DIY (Do-It-Yourself) Guides For all DIYs. |
#15 | |
Drives: Awesome
The Following User Says Thank You to Retro86 For This Useful Post: | FRSFirestorm (04-08-2013) |
#16 |
P i N O Y P R i D E
Drives: 86 C7P MT
so this set up, can only turn the fogs on, with parking lights or headlights are on?
#17 |
Red is Fastest
Drives: 13 FRS 6MT Firestorm
#18 |
Drives: 10 Series #845
If i may ask, where did you purchase your fog lights at? ( Light, bezzel, etc..)
What Vtec?
| My build thread : http://www.ft86club.com/forums/showthread.php?t=48493 | |
#19 |
Drives: Scion Fr-s
#20 |
give us this day
Drives: AE86 - FRS
hmm i hope this is not a stupid question but where did you buy the stalk with the fog light option? thanks in advance
#21 | ||
Red is Fastest
Toward the end of the stalk install link I posted the part number is posted. I don't remember it or I'd post it. I just googled that part number and several parts places showed up. I just picked the cheapest one and ordered it. It was a dealership with online parts presence. |
The Following User Says Thank You to FRSFirestorm For This Useful Post: | imravenit (04-09-2013) |
#22 |
give us this day
Drives: AE86 - FRS
is it this one?
http://www.toyotapartszone.com/oem/t...140-02670.html subaru has it too? $60? http://subarupartsforyou.com/cp_part...p?partid=23294
#23 | |
Red is Fastest
#24 | |
give us this day
Drives: AE86 - FRS
so you went with the tundra stalk correct?
so with this approach theres no meed to tap into the bcm c3 anymore correct?
#25 | |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
#26 | |
Drives: Awesome
#27 |
Drives: Awesome
yup! just need a female connector pin or make shift connection anyway you like runnin through the connector.
The Following User Says Thank You to Retro86 For This Useful Post: | imravenit (04-09-2013) |
#28 | |
give us this day
Drives: AE86 - FRS
its coming a lil bit all together now .. so if i understand this correctly.. once ive installed the brz stalk no wiring needed basically just switch stalks.. locate the connector for the signal lights for both driver and passenger tap in to the red/white wire vice versa and then find a ground for fog lights .. flick the saitch and it should work? on the side note i thought the brz stalk has the auto headlights feature?
FRS fogs using BRZ stalk | Sco2355 | DIY (Do-It-Yourself) Guides | 378 | 12-16-2018 05:17 AM |
Factory shift light/chime | Wonderbar | Electronics | Audio | NAV | Infotainment | 29 | 04-05-2013 03:30 PM |
Manual shifter stalk thread dimensions for knobs | bcj | Scion FR-S / Toyota 86 GT86 General Forum | 1 | 03-19-2013 06:42 AM |
SEAT BELT STALK COVERS | cslntuee | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 03-01-2013 12:57 PM |
FRS fogs using BRZ stalk | Sco2355 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 02-18-2013 01:51 PM |
