-2016 06:21 PM |
First tank OFT E85 tuning. Noise? | Tromatic | Software Tuning | 2 | 02-20-2014 05:43 PM |
Exhaust Cut Off Valve | beagoodruslan | Engine, Exhaust, Transmission | 2 | 01-01-2014 01:47 AM |
Exhaust Noise that goes away after warmed up | FastLane1000 | Engine, Exhaust, Transmission | 10 | 08-15-2013 10:06 PM |
Knock/valve slap/crick noise under accel | yomny | Issues | Warranty | Recalls / TSB | 47 | 01-07-2013 08:53 PM |
