Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
07-30-2023, 12:33 PM | #15 | |
Drives: 2018 BRZ
I was worried about this which is why I was initially looking at 17x9s. But none so far. I do still have the stock front swaybar/endlinks if that matters.
If anything, I noticed there are two occasions where I seem to encounter rubbing: 1. if I am turning or cornering at slow or moderate speed during drastic elevation changes, it seems like the tire is rubbing against the inside fender liners. 2. if I load up the fronts to use weight transfer to rotate the car, the tire seems to rub against the actual fender. This sounds more like a plastic creaking noise if that makes sense lol. I am assuming for #2, more camber will suffice. Not sure about #1 though. I'm gonna see how it is after I get the alignment and corner balancing done. Currently my thoughts are: -3.5 front camber 0 toe -2.25 rear camber 1/16" total toe in And as for corner balancing, the shop will just adjust the height as necessary? Never done this before so I am not sure what to expect Quote:
07-30-2023, 03:12 PM | #16 |
Drives: Subaru BRZ
If you are not tracking the car, I would not have it corner balanced, waste of money.
The Following User Says Thank You to Code Monkey For This Useful Post: | ZDan (07-30-2023) |
07-30-2023, 03:24 PM | #17 |
Drives: '23 BRZ
You might have them check corner weights. IMO if they're within say 30 lb. I wouldn't worry about it. My car was near dead-nuts on for cross-weights when coilovers were installed without any adjustment required to balance.
The Following User Says Thank You to ZDan For This Useful Post: | Code Monkey (07-30-2023) |
07-30-2023, 04:14 PM | #18 | |
Drives: 2018 BRZ
But yea..this is mostly a street car (averaging 4-5 track weekends a year) so this may be an overkill. Oooh, good point. I wonder if the shop will let me just check without charging for a full on corner balance lol. |
The Following User Says Thank You to ihavefat For This Useful Post: | Code Monkey (07-30-2023) |
08-01-2023, 02:59 PM | #19 |
Drives: 2018 BRZ
A bit of a plot twist. It seems like my front wheels were super close to the front (I’m guessing a lot of positive caster?), which may have prevented the endlinks from hitting it even initially set height when I installed the coilovers. Had to take the endlinks off during the alignment and have shorter ones on the way. This is what it looks like currently:
https://imgur.com/a/k7aGqvG Got some wheel gap currently but I have no rubbing whatsoever regardless of what I’m doing. Don’t really hate the look either lol |
08-01-2023, 03:31 PM | #20 | |
FT86Club Official Vendor
Drives: Launch-Year Whiteout FR-S
- Matt
12-24-2023, 02:06 PM | #21 | |
Sent from my Pixel 6 using Tapatalk
2013 Series 10 FRS #553
Similar Threads | ||||
949 Racing 6UL 17x9 +48 Fitment | Scubadriver | BRZ Second-Gen (2022+) -- General Topics | 31 | 05-23-2022 01:14 PM |
Fitment Issues: 17x9+35 wheels with 245/40 tires | Nurnburger | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 30 | 09-02-2018 08:52 AM |
(HELP) 17x9 RPF1 meaty fitment | Benschneider06 | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 32 | 02-25-2018 10:45 PM |
17x9.5 +15 fitment | Matty-T | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 3 | 05-02-2015 06:26 AM |
17x9 6UL - FT86 fitment available soon | Guillaume | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 43 | 02-17-2015 11:54 AM |
