Old 07-21-2013, 12:31 PM   #15
elefunkd
Drives: brz
Ah, gotcha. Dealer visit it is, afterall. I so wanted to avoid that hassle, but, moving forward and such, it seems inevitable.
Thanks again.
-T
elefunkd is offline   Reply With Quote
Old 07-21-2013, 01:22 PM   #16
Lonewolf
Lonewolf's Avatar
Drives: Moped
Originally Posted by ft_sjo View Post
They all do it. The 'di failure' paranoia threads is dealt with by an updated calibration, however that won't resolve the 4k RPM tip-in det you're talking about. Most of the doom mongers won't know the difference though and will mislead you.
Good to know that you know everything....
Old 07-21-2013, 01:29 PM   #17
jamesm
Originally Posted by arghx7 View Post
How do you know it was knocking? Are you sure you're not just hearing driveline noise? Do you have ECUtek logs showing the knock?
I wouldn't say it's "desireable" condition, but it's certainly a normal one. Just about every modern engine runs on the edge of knock under certain conditions because that gives the best fuel economy. And knock isn't an all-or-nothing thing. There are degrees of severity.
'on the edge of knock' and 'knocking' are not the same thing. if you're engine is knocking, something is wrong.
Old 07-21-2013, 01:36 PM   #18
fstlane
fstlane's Avatar
Drives: BRZ Limited
My BRZ with 2500 miles on it has behaved this way since day one. Any quick shift regardless of the rpm will result in a brief period of detonation. I have also used the knock detector plug in for the Torque app which confirms what my ears hear. I have tried 91 octane gas from a number of different top tier stations as well as blended 100 octane pump fuel at a ratio in the 93-94 range. Unfortunately I feel a trip to the dealership will result in nothing but a wasted trip with a "this is normal" outcome. For now I'm just trying to slow my shifting down a bit and keeping my engine completely stock until a solution is found or a mechanical failure happens. Please share your findings. Thank you!
fstlane is offline   Reply With Quote
Old 07-21-2013, 01:39 PM   #19
elefunkd
Drives: brz
I will definitely update....
But, what a disappointment in terms of lack of r&d on the manufacturers part.
-T
Old 07-21-2013, 02:06 PM   #20
StormTrooper
StormTrooper's Avatar
Drives: Pavement MT GR86
I'm very curious how you're managing it and how any dealer could call this normal.
I have 6500 miles on mine live at 4500 ft and have to use crappy 91 oct gas.
I drive aggressively including shifting in around and after the torque dip and have never noticed this.
If Toyota or Subaru calls this "normal" I'd definitely get it in writing so that when something happens they have to fix it. Reminds me of the oil consumption threads where people were told a quart per change was acceptable.
GR86 MT premium
StormTrooper is offline   Reply With Quote
Old 07-21-2013, 02:51 PM   #21
NotSoJDM
NotSoJDM's Avatar
Drives: '13 BRZ | '04 E55
I have the same issue. For as long as I can remember. My car has 29k on the odo and around 15 autocrosses. Hasn't gotten any worse since when I first noticed it. But my catback does make it much more audible.
Keep us posted on how the dealer trip pans out. Im sure youre already aware, but take everything you read in here with a grain of salt.
NotSoJDM is offline   Reply With Quote
Old 07-21-2013, 08:59 PM   #22
StormTrooper
After driving my car again I have to ask why you would ever notice this.... If you are shifting at 4k you're not in a hurry....
GR86 MT premium
Old 07-21-2013, 10:10 PM   #23
Cameronghanson
Drives: n/a
If it makes a weird harmonic sound when engaging the clutch there are some threads about that. I had that too and had injectors and fuel pump replaced...they went away and within a month or two they came back
Cameronghanson is offline   Reply With Quote
Old 07-21-2013, 10:16 PM   #24
arghx7
Drives: car
I don't know the exact formula your Torque app uses, but the only way it could work is by taking some kind of "before and after" comparison or some kind of statistical analysis of spark timing. It can't read the knock sensor over the universal CAN bus. So you're still at the mercy what the knock sensor is responding to. The knock sensor can be responding to driveline noise, or it could in some cases be a little extra sensitive to combustion noise depending on how the engineer set the background learning signal processor and the knock judgment threshold.
