Software Tuning Discuss all software tuning topics. |
11-04-2013, 08:27 PM | #15 |
i don't. after reading more, looking back through old logs, and talking to some folks that have been around subarus for a while, it seems this is just 'the way it is'. i guess there's some argument over whether it's problematic or a concern, but it's an extremely common issue, even in stock cars.
so, i'm not going to lose sleep over it. until i see more than a degree being pulled, or anything being pulled under WOT, i'm just going to keep going as if it isn't there. what do you think? assuming this is real (light) knock, is it an issue at the loads and frequency i (and others) are seeing it? |
11-04-2013, 08:29 PM | #16 | |
Drives: Mazdaspeed 3
Good luck with the installation and tuning process. |
11-04-2013, 08:32 PM | #17 | |
11-04-2013, 11:51 PM | #18 | |
I think the car has one knock sensor, but the ECU can tell by the timing which hole is knocking. RickyB, Thanks for the info on Hydra! I'm very excited, turbo and related parts going in hopefully at the end of the week, or early next week. |
11-05-2013, 12:54 PM | #19 |
The sound of ball bearings on a marble floor is hard to miss. For me i have ZERO full throttle knock, but upon shifting during normal driving as soon as i let go of the clutch and put my foot back on the accelerator it knocks (heard/logged). I am not too concerned about it but what bugs me is that it drives the IAM down. By the end of an afternoon driving the IAM is at 0.25 today. If i go out and find a nice stretch of road and floor it for a while it goes back up quickly to 0.6-0.8.
So regardless if its real knock or not, the impact on IAM is real (unless something else is making the changes to IAM). To confuse a bit more check this post of mine, I am still baffled by why IAM dropped like it dropped there. Nice to see you in this post http://www.ft86club.com/forums/showp...2&postcount=56 |
11-05-2013, 01:21 PM | #20 | |
11-05-2013, 01:33 PM | #21 | |
I would think that would solve the problem of removing timing in the lower rpm area yet we would still have fake/real knock which would cause the IAM to trend down. I don't think this would solve the IAM dropping issue. On another tangent, I have it on good faith that temperatures, especially oil have an impact on the mapping, yet in all available definitions I cant find a oil to timing map.
11-05-2013, 02:40 PM | #22 | |
It does solve the aim dropping issue. The timing itself is the same. Final timing is base + (iam * advance) + compensations. The tables were reconfigured such that total timing remains the same. By zeroing advance in that area, flkc has no timing to pull in those areas, so iam never drops as a result. i haven't found any maps referencing oil temp at all, but then i havent really been looking for it. i'm using brzedit and romraider, so not sure if ecutek has them or not. Last edited by jamesm; 11-05-2013 at 03:29 PM. |
11-05-2013, 08:50 PM | #23 | |
Drives: car
Top chart shows engine rpm in blue, knock retard events in red. Bottom chart shows vehicle speed kph in black and IAM scaled up where 100=1.0 I'm going to throw something out there. I think in some cases you're getting LSPI. Considering the nature of LSPI it's not going to happen on every detected knock event, but the fact that you are hearing "ball bearings on a marble floor" sometimes is a big sign that this isn't always false events. What the heck is LSPI? It stands for Low Speed Pre Ignition also known as Super Knock or Mega Knock. It's not very well known in the aftermarket. It sounds scary, and it kind of is. It's what can happen when a turbo engine spools up at low rpm, especially turbo DI engines. It usually happens at 2500rpm or less, especially under 2000rpm. You don't commonly hear about it because DI engines with factory turbos are tuned to stay out of the "no man's land." Usually an LSPI event will hit peak cylinder pressures of 140-190bar, similar to a diesel. Your pressure rate of gets very very high. That's where the noise comes from. It's different from regular old knock or preignition from hot spark plugs and such. There's basically no simple solution for it, and it's somewhat random. Pulling timing often doesn't solve it, although a richer mixture can help sometimes. Theories for its causes abound and I won't dive into them here. So basically, if you're actually hearing a loud "marbles in a can" sound at low speed tip-in, and some simple spark retard is not working, you have limited options to solve it... there are guys with PhD's who have been trying to figure it out for years. I'm not trying to sensationalize anything--you probably make it go away with enough fuel and spark retard. It's important to recognize though that this problem exists and if you really do have it there isn't an easy solution. |
The Following User Says Thank You to arghx7 For This Useful Post: | Toyota86.ir (03-04-2016) |
11-06-2013, 12:28 AM | #24 |
Drives: GT86
@arghx7 - The tip-in knock exists throughout the rev range, even when the transient spark table is heavily modified.. it can be reduced, but not eradicated.. all the tables are not defined, e.g. there are no speed compensation tables around transients.. which is pretty crucial!
11-06-2013, 12:34 AM | #25 | |
11-06-2013, 12:43 AM | #26 | |
11-06-2013, 12:53 AM | #27 | |
Drives: GT86
FWIW, i've only ever seen det on vacuum once (not on an FA20), and that was really odd. |
11-06-2013, 01:38 AM | #28 | |
i'll try to find a log that illustrates it clearly and post it. |
Similar Threads | ||||
BC Racing Coilovers - Knock? | 636 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 42 | 12-09-2015 10:41 PM |
FR-S Rod knock | pozer | Issues | Warranty | Recalls / TSB | 95 | 11-03-2015 09:39 AM |
ca-fi knock off questions | fionnsfrs | Electronics | Audio | NAV | Infotainment | 2 | 10-27-2013 01:47 PM |
Knock on e85 not a problem? | gdrider77 | Forced Induction | 76 | 10-20-2013 11:36 PM |
Would you rather buy knock off parts for your car? | EJ20 | Engine, Exhaust, Transmission | 63 | 11-02-2011 06:17 PM |
