Old 05-04-2016, 05:02 PM   #15
Gloonge
Drives: 2013 frs raven
Originally Posted by Ben_G View Post
Same thing, but the installation instructions give a better way to locate the pins on the bumper.
http://www.ft86speedfactory.com/move...l#.ViT9auxVhBc
Any idea where one might find the little adapters to change the angles of the rear pins like the ones in this kit?
I know this is an old post, but here's to hoping.
Gloonge is offline   Reply With Quote
Old 05-15-2016, 03:03 AM   #16
zeal86
zeal86's Avatar
Drives:
@BirdTRD Great write-up! I hope to tackle this project this upcoming week.
I do not have the dreaded gap problem...However, I currently have my bumper cover off for the second time... no telling if it will line up right when I go to reinstall it...plus I wanted to do this anyway...
Thanks again for the very detailed write-up you put together!
__________________________________________
projekt zeal86 build
zeal.eightsix Facebook
Instagram | zeal.eightsix
zeal86 is offline   Reply With Quote
The Following User Says Thank You to zeal86 For This Useful Post:
BirdTRD (05-15-2016)
Old 07-12-2016, 08:06 PM   #17
CladMonitor
CladMonitor's Avatar
Drives: 2013 FR-S Asphalt
Worked perfect great DIY!
CladMonitor is offline   Reply With Quote
The Following User Says Thank You to CladMonitor For This Useful Post:
BirdTRD (07-12-2016)
Old 07-28-2016, 04:22 PM   #18
SkAsphalt
Ridge Racerrrrrrrrr
SkAsphalt's Avatar
That is good to know we only need one per side
So you use these, and just the plastic pop rivets up top, how many things do you leave in the bottom of the bumper to actually make it "quick release" for you?
Old 10-01-2016, 02:12 PM   #19
Bramick
Bramick's Avatar
Drives: 2013 BRZ Limited M/T
Just installed. Works great. Easy to do.
Thanks for the write up.
2013 BRZ Limited | 1965 Mustang GT Fastback
Bramick is offline   Reply With Quote
The Following 2 Users Say Thank You to Bramick For This Useful Post:
BirdTRD (10-02-2016), zeal86 (10-01-2016)
Old 10-22-2016, 06:25 PM   #20
Bramick
Bramick's Avatar
I've had my bumper since my install. If I'm trouble releasing the latch because it won't push in, do I need to move the pin in or out more?
Old 10-22-2016, 06:29 PM   #21
Bramick
Bramick's Avatar
Old 10-22-2016, 08:16 PM   #22
zeal86
zeal86's Avatar
Drives:
Originally Posted by Bramick View Post
From what I remember from my install which was slightly different than yours... your latching post is way too far out... you need to adjust it back in.
Instagram @zeal.eightsix
Bramick (10-22-2016)
Old 10-22-2016, 08:20 PM   #23
BirdTRD
Simply Forgotus
BirdTRD's Avatar
Drives: 2014 Supercharged SSM BRZ Limited
Just from the looks of it, I would say make the post just a bit shorter, but not so short it "pulls" the bumper cover inward. Mine was a little stubborn too. I found that it developed a bit of surface rust on the tip, so I put some light grease on it to help it release easier.
I remove all the bumper cover fasteners and other hardware first then pull on the side marker opening while pushing on the latch button...works well for me. It's kind of screwy to have to push in on the button and pull out on the bumper at the same time, but that's how it's designed.
BirdTRD is offline   Reply With Quote
The Following User Says Thank You to BirdTRD For This Useful Post:
Bramick (10-23-2016)
Old 10-23-2016, 04:47 PM   #24
Bramick
Bramick's Avatar
Response from the manufacturer. Might order the spring and bracket. That'll keep junk out and perhaps make it easier to remove.
The issue you are experiencing could be caused by a number of factors including adjustment too high or too low.* If the pin is adjusted too low and it barely reaches far enough to engage the latch, then you may benefit from the use of a longer pin which is available as an option here:*http://www.quik-latch.com/elongated-...latch-pin.html
If the pin is adjusted too high, you will also have difficulty pushing the button for disengagement.* As I am sure you noticed prior to mounting the latch, there is an internal .034" internal spring loaded free play inside the latch.* This is to allow the ball bearings to move back and forth inside the latch to allow for pin engagement. The latch functions best when the pin is adjusted so that it is located centrally within the .034" free play.* Sometimes finding the correct adjustment is a process of trial and error, but once you find it, it will be pretty obvious because the latch will begin working more smoothly.
Another factor that can affect latch disengagement performance is pin to latch misalignment.* Even though the latch and pin can independently pivot off of a perpendicular axis, if the surfaces they mount to are not flexible and cannot pivot, alignment becomes much more critical.* Misalignment of the pin to latch as little as 1/32" can result in binding when attempting to disengage the latch.
Lastly, if pin to latch alignment looks good and the vertical adjustment is good, then you may want to try these springs:*http://www.quik-latch.com/mini-latch...t-spring.html*
Old 10-26-2016, 01:31 PM   #25
Bramick
Bramick's Avatar
I ended up moving my pin lower (in) and it resolved my issue.
The Following User Says Thank You to Bramick For This Useful Post:
zeal86 (10-26-2016)
Old 12-02-2016, 04:20 PM   #26
Grip Ronin
The Mechanic
Grip Ronin's Avatar
Drives: Civic Turbo,FR-S
good write up that bumper drives me nuts
IG-Joey_Soul
The Following User Says Thank You to Grip Ronin For This Useful Post:
BirdTRD (12-02-2016)
Old 11-23-2017, 07:39 PM   #27
tonytduc
tonytduc's Avatar
Great thanks!
tonytduc is offline   Reply With Quote
The Following User Says Thank You to tonytduc For This Useful Post:
zeal86 (11-23-2017)
Old 11-25-2017, 11:27 AM   #28
Exrald
Exrald's Avatar
Drives: 2013 Scion FRS & 2022 GR86
Will the 1" size with for our bumper?
2013 Scion FRS @Exrald.frs
2013 Scion FRS
2022 Toyota GR86
Exrald is offline   Reply With Quote
quik latch
DIY - Quik Latch Mini install(front bumper) stevo_12v DIY (Do-It-Yourself) Guides 31 07-20-2018 10:12 AM
DIY: TheRetrofitSource/Morimoto Retro-Quik Install in FR-S civicdrivr DIY (Do-It-Yourself) Guides 236 07-10-2017 12:04 AM
FS: Quik Latch Mini Black Ny Brz Exterior Parts (Aero, Lighting, Etc.) 1 06-22-2015 07:10 PM
FS: WA _Black Anodized Mini Quik-Latches NEW ..Great fix for bumper fitment issues!! glamcem Exterior Parts (Aero, Lighting, Etc.) 6 11-26-2014 01:21 PM
Rear Bumper removal / bumper latch SmartedPanda Cosmetic Modification (Interior/Exterior/Lighting) 3 05-01-2014 01:27 PM