I know what you're thinking. "It's either knocking or it's not. If it's knocking, that's bad, and no engine should be knocking on a regular basis because it will cause damage." Wellll...
Ask trained engineers or engine technicians observing the same engine whether the engine is "knocking too much" and you'll get a different answer. There are two different ways of judging knock. There's a cylinder pressure trace method, and there's an audible microphone method. Notice that I didn't include a knock sensor in that list. The knock sensor reading, as processed by the ECU, is a reflection of some judgment call made during development in terms of sensor placement, calibration of the noise learning, and judgment of the "real knock" threshold.
Cylinder pressure, actual microphone, or knock sensor?
First, somebody decided where to put the knock sensor, which was a series of compromises in and of itself. Then during calibration of the knock system, somebody was physically listening to the engine or looking at the cylinder pressure trace. There are two schools of thought on knock judgment. The "microphone guys" swear that it's the best way to judge knock, and that with proper training it can detect real knock before a cylinder pressure trace ever could. The cylinder pressure guys say the same damn thing, claiming it's more representative than a microphone could ever be.
So, you get two guys listening to an engine and they will have their own opinions on how much noise is too much, unless they were trained by the same guy. And their judgments would then be reflected in the knock sensor feedback system on the ECU, which ultimately affects you the driver. But what about the cylinder pressure trace? Combustion pressure couldn't lie, could it?
Let's look at my cartoonish representation of a typical pressure trace at high load and MBT timing (minimum spark advance for best torque). X axis is time/crank angle, Y axis is combustion chamber pressure measured by pressure transducer.
so that's MBT. Usually you have 50% burn by 6-10 degrees ATDC firing, and peak pressure (shown above) maybe 15-20 degrees ATDC. Now here's a retarded combustion phasing under full load. It's retarded because at a given rpm, we retard ignition timing with increased load to mitigate knock. In this example, peak pressure is around say 30 degrees ATDC.
All of these made different levels of power and fuel economy, and often the uglier pressure traces perform better (except for when they don't). So which one is knocking "too much" ? But why not pull timing more so the pressure trace is less noisy? Well if you decide to do that you'd lose output and heat up the exhaust, requiring you to richen the mixture to keep temps down.
Remember, the knock sensor on your car can't read cylinder pressure and it doesn't have a human being sitting there with a microphone. It's just an approximation of that process. Setting an OEM knock control system is very difficult and except for extreme cases, there is no universal consensus on how much knock is too much. It's all somebody's judgment call, magnified by production tolerances and other factors.
arghx7 is offline   Reply With Quote
Old 07-21-2013, 10:24 PM   #25
mad_sb
Drives: 2013 Asphalt FR-S
Nice post @arghx7 :-)
Old 07-21-2013, 10:32 PM   #26
Suberman
Drives: Subaru BRZ Sport Tech Satin White
Jeepers guys, transient detonation will impact your engine in exactly zero way.
Supercharged engines detonate all the time. It's how the knock sensor works to control boost pressure. Basically a knock sensor controlled engine MUST detonate in order for the knock sensor to sense knock. Only AFTER the engine detonates will boost or timing be knocked back (pun intended).
Serious piston holing detonation just cannot occur in these engines.
Suberman is offline   Reply With Quote
Old 07-21-2013, 10:38 PM   #27
arghx7
Drives: car
I'm not sure I'd go that far... remember the injector issue on some of these engines and the new knock control settings from the dealer reflash.
I was just trying to point out that this is a gray area, not black and white. It's a murkier issue than "my car is definitely knocking and any knock is bad"
Old 07-21-2013, 10:43 PM   #28
elefunkd
Drives: brz
This makes me realize that there is such a thing as a "stupid question"
Stock FR-S Tune Just Done Zach3794 Engine, Exhaust, Transmission 67 11-05-2017 02:01 PM
Visconti vs FA20Club vs Stock Tune Dyno Results mechaghost Engine, Exhaust, Transmission 153 07-08-2013 11:35 AM
Anyone have a stock tune from Visconti? Bleevin CANADA 3 07-03-2013 01:01 AM
My Initial (all stock) BRZedit tune mad_sb Engine, Exhaust, Transmission 6 02-16-2013 12:20 PM
Save stock tune with ecutek? gdrider77 Engine, Exhaust, Transmission 7 01-06-2013 12:50 AM
