Forced Induction Turbo, Supercharger, Methanol, Nitrous |
05-21-2013, 11:53 AM | #15 | |
NASA SpecE30 Racer
- King Tut
Street/Track Car: 2006 Honda S2000 TT3 || Race Car: 1987 BMW 325is SpecE30 || Tow Vehicle: 2014 RAM 1500 EcoDiesel Sold Cars: 2012 BMW M3 || 2013 Subaru BRZ || 2012 Porsche Cayman R || 2009 Chevrolet Z06 || 2009 BMW M3 || 2004 BMW M3 || 2004 Nissan 350Z |
05-21-2013, 11:55 AM | #16 |
Drives: FRS
my goal is 400 didnt say i would reach it but i would love to hahhaha
05-21-2013, 11:55 AM | #17 |
NASA SpecE30 Racer
When tuning a boosted car there are the two different mindsets I mentioned. The fact is that with our 12.5:1 compression and 93 octane, we are severly knock limited and the only question is how does your tuner choose to approach that limit either through more boost or more timing.
- King Tut
05-21-2013, 11:59 AM | #18 |
Drives: FRS
but dont you think with the compression we have more boost is not really the BEST solution it works fine as your driving with 14psi but lets say i push 10 and make what you make what you think would be the safer option ?
05-21-2013, 12:07 PM | #19 | |
Drives: 2013 White Out FR-S
The Following 2 Users Say Thank You to FA20Club.com For This Useful Post: | PrDarkKnight (05-21-2013), Pure Automotive (05-21-2013) |
05-21-2013, 12:16 PM | #20 |
LOL, well naturally i would be running more timing than your 14 psi map but nowhere near your guesstimate. my timing curve is still pretty conservative infact its almost identical to my vortech map. the issue is i can yield more power from a multitude of variables. first my turbo choice moves my power band in a different direction from yours. when tip-in occurs my setup requires less accell pump increases because my turbo didnt ramp up as fast. the timing map can be progressively ramped back in for a smaller turbo whereas retarded a bit more through the band for the larger turbo since it doesnt take as much energy to keep making power through the curve. if i were @14psi with my setup honestly i would be running even less timing than what you would be at with your GT28. for a gt28 to pump out 20+ hp/psi on low boost would be almost unheard of even with the rpm range and compression of this motor.
The Following 2 Users Say Thank You to FA20Club.com For This Useful Post: | King Tut (05-21-2013), PrDarkKnight (05-21-2013) |
05-21-2013, 01:13 PM | #21 | |
NASA SpecE30 Racer
- King Tut
05-21-2013, 01:17 PM | #22 | |
I'll keep an eye out as I don't baby my car at all. I drive her nuts off, and also plan on going to the track quite often... How do you get in the "ecutek and haltech" networks? Is that a secret club for ecutek dealers? |
The Following User Says Thank You to Sonolin For This Useful Post: | Strife26 (11-26-2017) |
05-21-2013, 01:17 PM | #23 | |
Drives: FRS
05-21-2013, 01:23 PM | #24 |
NASA SpecE30 Racer
I think you have to be Australian because Haltech is an Australian standalone ECU company that competes with EcuTek. I have ZERO fear of the motor not lasting on 300 whp by the way.
- King Tut
05-21-2013, 01:33 PM | #25 | ||
Mr. Cranky Pants
Drives: 2013 Argento FR-S
This thread, several posters in it, hell the entire internet make it sound as if there's a magic boost threshold for any given engine where if you stay below that line, you're safe. It's not that easy. Ever. For any engine. Even for two identical engines made on the same day in the same factory. Quote:
05-21-2013, 03:09 PM | #26 |
Drives: waiting on a 2021...
So what kind of timing(in terms of degrees BTDC) are these cars running boosted versus N/A? I always thought you run the least amount of total timing possible to insure a complete burn. Too much timing on an efficient chamber design actually works against you. From what I've read, you want maximum cylinder pressure to occur ~6-10 degrees ATDC.
2016 4Runner Tail edition
2020 Camry 2020 RAV4 2013 Chevy 3500 4x4 Duramax 1999 Ford F250 Powerstroke, the tow rig 1969 Mustang, the fast car....(: |
05-21-2013, 03:39 PM | #27 |
Cool Stuff
Drives: Cool Car
stock for stocks, 11 psi at 15.5 degrees.
