06-22-2017, 12:59 AM | #2787 |
btr.life
Drives: 2022 GR86
That's correct.
The Following User Says Thank You to justinco For This Useful Post: | smg1138 (06-22-2017) |
06-22-2017, 01:02 AM | #2788 |
Drives: 2013 FRS, 2024 Trueno Edition
The justification for the rule was that from the factory those foam pieces are attached to the car and will not move around with the spare tire removed.
The Following User Says Thank You to Shneegle For This Useful Post: | smg1138 (06-22-2017) |
06-22-2017, 08:41 AM | #2789 |
Drives: 2017 BRZ
06-22-2017, 08:43 AM | #2790 |
Drives: 2013 WRB BRZ
I bought some velcro strips for mine. They seem to be working to hold them in place, but still removable.
The Following User Says Thank You to BigTuna For This Useful Post: | cjd (06-22-2017) |
06-22-2017, 11:05 AM | #2791 |
APEXHNTR
Drives: 10 Series FR-S #1867
Oh wow I missed that update. That's pretty dumb. Like taking them out accounts for significant weight savings??
Clips are missing on both of mine. Guess I'll have to buy clips...
2013 Sc10n FR-S 10 Series #1867 of 2500 in the garage...2001 Toyota 4Runner [Solid Axle Rock Toy], 1987 Pontiac Fiero GT [Shitwagon], 2004 Honda Interceptor VFR800 [daily rider], 1978 Suzuki GS750 [Café Racer] |
06-23-2017, 12:51 AM | #2792 |
The Stig's German cousin
One of mine is secured with painter's tape. They are so light, you don't need much stick to hold them in place. If you use too much velcro I can see you breaking the piece trying to remove it.
The body shop abused my other one when removing it - I have a clip for it, but the clip is so loose that the painter's tape on the other piece actually does a better job holding it in place. Again, if you need a clip at nats, I will have some spares with me. I also won't be protesting anyone for missing styrofoam. |
The Following User Says Thank You to renfield90 For This Useful Post: | strat61caster (06-23-2017) |
06-28-2017, 10:14 PM | #2793 |
Drives: 2015 CWP BRZ
So who all is going to Solo Nats 2017? I really want to go in my car but I just don't have the funds to get the car prepped better. Anyone need a tire warmer?
07-05-2017, 09:23 AM | #2794 |
Bristol Champ Tour and Match Tour videos:
Champ Day 1 - [ame="https://www.youtube.com/watch?v=GAvNzMNnl3E"]Bristol Champ Tour Day 1 - Kyle Herbst - #189 STX - YouTube[/ame] (no sound for whatever reason) Champ Day 2 - [ame="https://www.youtube.com/watch?v=9JXxD1L5ejY"]Bristol Champ Tour Day 2 - Kyle Herbst - #189 STX - YouTube[/ame] Match Tour Best - [ame="https://www.youtube.com/watch?v=Ubw5V24vvjY"]Bristol Match Tour - Kyle Herbst - #89 STX - YouTube[/ame] |
The Following User Says Thank You to M0nk3y For This Useful Post: | DocWalt (07-05-2017) |
07-05-2017, 12:16 PM | #2795 |
Drives: 2022 BRZ
Wow that place looks bumpy
2022 BRZ 71 STR
Sponsors Xero-Limit//Karcepts |
07-05-2017, 12:19 PM | #2796 |
It was. Sent from my iPhone using Tapatalk
Kyle H. - #89 STX
07-07-2017, 05:20 PM | #2797 |
Drives: 2014 SWP BRZ
Going to be upgrading the suspension on my BRZ late this summer & just looking for some opinions before I pull the trigger. Current set up: Bilstein b8 dampers w/ RCE Tarmac springs & RCE street camber plates. 17x9 wheels with Re71r's. Alignment -2.8f/-2r. Have had this setup for apprx 2 years.
Wanting to make the jump to coils for the damper adjustability, spring rates, and ability to corner balance. Planning on going with RCE Tarmac 2's (400/400), a 22mm front sway, front endlinks, SPC rear lower control arms, and whiteline rear bushings. Question: is there really any difference between the perrin, whiteline, and strano front sway bars? Also, are all endlinks created equal? Was planning on whiteline, but if there are better options out there I'm all ears. |
07-07-2017, 05:40 PM | #2798 | |
Drives: 2013 Raven FR-S
07-07-2017, 05:45 PM | #2799 | |
iirc from softest to stiffest OE (18mm) Perrin 19mm Strano (I think it's in between the Perrin soft and stiff settings) Whiteline 20mm (I think Perrin on stiff setting is stiffer than Whiteline on soft, a bit of overlap here) Perrin/Whiteline 22mm (not sure which is stiffer here) And then there are more options on top of that. Personally I'm not a fan of the end links whiteline provides with their sway bar for the 86, I find them difficult to install and swap to a different hole and they come loose about every 4-6 months for me. They're also too long for this car, if you search you'll find some people have hacked off the ends to make them work a bit better. But I do think adjustables are the way to go, I did ghetto hardware store links in the rear and I'm living with the Whitelines up front (with a 20mm bar) for now. As above most people think softer sway bars are the way to go. |
07-09-2017, 12:33 AM | #2800 | |
btr.life
Drives: 2022 GR86
Ran a whiteline 20mm on soft for the whole year on my FRS and a bit on my BRZ. Recently switched to the 22mm Perrin in the front and I like that better (both setups with whiteline front end-links). Going to be trying the new Mann 12mm adjustable rear bar here soon, also adding rear adjustable end-links.
The Following User Says Thank You to justinco For This Useful Post: | Racecomp Engineering (07-10-2017) |
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
