DIY (Do-It-Yourself) Guides For all DIYs. |
06-07-2019, 02:32 AM | #15 |
chicken tonight
Enjoy, guys. It's pure win.
06-07-2019, 11:27 AM | #16 |
Drives: 2016 White Pearl BRZ Premium
Sorry in advance for the thread hi-jack ?
Hello @Ultramaroon ! -
After all the discussion re: the South American guy's efforts to improve oil pressure / survivability, and then seeing your oil cooler sandwich configuration in the transmission strap support thread you started, I got to thinking about the location where I have my oil temp and pressure senders. Perhaps there are better spots? Coming off the sandwich plate - I *think(!!) - Keyword* I have pressure on the line from the cooler, and the temp on the line to the cooler. So I know if the pressure drops and also know the oil temp before it gets to the cooler. Your setup in the pics looks like you're obviously monitoring the oil temp and pressure at a different location. Thoughts / recommendations on better locations that what I am currently using? |
06-07-2019, 12:51 PM | #17 | |
chicken tonight
I think it's a toss-up for temp. Either the cooler is doing its job or it's blocked. The pressure tap should be downstream of the filter. I can see a slight drop as I clock over 5 Kmi on my oil and it jumps back up if I change only the filter. That leaves either the factory pressure tap or the one at the front of the main gallery. I picked the main just for convenience but recently, as you also read, have learned that it is a better location to monitor pressure delta as a function of temp. Does it really matter? Meh, probably not.
The Following 2 Users Say Thank You to Ultramaroon For This Useful Post: | Joesurf79 (06-07-2019), soundman98 (12-04-2022) |
06-07-2019, 02:40 PM | #18 | |
The one at the front of the main gallery = the plug here, below and to the driver side of the throttle body right? |
06-07-2019, 04:17 PM | #19 |
chicken tonight
Yup. Get a really good accurate socket head driver. That plug is unbelievably tight.
06-07-2019, 04:32 PM | #20 |
Dude it is! I have removed it once already..I had an accusump plumbed in there...which was totally not needed for my track speed at that time (more to have a fab/tinker project).
06-07-2019, 05:16 PM | #21 |
chicken tonight
Right?! Stung my hand when it snapped loose.
The Following User Says Thank You to Ultramaroon For This Useful Post: | soundman98 (12-04-2022) |
10-12-2021, 02:15 PM | #22 |
Drives: '13 BRZ TLM Spec
@Dave-ROR, try this and let me know how it works.
2013 BRZ Premium 6MT - Track Car, 2020 GMC Canyon Denali Duramax - Tow Vehicle, 2021 Forester Sport - Wife's Daily, 2016 Crosstrek - Daughter's Ride and always buying random flips...
12-03-2022, 09:19 AM | #23 |
The Dictater
Drives: '13 Red Scion FRS
Necro!
Just wanted to note that this isn't going to work with all ratchet straps. the ratchet can line up with the support bar which doesn't really allow the strap to turn the corner where I want it to. By my estimate, the ratchet side strap needs to be at least 18 inches long to clear the brace. Alternatively, the ratchet+strap length can be less than 10 inches to fit the ratchet between the fuel rail plate and the support bar on the right side. It also helps if your straps have the same hook type as OP. Edit: So of course I had a thought 5 minutes after writing this. If the ratchet side straps are too short/long, you can daisy chain them. It's more of a pita to do it this way I think.
If a picture is worth a thousand words, a model is worth ten thousand pictures.
Also: "Build Thread" Last edited by Spuds; 12-03-2022 at 09:33 AM. |
The Following 3 Users Say Thank You to Spuds For This Useful Post: |
12-03-2022, 02:22 PM | #24 |
chicken tonight
Ha! I never considered how lucky I was to have the right length of ratchet-side strap.
It's really hard to beat a good rope. I should update with a tutorial on tying a bowline and trucker's hitch. ...maybe.
The Following 4 Users Say Thank You to Ultramaroon For This Useful Post: |
04-17-2023, 09:15 AM | #25 |
Drives: Toyota GT86
Will this work to lift the engine a little to help in the reinstallation of the transmission?
08-31-2023, 01:10 AM | #26 |
chicken tonight
Whoops. Sorry I missed this. Lift? No. Tilt back? Yes, absolutely.
08-31-2023, 12:14 PM | #27 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
Knots are a basic mechanical advantage. If you don't have the fundamentals in your toolbag, something is lacking.
Tautline hitch, prussic, woo! sheepshank! Get em while they're knot! Rope Knots
"I gotta rock." -- Charley Brown |
The Following 2 Users Say Thank You to bcj For This Useful Post: | Ultramaroon (08-31-2023), Wally86 (09-01-2023) |
08-31-2023, 02:01 PM | #28 |
chicken tonight
Similar Threads | ||||
Tamara tow strap | Dreyup | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 07-09-2017 04:03 PM |
Takata tow strap | Thatguyjeremy | Cosmetic Modification (Interior/Exterior/Lighting) | 13 | 05-20-2015 09:25 AM |
FS: Takata Tow strap | Tengu | Exterior Parts (Aero, Lighting, Etc.) | 1 | 02-26-2014 08:36 AM |
rear tow strap | karma003 | Cosmetic Modification (Interior/Exterior/Lighting) | 0 | 07-23-2013 09:00 PM |
Help me strap down my tires | qoncept | Tracking / Autocross / HPDE / Drifting | 5 | 06-20-2013 04:06 PM |
