10-03-2018, 12:36 AM | #2885 | |
This has nothing to do with your header, but you should not be running the CARB tune with an aftermarket header anyways. Fix your install, then get a proper tune, to make it run properly. PM me to purchase a tune. |
10-07-2018, 11:08 AM | #2886 |
Drives: 86
More of a road course guy but the drag strip is fun every now and again. First time I took my FRS out last year the track was rained out and I was only able to make one pass where I spun all the way down the track, ended up running a high 15 or something silly so I didn't post it.
Went again a week or so ago and go rained out again but had slightly better luck, was able to run a 3-4 passes. Car still has a lot left in it just because I have a lot to learn on launching the car without excessive wheel spin. Shame I wasn't able to make more passes as I'm confident I could have hit a 12 with some more practice. Best ET 13.2 @107mph Best Trap 13.6 @109 Car setup: 6spd FRS Edelbrock w/ stock pulley DW300c fuel pump and DW 700cc injectors Delicious D box, flex fuel kit, and Edelbrock tune Gruppe-S UEL header and over pipe (both coated) HKS LegaMax E85 Stock clutch 327whp 243wtq 215/45/17 MPSS on stock wheels aired down in the rear to 28psi (lol not exactly drag tires) |
10-08-2018, 09:31 PM | #2887 |
Drives: 2015 BRZ Limited
Somebody make a strut bar that fits! LOL
10-10-2018, 09:20 PM | #2888 |
Drives: Supercharged Car
More of an FYI and data point. Went to SMOG my car with the Edelbrock Kit installed, I live in CA. Car passed no problem.
The technician typed in the E.O. number, ran the visual and proceeded with emissions. Easy peasy 15 mins. In and out. Mods are all CARB compliant (stock headers, stock engine, catback exhaust) Last edited by itsibarra; 10-13-2018 at 01:01 AM. |
10-28-2018, 05:02 PM | #2889 |
Drives: White 86
For those who have a D-Box, do you guys feel the improvement from driving? I have MotoEast remote tuned my car and sometimes I can feel some weirdness/hesitation throughout the 3k to 7k rpm range. Mike suggested me to get a Dbox, just wonder if it will really solve the problem?
10-29-2018, 06:20 PM | #2890 | |
Drives: 2013 DGM BRZ
Can you post up logs from when that's happening? It should be pretty easy to spot where/when that is causing you issues. |
11-04-2018, 05:57 PM | #2891 | |
Drives: 2013 Subaru BRZ
11-04-2018, 09:43 PM | #2892 |
Drives: 86
11-13-2018, 03:15 PM | #2893 |
Drives: '13 with go fast bits attached
Just ordered mine! Excited for the boost
The Following User Says Thank You to diluzio91 For This Useful Post: | CSG Mike (11-13-2018) |
11-13-2018, 03:48 PM | #2894 |
Drives: 2014 Porsche Cayman S
Get a Delicious Tune, too...you won't regret it
It's not speed or the attention that matters, it is that unexplainable moment when man and machine become one! At that time, nothing else exists except the path before you.
11-14-2018, 01:03 AM | #2895 |
Drift office is doing mine
Sent from my SM-G965U1 using Tapatalk |
The Following User Says Thank You to diluzio91 For This Useful Post: | paiceyfan (11-14-2018) |
11-14-2018, 07:04 AM | #2896 |
Subaru Ambassador
Drives: 13 BRZ 18 Silverado
Mine is at my sponsors shop now, getting installed in the next few weeks. This is a track only car so I'll have some good info on how much abuse this system can take.
The Following User Says Thank You to subielife For This Useful Post: | Takumi788 (12-10-2018) |
11-18-2018, 11:36 PM | #2897 | |
Drives: 2013 FRS
I'm going to be running a similar set up. I'm finishing up my E85 tune and I have full 2 1/2" exhaust w EL header.. Hope to get my supercharger in summer...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
11-21-2018, 12:57 PM | #2898 |
Simply Forgotus
Drives: 2014 Supercharged SSM BRZ Limited
I guess it's belt time. 23K miles and a little over 2 years. I heard a slight squeal a couple weeks ago on start up (a little cold outside) but that's it, I never heard that piece slapping the hood, could have been while the car was warming up though.
Similar Threads | ||||
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
Edelbrock E-Force Supercharger | itsibarra | Forced Induction | 938 | 07-31-2021 04:48 PM |
Most annoyingly over-asked questions on FT86 forums | mit_peid | Off-Topic Lounge [WARNING: NO POLITICS] | 36 | 01-16-2014 02:48 PM |
Brz Info/Specs (helpful info for questions asked often) | Gaen | BRZ First-Gen (2012+) -- General Topics | 0 | 05-24-2012 10:09 PM |
