Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
08-16-2012, 09:02 AM | #15 |
Drives: Toyota 86
wow that is impressive, (im an MT noob, been driving an auto most my life until i got my 86) but does using this feature potentially damage the clutch/gearbox?
does it wear the clutch out quicker? |
08-16-2012, 09:07 AM | #16 | |
He was short shifting in the video so he was actually reving up between shifts which would not feel good to do on the road. Typically you set it at 5000 this way when you shift at redline it is seamless between gears and you wont get TOO much of a jerk. Someone correct me if i am wrong but this is how it worked in my11 sti |
The Following 2 Users Say Thank You to fenton For This Useful Post: | Rawdog (08-20-2012), Spaceywilly (08-16-2012) |
08-16-2012, 09:09 AM | #17 | |
If it is synced up perfect and you get really use to it the damage will be much less but you are still trying to connect something that is loaded and spinning at a higher rpm to something that is freely spinning at a lower rpm. |
08-16-2012, 09:23 AM | #18 |
One more thing....the reason most do this in a boosted application is the ability to maintain some amount of boost between gears so you don't have to spool out of vacuum every shift.
My sti would hold about 9psi between shifts saving me about half a second of spool at wot shifts Sent from my Galaxy Nexus using Tapatalk 2 |
08-16-2012, 09:35 AM | #19 | |
The secondary rev limiter is 100rpms higher then the point you push the clutch in. So let's say you no lift @ 4000 rpms, no lift activates at 4100. Now let's say you no lift @ 3500, no lift activates at 3600.. In the world of rally the static 5500rpm no lift shift is junk. |
The Following User Says Thank You to Visconti For This Useful Post: | DriftEightSix (08-16-2012) |
08-16-2012, 09:40 AM | #21 |
This no lift shift also adjusts timing and fueling...
That's why it's called RaceRom Flat-foot! What do you get when you spell RaceRom backwards... Anyone anyone ? |
08-16-2012, 09:46 AM | #22 | |
Engine spinning at 7600 and trying to engage a gear at 5000 doesn't sound like a fun time. |
08-16-2012, 09:50 AM | #23 | |
That could be a problem. I'll talk to ecutek about this and most likely have a additional table added so above let's say 7000 rpm it flatfoots an adjustable amount of rpm below instead of above. Thanks for pointing that out !! |
08-16-2012, 09:55 AM | #24 |
Drives: 2009 Cobalt SS 373 FWHP 431 Lb-Ft
I like how this lets you flat foot at pretty much any rpm. My cobalt only lets me no lift when near red line or I risk getting knocks =/
08-16-2012, 09:55 AM | #25 | |
08-16-2012, 09:56 AM | #26 | |
08-16-2012, 09:57 AM | #27 |
Same with the STI. Had to shift it at redline as there was only one RPM possible in COBB FFS. I like this idea better but seeing how much that car is moving and jerking on the dyno it would be interesting to see it on the road.
08-16-2012, 11:19 AM | #28 |
Drives: Scion FantasticRoad-Sex
Jelly. Like real jelly...and just... jelly.
Similar Threads | ||||
Foot Well Mood Lighting | BigJyoungblood | Cosmetic Modification (Interior/Exterior/Lighting) | 189 | 06-01-2017 11:21 AM |
EcuTek RaceROM Launch Control | just86 | Software Tuning | 47 | 03-14-2014 02:55 PM |
shifting and down shifting feel | Lowellrenzo | Scion FR-S / Toyota 86 GT86 General Forum | 23 | 07-08-2012 05:09 PM |
Stupid girl 2 foot driving | GenkiElite | Off-Topic Lounge [WARNING: NO POLITICS] | 31 | 07-23-2011 08:33 PM |
How much do you like heel-toeing or left foot braking? | USMCMike | Other Vehicles & General Automotive Discussions | 20 | 01-15-2010 04:20 PM |
