Old 08-11-2016, 11:54 PM   #15
VerusEric
VerusEric's Avatar
Drives: BRZ, STI, GT350R, Supra, 987.2
I remember my days of small-run manufacturing. So painful having to mill a can out of billet.
It's a beautiful piece, Eric. Totally makes sense.
Thanks sir. This has been a fun project.
Originally Posted by TRAKRAVN View Post
Any plans for a crankcase vacuum pump mounted to replace the air conditioning pump?
Not right now, perhaps down the road.
Originally Posted by lazyluka View Post
Compatible with RHD?
Originally Posted by COO86L View Post
Stole my question haha!
Looking at pictures online, it looks like we'll need a different bracket for those that are RHD.
Thanks,
Eric
VerusEric is offline   Reply With Quote
The Following 2 Users Say Thank You to VerusEric For This Useful Post:
lazyluka (08-24-2016), TRAKRAVN (08-12-2016)
Old 08-13-2016, 05:02 PM   #16
Sargy
Long Distance Driver
Sargy's Avatar
Love the design and R&D that went into this.
Whats nice to see is the optional coolant passages,
Another form of contamination not going into the motor!
Sargy is offline   Reply With Quote
Old 08-14-2016, 03:11 PM   #17
VerusEric
VerusEric's Avatar
Here are some updated photos. Received the anodized and laser engraved parts and started assembling.
-6AN ORB to 1/2" hose barbs
Caps with the coalescent filters installed
Close up of filters installed
Took off the prototype unit. Both sides of the AOS have oil traces on the filters showing they're doing their job. Definitely, need both sides filtered if you want to extract all of the oil out.
Thanks,
Eric
The Following User Says Thank You to VerusEric For This Useful Post:
Calum (08-14-2016)
Old 08-14-2016, 03:50 PM   #18
Resolute
in the recliner of rage
Drives: Asphalt FR-S
I like how you've incorporated coalescent filters into the design, and I think the unit looks great. But for those of us who would rather not drain the catch oil back into the pan, is there a way to check the fluid level of the can? Is a sight tube an option?
Resolute is offline   Reply With Quote
Old 08-17-2016, 01:12 AM   #19
VerusEric
VerusEric's Avatar
We currently do not. We can look into this for the next run; however, price would likely have to go up.
From my experience, you won't need to drain it more than once an oil change unless you track it heavily. With a Fumoto drain valve threaded in, it'd be quite quick and easy to drain.
Here are some more assembly photos.
Rear of base assembly
First (3) fully assembled units
Each mesh ball gets a sonic cleaning before being installed into the cans for half an hour.
Installed photos
If there are any photos you guys want of something specific, please let me know. I'll have an install manual up soon and these should be fully assembled shortly and ready to go shortly.
Thanks,
Eric
yberther (08-17-2016)
Old 08-17-2016, 08:57 AM   #20
Cockatoo
TALLY FT86
Cockatoo's Avatar
Drives: 2014 FR-S Monogram -- SBD Turbo --
Looks really clean!
Cockatoo is offline   Reply With Quote
Old 08-22-2016, 01:52 AM   #21
VerusEric
VerusEric's Avatar
Here are the last few photos of assembly.
Coolant passage port uncovered
Coolant banjo bolts installed. Came out better than I had hoped!
These should be available for order later this week on both FT-86 SpeedFactory and Velox website.
Thanks,
Eric
The Following 3 Users Say Thank You to VerusEric For This Useful Post:
15limited (08-24-2016), civicdrivr (08-22-2016), SkAsphalt (08-29-2016)
Old 08-22-2016, 03:27 AM   #22
solidONE
solidONE's Avatar
Drives: FR-S Whiteout
Beautiful!
Intent > Content
The Following User Says Thank You to solidONE For This Useful Post:
VerusEric (08-22-2016)
Old 08-24-2016, 02:50 PM   #23
VerusEric
VerusEric's Avatar
These are now for sale on our website and soon FT-86 SpeedFactory.
http://www.velox-motorsports.com/#!p...c-c921839a6b69
I noticed during final assembly that the bases on the blue units had some discoloring. I'm not sure what happened during the anodizing process but these are on clearance for anyone that doesn't need a "show quality" AOS. Below is an example of one of these blems.
Thanks,
Eric
Old 08-24-2016, 10:46 PM   #24
15limited
15limited's Avatar
Props for not just mixing in discolored units with the others and calling it a day. I have your LCA and they look amazing 👍 Velox has the quality control all companies should live by
Perrin Transmission Bolt, Drift Button,Intake Tube, Radiator Hoses, Engine Mounts, Gurney Flap Diode Dynamics Always On Module OLM 3k HID Foglights GCS Smoked Side Markers Motul Gear 300/300 V OE Acantara arm rest Password JDM Dry Carbon rear diffuser Rally Armour Mud flaps H.I.C side & rear visor Gruppe-S UEL header/OP HKS Front Pipe Leg Sport Cat Back Koyorad aluminum radiator Wheelhaus CF low pro 3rd brake light Toms JDM Clear Tail Lamps
15limited is offline   Reply With Quote
Old 08-25-2016, 10:12 AM   #25
200hp/tonne
200hp/tonne's Avatar
Drives: Raven Fr-S
How do I get one on clearance?
<insert Colbert's give it to me now gif>
FR-S Mod target: 200 BHp / Tonne
4lb Li Battery, RPF1 17x9, 245 RE71R, RCE T2, OFH, OFT Stg 2, Berk Over+Front Pipe, , STI Eng/Trans Mts, PU Bushings, Forrester Liq-Liq oil cooler, Al Driveshaft, OSGiken Diff
200hp/tonne is offline   Reply With Quote
Old 08-25-2016, 11:01 AM   #26
civicdrivr
civicdrivr's Avatar
Drives: 2018 Golf R
From the drop down on their website, select Blue-Blemish Unit.
Parting out HERE
civicdrivr is offline   Reply With Quote
Old 08-25-2016, 12:19 PM   #27
Maverick986
Drives: 2014 Subaru BRZ
I found it doesn't work on my mobile devices, however does work/update the price on my laptop.
Sent from my SM-G925V using Tapatalk
Maverick986 is offline   Reply With Quote
Old 08-25-2016, 06:02 PM   #28
VerusEric
VerusEric's Avatar
I do my best to catch these types of things before they go out the door, I'm sure I don't get them all but I do my best.
Should be on the drop down, blue-blem. Should be ~$70 off or so.
I tried it on mine, not sure what is happening on your end? Try clearing your cache/cookies or something as I initially did set it up at full price.
Coolant kit and drain kit are now on there as well. FT-86 SpeedFactory will probably have them on the shelf/website soon as well.
Coolant: http://www.velox-motorsports.com/#!p...9-d5aecc4258a4
Drain Kit: http://www.velox-motorsports.com/#!p...d-de3c930fc1ad
Thanks,
Eric
Verus Engineering High Performance Radiator - Gauging Interest VerusEric Engine, Exhaust, Transmission 90 07-08-2023 07:43 AM
Verus Engineering Rear Wing Development VerusEric Tracking / Autocross / HPDE / Drifting 203 07-05-2021 09:15 AM
Verus Engineering Billet Transmission Beta Tester Run VerusEric Engine, Exhaust, Transmission 62 04-26-2020 01:44 PM
Verus Engineering Carbon Thermoplastic Splitter Components VerusEric Cosmetic Modification (Interior/Exterior/Lighting) 35 11-26-2017 05:23 AM
Raceseng | Revo Pulleys Information and Release Raceseng Engine, Exhaust, Transmission 3 10-09-2016 11:01 AM
