DIY (Do-It-Yourself) Guides For all DIYs. |
12-05-2013, 02:46 PM | #16 |
Serial Cone Killer
Drives: '14 BRZ - WRB Premium 6MT
Is it necessary to jack the car up to remove the strut tower bracing? I would assume that that at rest there is some tension placed on the brace, making jacking up a safer situation (for both car and person working on it). I am just curious though. Also, if there is not a DIY for intalling on an auto, i'll do a write up once I get my car back.
12-05-2013, 08:00 PM | #17 |
Can the brace be installed without removing the tower to firewall brace? I assume it was only removed for better pictures?
12-05-2013, 08:25 PM | #18 | |
Drives: BRZ Limited WRB MT
That said, removing it, (just a couple of bolts), gives you a little bit more room to install the brace... So no, no need to remove it if you don't want to. |
The Following User Says Thank You to modena For This Useful Post: | amram (03-28-2014) |
12-05-2013, 08:37 PM | #19 |
Sideways and smiling!
Drives: First 86 FRS 5/8/2012 (second US)
It was super easy for me to install with out removing the brace as well. All I needed was an extension for my rachet. Takes maybe 5min to install.
12-06-2013, 10:30 PM | #21 | |
Matt Beenen Engineering |
12-06-2013, 10:54 PM | #22 |
03-28-2014, 04:40 PM | #23 |
Drives: 2013 FR-S AT
Great write-up as always F1point4! Thank You!
"That's why I like the GT86 so much..... It's a car designed for one thing only: fun." - Jeremy Clarkson
03-29-2014, 05:11 AM | #24 |
Drives: Subaru BRZ
Does the MSB make a difference in daily driving? Or is it only noticeable in high performance situations?
03-29-2014, 07:47 AM | #25 |
Drives: (formerly) 2013 Raven FR-S
06-20-2014, 01:23 PM | #26 |
Drives: 2014 BRZ Ltd - DGM
Does the strut tower and/or firewall not flex enough under hard driving or over bumps/a pothole/or driveway curb/speed bump/etc to cause damage at some point by having an object pushing on the firewall from teh strut tower?
I'm throwing it out there because I don't know if strut tower doesn't move at all, ever, or if it does.
2014 BRZ Ltd. - DGM
E30 318is trackday funday car E46 323ci vert |
The Following User Says Thank You to sluflyer06 For This Useful Post: | Tristor (02-22-2018) |
06-20-2014, 04:24 PM | #27 | |
Drives: 2013 BRZ Limited
2013 BRZ Limited 6MT
2014 Ram 1500 Quad Cab Black Ram - 8 speed with 3.21 gears 1994 Honda VFR750 - Two brothers 4-1 left side exit exhaust 1993 Honda CB750 Nighthawk |
The Following User Says Thank You to CoupedUpSubie For This Useful Post: | Tristor (02-22-2018) |
05-28-2018, 03:35 PM | #28 |
Drives: 2015 Asphalt FR-S
Does anyone know what the bracket for the AT wire harness is called? I lost it and need to get another.
-EDIT- Got it I think! Part SU003-02205 Bracket for ATM Last edited by V_86; 05-29-2018 at 01:27 PM. |
Tags |
brakes, diy, grimmspeed, master cylinder brace, stopper |
Similar Threads | ||||
Cusco FSB with master cylinder brace - A heads up for AT owners | CircuitJerk | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 33 | 03-15-2014 07:25 AM |
Master Cylinder Brace Development - Any Interest? | GrimmSpeed | Brakes, Suspension, Chassis | 411 | 05-14-2013 05:04 PM |
