Forced Induction Turbo, Supercharger, Methanol, Nitrous |
04-14-2021, 11:46 AM | #15 | |
Drives: 2017 BRZ w/Performance Package
04-14-2021, 11:50 AM | #17 |
04-14-2021, 12:32 PM | #18 | |
Moutain Runner
I'd love to replace it, but $1000 for parts+labor just isn't in the cards right now. |
04-14-2021, 10:10 PM | #19 | |
Drives: 2017 Toyota 86
OTOH why not sell the header to recoup some additional costs from bumping up to a higher quality kit? |
04-15-2021, 08:23 AM | #20 |
AutoX-10/10ths every run
I'd swap these:
•Mishimoto Radiator •Mishimoto Oil Cooler With this: https://www.counterspacegarage.com/j...gt86-scion-frs
[ Delicioustuning | Counterspacegarage | RS-R USA | Cusco USA | SPL Parts | ACE Header | Stark Performance | Infinite Motion | Ciro Racing | Build thread:Here ] [ GR Corolla Core in White w/LSDs on wish list ] |
04-15-2021, 07:19 PM | #21 | |
Something something
Drives: 2017 BRZ (Vortech), 1993 R32 GT-R
But, do you really need the PCV valve if you have a Check Valve already on a catch can? This is the one thing I'm still not sure about to this day.
Daily Driver - 2017 Subaru BRZ (Vortech Supercharged) | Weekend Warrior - 1993 Nissan Skyline GT-R |
04-16-2021, 12:54 AM | #22 |
Drives: brz 2017 hksv2
you shouldn't need it, but you d better have it anyway
cheap and effective |
04-17-2021, 07:24 PM | #23 | |
Poop train conductor
Drives: 2015 BRZ Ice Silver Metallic
For a daily driver clutch they recommended an Exedy stage 1, but that was backordered so I ended up with a Competition stage 2. They also recommended the Verus clutch fork and pivot. The stock fork is prone to failure, especially with stiffer aftermarket pressure plates. The parts are around $200 and very little extra labor to install during a clutch job. Worth it for reliability in my book. As for Motul; It's a noticeable improvement. I doubt you need to change the gear oil early because of the turbo, but I highly recommend you give Motul a try when you change it. |
The Following User Says Thank You to MR2Dave For This Useful Post: | JesseG (04-27-2021) |
04-21-2021, 12:33 PM | #24 | |
Road-hole
Drives: 2013 Whiteout FR-S
no..
People love to say how weak these engines are, yet there have been as many or more rod failures on stock power levels as on boost which SHOULD lead a logical mind to the probability that it was a quality control issue rather than a generally weak rod issue. Especially considering that many have gotten over 400 on stock blocks without issues. The problem with a quality control issue though is that it's a crap shoot when adding power. Although if you were unlucky enough to get the shitty rods, it's just as likely that running it stock will have the same end result, so whatever. I would love to see how much power can be gotten with just a rod upgrade and some ring gap. I would bet over 500 reliably. I have my first engine that, (on stock power levels), spun a rod bearing, which I eventually plan on doing the above to to find out what it will handle. Jaden |
The Following User Says Thank You to Jaden For This Useful Post: | JesseG (04-27-2021) |
04-23-2021, 11:34 AM | #25 |
You could probably save some money on the radiator with a CSF unit. I've got one on my car and it keeps great temperatures in traffic and on the track. Never even come close to overheating whereas my car overheated here in the south from the factory. They actually produce the Jackson Racing oil cooling radiator as well.
https://csfrace.com/product/subaru-racing-radiators/ Last edited by B T; 04-23-2021 at 11:35 AM. Reason: added details |
04-23-2021, 05:25 PM | #26 | |
The Following User Says Thank You to Leviticus Ezra For This Useful Post: | whataboutbob (04-23-2021) |
04-23-2021, 05:29 PM | #27 |
With the way the Radium kit actually ended up being fitted, it had I believe 3/8 hose running into the PCV valve fitted to the manifold which is a 1/2 fitting, so the PCV valve is still used because it converts from a the 1/2 to a 3/8 on the other end if that makes sense? The instructions for the dual catch cans were extremely unclear. I ended up needing to run to the auto parts store for more hose
04-23-2021, 05:38 PM | #28 | |
Tags |
boost, forced induction, help me, question, tips |
Similar Threads | ||||
Boosting 1st gens | frsqc | Forced Induction | 44 | 04-06-2016 01:40 AM |
Additional considerations when boosting | 86 South Africa | Forced Induction | 10 | 12-28-2015 06:54 PM |
Boosting Auto 13' Frs | SPAGNOLA | Scion FR-S / Toyota 86 GT86 General Forum | 9 | 04-06-2015 11:19 AM |
Boosting my FR-S | Team86 | Forced Induction | 48 | 11-10-2014 06:24 PM |
General boosting question | Pneub | Forced Induction | 8 | 10-30-2013 02:36 AM |
