Software Tuning Discuss all software tuning topics. |
01-27-2014, 12:13 AM | #15 | |
Drives: 2013 FRS
01-27-2014, 12:20 AM | #16 | |
Drives: Subaru BRZ
Seriously good job though. The car really feels like it has way more life in it and its not so rough at higher revs. I am really excited with the direction you guys are moving. I just hope that one day you guys will have some tunes for the Innovate SC... as that is my goal further down the road. The fuel, however, is probably because I had roughly 2-4 gallons of 91 in my tank on fill up. |
01-27-2014, 12:20 AM | #17 | |
Hi Shiv, Interested in running this tune in Australia. The E85 at the pump is rated at 105 RON (petrol rated at 98 RON ,think i'st equivalent to your 93 in US) Will E85 rated at 105 RON (Australian) be sufficient for this tune on standard car ?? |
01-27-2014, 12:30 AM | #18 | |
01-27-2014, 01:19 AM | #19 |
Senior Addict
Drives: 86 GT
I was thinking of using the E85 tune as well but there's only 1 station in my area, not very close to my home anyway. Would be simply too inconvenient for a daily driver.....
Hoping E85 become available more easily in future |
01-27-2014, 01:21 AM | #20 |
Drives: 2013 FRS
Unfortunately, I have no experience with your E85 but I suspect it will be fine. But it's a good idea to test carefully when first running it with the E85 maps. Just for peace of mind
01-27-2014, 01:47 AM | #21 |
01-27-2014, 01:59 AM | #23 | |
Ok what KC learned values should I be looking for Value above XX Stays above XX for certain amount of time Currently don't see above 6 and only short duration spikes few seconds most often on lower RPM ranges 1500-4000rpm this is on 98 RON petrol What is dangerous ?? Won't have to worry about cold start here if it gets below 50F everyone would be panicking thing the next ice age is coming Thanks |
01-28-2014, 09:53 PM | #24 | |
Thanks shiv and Jamesm Think I have this "KC Leaned" parameter sorted now. spent last hour or so comparing Engine Load Vs RPM Ignition advance table values against KC Learned value's from my logs. Can now see why your tunes pulled advance in 1500-3000 Rpm area against stock, evidence of knock when I was on stock ROM (2 or 4 degrees discrepancy between KC Learned and advance table values) but very little if any on 1.42 or 1.53 tunes The IAM dropping is and indication you need to look deeper at "KC Learned" and see where your knock occurrs to pull timing I now realise Hopefully I am on the right track |
01-28-2014, 10:16 PM | #25 | |
what this means is that just because you don't see knock in one place doesn't mean it wasn't there. you have to see the whole picture. knock correction learned value will show you the result (but not the actual value of) flkc and coarse correction. coarse correction is your IAM btw. so, if you have a targeted advance value of 5deg.. and your knock correction learn value is 2.5, it means either your iam is 0.5, or that cell in flkc is pulling 2.5deg (which isn't a valid value, they're incremented by 0.35 in the stock rom, but whatever lol), or some combination of the two. so, kclv essentially shows you what's happening in two of the modes. fbkc is just instantaneous correction.. dumb knock correction basically. it's also important to note that the ecu has no notion of knock severity. the knock flag is a boolean value.. i.e. true or false. every x number of cycles the ecu checks this value, and if it's true, it decrements something, if it's false it increments something or does nothing depending on what mode it is currently in. remember we're talking fractions of a millisecond here, which is why it seems like they're all working at once, though they arent. so it works something like this (the short version): by default you're running around in fbkc. when significant knock is detected by the ecu (greater than 3.1 deg of correction iirc), it'll write a value into flkc. if the value written into flkc is large enough (again i believe 3.1deg), it will decrement the IAM by the value set in the rom. after a while of not seeing knock in a load/rpm range, it will increment flkc in that range. this means that it's only possible for flkc to be positive if the iam is less than one. that's just a very basic overview of how things work, but if anyone would like a more detailed explanation feel free to pm me and i'll do the best i can. |
01-29-2014, 04:43 AM | #26 | |
Every day i learn something new is a good day will digest info above , might take you up on your offer once i have my head around this. Last edited by steve99; 01-29-2014 at 07:40 AM. |
01-29-2014, 05:28 AM | #27 | |
so default would be flkc? until driven spiritedly, WOT etc? |
01-29-2014, 10:00 AM | #28 | |
there's talk of a notion of pre-emptive knock control that is based on the load delta, but it's not well defined and i've only been able to find a little bit of (old) information on it. |
Similar Threads | ||||
OpenFlash Tablet | Rombinhood@OpenFlash | Software Tuning | 1838 | 07-29-2023 06:35 PM |
FS: Openflash Tablet | Sgt.Beardface | Engine, Exhaust, Bolt-Ons | 8 | 01-04-2014 11:12 AM |
FS: Openflash tablet | nguyen_er | Engine, Exhaust, Bolt-Ons | 6 | 12-30-2013 12:31 PM |
new OpenFlash tablet | autobrz | Engine, Exhaust, Bolt-Ons | 5 | 12-23-2013 09:05 AM |
***VISHNU OpenFlash Tablet IN STOCK*** | Garrett@Openflash | Engine, Exhaust, Bolt-Ons | 15 | 12-17-2013 01:30 PM |
