Old 10-17-2013, 12:32 AM   #15
stugray
Drives: 2013 GBS BRZ Limited
Originally Posted by u/Josh View Post
I am shocked to hear that the ecu is running essentially matlab code. Do you have a link for more information on this?
Matlab can be converted directly into C code, so why the surprise?
We use that exact method to develop attitude control software for missions like Deep Impact (to hit the comet)
Now if we said it was running a Labview executable under windows, then I would be scared!
Old 10-17-2013, 12:52 AM   #16
u/Josh
Drives: GBS Limited 6MT
I didn't know that, thanks for the info. Why not just program directly in C? Development time I would assume, but are you sacrificing runtime performance?
u/Josh is offline   Reply With Quote
Old 10-17-2013, 01:14 AM   #17
stugray
I our case, we can have attitude control engineers develop & test the algorithms in Matlab , then port the C-code to the software engineers that embed the coded algorithms into the flight software.
Old 10-17-2013, 07:04 AM   #18
arghx7
Drives: car
http://www.etas.com/en/products/inca_mip.php
So ETAS INCA is one of the leading software and hardware combinations. Competitors include ATI Vision, dSpace Control Desk and Vector CANape. They integrate directly with Matlab. Depending on the system, It's basically a prototype ECU that literally has real time access to every tuning parameter and can datalog at 1000 samples per second. Compare that to a Subaru Cobb Accessport which has maybe 10 real time maps and logs at like 10-15 samples per second. All the hardware ends up costing as much as a BRZ.
When the code is model-based in Matlab, it can be used easily in simulation packages to test if it works before it's used in an engine.
arghx7 is offline   Reply With Quote
Old 10-17-2013, 07:30 AM   #19
DriftEightSix
Pegasus White
DriftEightSix's Avatar
Drives: 86
Originally Posted by xjohnx View Post
Interesting find. It looks like Joe Schmoe can buy a 2 day subscription for $55 and get access to TechStream w/ ECU flashing functionality and the latest ECU rom's from toyota. Might be a good alternative for those of you that want the updated maps but don't want an aftermarket reflash.
Only if you have this "NASTF Vehicle Security Professional Registry".
Driving: Pegasus White Manual GTS 86.
DriftEightSix is offline   Reply With Quote
Old 10-17-2013, 07:42 AM   #20
ft_sjo
Drives: GT86
Matlab is used an awful lot in automotive product development, not just calibration work.
Old 10-17-2013, 07:44 AM   #21
xjohnx
Grip>Slip
xjohnx's Avatar
isn't that only for the security professional level (which basically enables vehicle key/transponder programming in the techstream software)? the professional diagnostic level seems to be available to anyone.
Old 10-17-2013, 07:57 AM   #22
DriftEightSix
Pegasus White
Drives: 86
so it is, i should learn to real the whole page and not skim the shit out of it looking for requirements.
Old 10-17-2013, 11:30 AM   #23
King Tut
NASA SpecE30 Racer
King Tut's Avatar
Drives: 2006 Honda S2000
First discussion of Matlab I have ever seen on an automotive message forum. Matlab is good for coding things up quickly as a proof of concept. It allows you to define whatever you want whenever you want and generally write really crappy code that works in Matlab. The algorithms should then always be ported to a proper coding language for a final software product.
Old 10-17-2013, 02:40 PM   #24
robot
There are now 2 carseats!
Drives: 2013 DGM BRZ
I agree with this...a lot.
I don't like how matlab manages memory of large datasets (I haven't used it in a few years). In production code you'd want to know and control how this is done.
robot is offline   Reply With Quote
Old 10-17-2013, 04:43 PM   #25
arghx7
Drives: car
Every auto company manages the software release process differently. There's typically an in-house software tool to track different levels of software releases and the associated calibration values. It might go something like Matlab/Simulink --> hardware and/or software in the loop simulation --> in house tool/software database --> prototype ROM files and map definition file. That will go into a prototype ECU for realtime tuning or a production one (flashing the ECU for changes) if the vehicle is almost ready for launch and the software tweaks are small.
Old 10-17-2013, 04:51 PM   #26
muffinz
Drives: 2013 DGM BRZ Ltd
I love matlab not only because it is incredibly powerful with elegant syntax, but also bc it has my name in
muffinz is offline   Reply With Quote
Old 10-17-2013, 06:10 PM   #27
arghx7
Drives: car
Your mom named you Atla?
Old 10-17-2013, 06:46 PM   #28
OrbitalEllipses
Drives: Attitude
I chortled.
WORK Emotion Wheels ** Winter Promotion || Free WORK Lugs or WORK Caps ** RavSpec Wheels and Tires 18 12-10-2013 05:19 PM
18x9.5 +38 Work Emotion CR kai Work Metal Buff Jive Turkey Wheels and Tires 22 05-20-2013 01:54 AM
Work Emotion CR Kiwami Bronze 18x8.5 +47 18x9.5 +38 (5x100) w/tires + Work lug nuts serial gixxer Wheels and Tires 41 03-29-2013 03:14 AM
