Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
01-27-2016, 10:38 PM | #15 | |
Drives: '22 BRZ
Seeing that it's so close in length compared to a Bilstein shock eases my concerns quite a bit, I've driven a car on those and never had an issue pushing it hard. |
01-28-2016, 02:11 AM | #16 | |
Drives: 2005 Toyota Camry
-alex |
01-28-2016, 10:28 AM | #17 |
Drives: '22 BRZ
The Following 2 Users Say Thank You to DocWalt For This Useful Post: | Shark_Bait88 (01-28-2016), wparsons (01-28-2016) |
01-28-2016, 01:24 PM | #18 |
I don't know about you, but plenty of freeways in the Los Angeles area suck.
Too much container/truck traffic = horrible, poorly fixed expansion joints on roads. And some of the bridges end up being launch ramps instead of joints. -alex |
02-03-2016, 08:01 AM | #20 |
Drives: GT86 Cosworth
Quite soft springs at 70N/mm
Is the damper travel the same? |
02-03-2016, 01:45 PM | #21 |
02-03-2016, 01:53 PM | #22 |
Drives: '22 BRZ
Out of curiosity, do you/can you tweak the DFV at all? I don't even know where I'd begin with that, just curious if it's something that's possible.
02-04-2016, 06:12 AM | #23 | |
The DFV is the same in all the road and track kits, just shimmed differently to suit the application. Also 70N/mm is 7.14kg/mm i'll get my coat..... |
02-04-2016, 09:12 AM | #24 | |
Drives: '22 BRZ
It appears as though the DFV is going to be directly affected by the main valve and vice versa, but the drawing is not overly clear in that regard. |
02-04-2016, 11:07 AM | #25 |
Isnt it the shaft jet path bleed that gets adjusted?
Its low speed damping that you want to be critically damped so you have to increase it with spring rate? |
02-04-2016, 11:47 AM | #26 | |
Drives: '22 BRZ
I'm just curious if they've made adjustments to the behavior of the DFV to change the response over harsh bumps. |
02-09-2016, 08:42 PM | #27 | |
We have actually removed the DFV system completely. The valving now compensates to the missing DFV system and makes the ride extremely comfortable. I took a ride in the customer's car, and Man oh man, it sure is amazing. I have valved bilsteins on my miata (non adjustable monotube yellows) and it makes mine feel extremely stiff. |
The Following User Says Thank You to FRSport.com For This Useful Post: | DocWalt (02-09-2016) |
02-14-2016, 03:11 PM | #28 |
wow, that looks serious
Similar Threads | ||||
FS: MCS C-Street Double Adjustable Shocks with TRD Spring PKG | simpleisbest | Brakes, Suspension, Chassis | 11 | 08-24-2015 01:41 PM |
Ohlins R&T on the street? | donoman | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 30 | 04-30-2015 01:59 PM |
Brand New Whiteline Sway bars 20mm adjustable front 16mm adjustable rear | deedz | Brakes, Suspension, Chassis | 11 | 03-17-2015 03:29 AM |
Ohlins group buy | aruxe | CANADA | 1 | 05-22-2014 03:36 PM |
Trailer | Ohlins Install | Interviews With Essex & Ohlins | Dezoris | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 31 | 12-24-2013 03:01 PM |
