Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
04-05-2013, 08:16 PM | #15 | |
Add lightness!
Drives: 17' WRX
04-05-2013, 08:33 PM | #16 |
Site Moderator
Drives: Stuff
I can't recall. They were cast but not konig, or xxr, etc.
-Dave
Track cars: 2013 Scion FRS, 1998 Acura Integra Type-R, 1993 Honda Civic Hatchback DD: 2005 Acura TSX Tow: 2022 F-450 Toys: 2001 Chevrolet Corvette Z06, 1993 Toyota MR2 Turbo, 1994 Toyota MR2 Turbo, 1991 Mitsubishi Galant VR-4 Parts: 2015 Subaru BRZ Limited, 2005 Acura TSX Projects: 2013 Subaru BRZ Limited track car build FS: 2004 GMC Sierra 2500 LT CCSB 8.1/Allison with 99k miles |
04-05-2013, 08:39 PM | #17 |
The rigidity of the wheel takes more precedence over weight. We're talking at most 2lbs extra for some wheels. Decreasing weight while maintaining strength/rigidity means wheels will cost more just to spend more effort finding every method to shed weight without reducing that epic quality we all seek. Good wheels means more R&D and effort to optimize these factors (Volks & BBS).
Under cornering loads, a stronger wheel (usually slightly heavier) is faster than a lighter wheel. We also see a lot less bent wheels from track and street use using those "heavier" wheels. Of course, this is from an actual use and abuse perspective. |
The Following User Says Thank You to CSG David For This Useful Post: | nikitopo (12-30-2014) |
04-05-2013, 08:47 PM | #18 |
I understand that stronger is better for obvious reasons but most "lightweight" wheels forged or not are under 20lbs. So when you guys say that tests have shown that heavier provides a faster time, are they over 20lbs? I guess what I'm trying to say is when is heavy too heavy?
PS- I've had a few brewskies so if I don't make sense don't mind me! Lol |
04-05-2013, 08:57 PM | #19 |
Also I've noticed that 90% of racing teams use lightweight wheels with success so are they all wrong? Honest question since I don't have much experience with road racing/auto-x/time attack, etc.
04-05-2013, 09:02 PM | #20 | |
They want light but also cheap because they have many sets of wheels for backup and replacements. They bend a lot of wheels and trash a lot of wheels as well. We're not saying uber light wheels are super weak, they are actually sufficient and respectable, however justifying that it has better acceleration and will win you close races because you saved 1lb per corner, well, that's harder to say. Also, the track surface is relatively smooth vs. public roads. |
The Following 2 Users Say Thank You to CSG David For This Useful Post: | PRORICAN (04-05-2013), racecaresuaceb (04-07-2013) |
04-05-2013, 09:06 PM | #21 | |
04-05-2013, 09:08 PM | #22 | |
Drives: Slowly
And what materials. There's no comparison between a forged A6061-T66 wheel and a cast AC4C-T6 when it comes to rigidity, but people generally don't appreciate what they can't see. For example, a 25lb Work may be more rigid than a 20lb Enkei, while a 15lb Volk could be more rigid than both. I'm not bagging any brand (as those are all good), just giving an example and obviously ignoring price. I know you know this, but I'm making the point that material and manufacturing process is at least as important as design, unless you are saying that you'll only consider cheap cast wheels. |
The Following User Says Thank You to coyote For This Useful Post: | Gilwith1l (02-20-2014) |
04-05-2013, 09:10 PM | #23 | |
Drives: Slowly
Perhaps you stole it from me?!?! |
04-05-2013, 10:01 PM | #24 | |
Site Moderator
Drives: Stuff
PRORICAN: Some race teams use heavy wheels, and some use very light very high end and very strong wheels that don't apply the majority. Others use cheap and light due to replacement costs. That all depends on the goals of the team in question. We run a large selection of OEM wheels on our race car because we had them laying around, soon they will be replaced with cheap and light wheels that are 15x8s to run 225s. We expect to break some over time, and we expect a lot of random damage. We aren't willing to pay for high end wheels tho :P
-Dave
04-05-2013, 10:12 PM | #25 |
Drives: Perrin/VORTECH Supercharger TestBRZ
I have 17's that weigh 15.5 lbs(blue HLT OZ for track made in italy) and 17s that weigh 22 lbs(silver Sparco by OZ made in ROC)
I can totally tell them apart if you had me drive them blindfolded. In this case the heavier wheel is stronger for potholes, and drawing less attention than I may want day to day |
04-06-2013, 06:38 AM | #26 |
Drives: '23 BRZ
Ha, could be! I took down my post after I saw that exact picture as the first image on a google search. I musta just remembered scaling it down to a max size, not cropping it. I've been using it for nigh on ten years, so you have precedent. Anyway, it funny to be reading a post thinking it was mine. "When did I say THAT?!"
04-06-2013, 06:54 AM | #27 | |
My FR-S has 5 gears
Drives: FRS/280z/Tundra
Omar GC
2JZ - 6870 - stock block - 1000whp? Instagram: 2jzus |
04-06-2013, 07:15 AM | #28 | ||
Drives: '23 BRZ
Forged wheels (6061-t6) are not stiffer than cast wheels of the same design! In fact if you take advantage of the forged material's higher strength properties to take material/wall thickness out, it will be *less* stiff vs. the thicker/heavier similar-design cast wheel. I've heard references made by reputable sources about the advantages of "stiffer" wheels, but in my experience designing and lightweighting aluminum wheel designs, even the lightest/most-flexible viable wheel design is so much stiffer than the tire, that I'd be surprised to find that it should matter much. The TIRE is moving around so much more, on the order of 10x or more deflection under load vs. the wheel, that its compliance dominates the wheel/tire stiffness. I did see a quote from Enkei regarding the weight of the PF01 (I have these on the RX-7!). It came out disappointingly heavy relative to the RPF1 (it was supposed to be lighter), but I recall Enkei noted that it was "faster" due to being more stiff. Maybe it really is, but IMO this is possibly a story for marketing. If they did a bunch of laps on both wheels and the faster laps happened to be with the PF01 (entirely possible as the weight penalty isn't all that big), they could semi-legitimately make the case that "heavier but stiffer" was faster. But of course they are first in the business of selling wheels! If you make a wheel twice as stiff, the overall stiffness of the wheel/tire is only going to go up by on the order of ~5%. So the payoff in overall stiffness is quite small relative to big changes in wheel stiffness. 2x stiffer tires, and overall stiffness goes up 90%. So, a stiffer TIRE, you will most definitely feel the difference. With a stiffer wheel, I seriously doubt you could feel it and any difference in lap times should, I think, be buried beneath other factors (changing track/weather/tire conditions, driver inconsistency). Quote:
The Following User Says Thank You to ZDan For This Useful Post: | Trettiosjuan (12-30-2014) |
Similar Threads | ||||
BUDDY CLUB Lightweight Racing Wheels - JDM, lightweight, low pricetag | 18x8.5" | GuerillaRacing | Wheels and Tires | 116 | 01-20-2015 06:32 PM |
>> TSW Nurburgring | Panorama | Interlagos lightweight forged wheels - ready to ship | speed depot | Wheels and Tires | 24 | 11-26-2012 08:25 AM |
need suggestions for lightweight forged 17x7 wheels | hankster | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 34 | 11-15-2012 01:40 PM |
Recommendation for lightweight wheels without breaking the bank | ayau | Tracking / Autocross / HPDE / Drifting | 6 | 11-08-2012 02:23 PM |
