Engine, Exhaust, Transmission Discuss the FR-S | 86 | BRZ engine, exhaust and drivetrain. |
12-13-2017, 04:35 PM | #15 | |
Drives: 15 BRZ LTD, 05 FXT
If you drive 5 minutes and pull into a coffee drive through in the morning you may hear it a little, but if you've driven to work and you're just letting your EGT's settle down after a nice joy ride, it likely won't be too much louder than a stock engine. They are definitely louder, but not obtrusively so.
SOLD: 2015 WRB BRZ Limited ('02 WRX BBS, S-04's, Stoptech Sport pads, MXP SP, AVO drop in filter, Mishimoto Intake tube, decatted header, OFT 93 Stage 2 EL Tune, Kartboy rear shifter bushing, Whiteline transmission and subframe lockout bushings, ST Coilovers, SPC Camber bolts w/smaller crash bolt, SPC LCA's & SPC Toe Arm bushings, Red TOMs, TRD Wing.)
12-13-2017, 05:14 PM | #16 | |
Drives: 2015 Raven FRS
4032 pistons do not expand like 2618 so 4032 pistons can be used is stock bore with only a hone. So they are quiet right from the git go. So, next problem. I am shopping for 4032 pistons in the stock 12.5 compression ratio. Most piston manufactures either use only 2618 or only make low compression pistons for boosted applications. Full Blown told me Arias will custom make pistons in stock 12.5 to one compression ratio and out of 4032 alloy, And only slightly more than stocked pistons. So I now have put this on Santa's wish list. |
Similar Threads | ||||
compression ratio | nexusatm | Forced Induction | 38 | 05-13-2016 07:59 AM |
Suggestions on built short block and compression ratio? | SoCal80six | Forced Induction | 24 | 11-18-2015 05:59 PM |
NY Brz Vortech Supercharged | Ny Brz | Member's Car Journals | 47 | 06-22-2015 03:30 PM |
Porsche Patents a Variable Compression Ratio | Captain Snooze | Other Vehicles & General Automotive Discussions | 7 | 04-30-2015 11:21 PM |
Compression ratio 12.5:1. Bye-bye Super charger & Turbo build? | fred_boosted | Engine, Exhaust, Transmission | 215 | 12-12-2011 07:23 PM |