Do i fear for my motor ? no, i keep up the maintenance and it keeps me happy. |
The Following User Says Thank You to killerkid08 For This Useful Post: | Strife26 (12-08-2017) |
05-21-2013, 04:24 PM | #28 | |
Reverse Burnouts
Drives: 2013 Argento FRS
the basics... Your engine can only flow a certain volume of air. Changing the density doesn't change the volume of air entering the engine. The density that the air is at, decreases, if you shrink the tubing along the path and increases visa versa. Turbine spool rate: faster is always better depending on the flow rate of that turbo and its threshold. high spool rates signify the efficiency of the turbo. aka needs less exhaust pressure to spool. this in turns lets air leave the engine faster. This decreases the amount of energy the engine has to exert to remove the ignited air and fuel out of the engine. There are 3 places where energy is used in a natturally asparated combustion engine. 1 to turn the drive shaft 2 to evacuate exhaust gasses 3 pulling in air this is where turbos help/hurt... 1 air is now being pushed into the combustion chamber 2 more air is available for combustion but 3 they create more internal heat = loss in power 4 the turbine on the exhaust side creates lots of back pressure and when the air heats up from combustion, the volume of which the air wants to occupy increases dramatically making lots of pressure with the turbo holding it back like a damn behind the turbo. this is why a fast spooling turbo is recommended. air moves out faster and the engine has to do less work to achieve it. gtx3076R is great turbo for this. Quick spool, high flow rate, and a high threshold Now that we have the basics done. reliability 1. measure the air density and flow rate as close to the intake valves as possible, preferably after the throttle body. 2 find a turbo that flows the best vs the amount of hp you want to achieve too small and your engine/turbo will have to work harder, too big and you will increase lag and back pressure lower in the rpm band the gtx3076R or comparable turbo is a great mid point, spools fast with lots of room to grow if you need it and you can rev high with it without running our of breath. also with less back pressure you have less heat and your turbo will run cooler during daily driving doing less damage to itself and all components around it. 3 larger intake inlet before the turbo the turbo will be able to flow more with less work = less heat/faster spool times (this is why the PTuning kit works so well with low boost, notice how large that intake pipe is!) 4 a high flow/efficient intercooler. This allows the air to move slower through the intercooler allowing more time for the compressed air to cool. and remember above picture, the larger path compressed air has to move through the denser it is = more power 5 think about getting a larger throttle body as an upgrade at some point to relieve the bottle neck effect of air that reduces air density but not too large that it hurts the flow rate a few mm larger can yield some pretty good gains on a turbo set up. also with a larger opening the air is cooler by the awesome means of physics. when you accelerate air through a confined space it heats up. 6 watch those air fuel ratios, keep them conservative. with the set up above you should be able to make the same power as someone with a less efficient kit that is running more boost and timing and be more reliable than them 7 Turbo placement, is the turbo placed where it can do the least amount of damage as it radiates heat, and is it near a place that has a flow of air to cool it? 8 Oil coolers for the engine/turbo oil and transimission 9 use better oils that have the correct additives for your application and last longer. I personally like 15k mile extended performance M1, track days i like motul. more reliability! 1 have custom pistons made with the same tolerances in mind as the factory (pretty strict) that are made specifically for your engine's measurements. 2 have water sprayers installed to cool your intercooler for hotter days. (just like STI's ) 3 Titanium valves, springs, and retainers (more heat resistant than stock, but from what I've read the stock valve train is pretty good as is) 4 proper fueling: make sure your running equipment that can exceed what you need so you aren't running your pumps at 100% at redline wearing them out. I've always gone by the rule that the pumps/injectors should be around 60%-75% of their threshold at fuel cut 5 change oil more frequently, like every 2k - 3k miles.( for dd's that never see track time just a bunch of hooning) even more reliability! (lots more money) 1 get a baffled pan and a dry sump to cure oil starvation 2 sump system in the fuel tank so you don't have fuel starvation issues, if you lean out you could blow up your engine! (accelerated performance is developing a kit!) 3 if you want more power, run e85 and get a flex fuel kit in case you get shit E85 like we do in Texas that not always E85 plus you can just pour 93 when ever you don't feel like running E85 and not have to switch any maps there's more you can do and there's a million different factors i could go over but i don't feel like typing any more I hope this clears some things up so reliably isn't measured in whp its measured in tq, intake and exhaust temperatures, how efficient the engine flows from the intake to exhaust tips, timing, and are all parts up to the job? if you build your engine, make it as efficient as possible, and keep up with standard maintenance. I don't see why the engine couldn't last for over 100k miles of daily driving at 400 whp and 200k miles at 280 whp. of course track hours are completely different but it should reflect in the same way. and to answer the OP question as long as the kit is efficient, sensors are in their correct place for accurate readings, running a conservative tune and low boost (under 9 psi) your turbo frs/brz/gt86 should last you 100k miles my last car i modified it to run up to a 9800 rpm redline, beat it for 74k miles putting a grand total of 152k miles on a 12 year old car. and never once had an issue. i raced to work on a bone cold engine ever day during the winter and bounced off that almost 10k fuel cut every day. if you want to turbo. do it right the first time and you'll never regret it. I'm not turbo yet... why? the parts i want to build my kit with don't exist yet. until the fuel fix with accelerated performance is finished i wont even consider doing my build. good thing flex fuel is though! thanks visconti! Like for example there's a silver frs in north texas that was turbo'd, it was build, tuned by the right people. and because a catalytic converter wasn't up to the task, it melted and shit itself into the turbo. 1 small part like that that could have been replaced with a much better part and that failure would have never happened. EDIT: also a water-meth injection kit can also be added, these kits clean the inside of the engine's combustion chamber. ive seen photos of cars that ran water/meth for 70k miles and the insides of them look brand new
2000 Carbon Blue Toyota Celica GTS 152000 miles (wont forget you) 2013 Argento Scion FR-S 2011 Infiniti G37x Last edited by carbonBLUE; 05-21-2013 at 06:04 PM. |
The Following 6 Users Say Thank You to carbonBLUE For This Useful Post: | Brayden_23 (12-06-2017), cmss2000 (05-21-2013), killerkid08 (05-22-2013), Sonolin (05-21-2013), Strife26 (12-08-2017), Whitigir (05-21-2013) |
Similar Threads | ||||
How much spacer is safe on stock rear studs? | wparsons | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 22 | 12-27-2014 01:49 AM |
Amount of Brake Fluid.... | THEmailman | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 3 | 04-13-2013 11:46 PM |
2JZ engine swap on low boost - low 11's run | HighLife | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 10 | 03-07-2013 05:55 PM |
FS Stock Engine/Trans/Drivetrain | ecda | Engine, Exhaust, Bolt-Ons | 1 | 02-13-2013 05:04 PM |
What socket size and what torque amount for stock alloy wheels? | Takeshi | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 11-01-2012 10:25 PM |
