Suspension | Chassis | Brakes -- Sponsored by 949 Racing Relating to suspension, chassis, and brakes. Sponsored by 949 Racing. |
#15 | |
Drives: 2013 FRS
Begin with a series of light decelerations to gradually build some heat in the brakes. Use an on-and-off the pedal technique by applying the brakes for 3-5 seconds, and then allow them to fully release for a period roughly twice as long as the deceleration cycle. If you use a 5 count during the deceleration interval, use a 10 count during the release to allow the heat to sink into the pads & rotors. After several cycles of light stops to begin warming the brakes, proceed with a series of medium to firm deceleration stops to continue raising the temperature level in the brakes. Finish the bedding cycle with a series of 8-10 hard decelerations from 55-65 MPH down to 25 MPH while allowing a proportionate release and heat-sinking interval between each stop. The pads should now be providing positive and consistent response. If any amount of brake fade is observed during the bed-in cycle, immediately begin the cool down cycle. Drive at a moderate cruising speed, with the least amount of brake contact possible, until most of the heat has dissipated from the brakes. Avoid sitting stopped with the brake pedal depressed to hold the car in place during this time. Park the vehicle and allow the brakes to cool to ambient air temperature.
WIFE: "How can there be anything left to buy?"
The Following 2 Users Say Thank You to bmacfrs For This Useful Post: | ActionMaxon (02-15-2020), NoHaveMSG (02-15-2020) |
#16 | |
https://shop.advanceautoparts.com/p/...8aAke-EALw_wcB Sent from my GM1915 using Tapatalk
2013 Series 10 FRS #553
The Following User Says Thank You to jflogerzi For This Useful Post: | bmacfrs (02-15-2020) |
#17 |
Professional Auto Fixer
Drives: 2016 Oceanic FR-S as Designed
I can't speak to race parts, but I want to add that some brake pads specifically say not to apply grease to the backing plate. So make sure you aren't missing a pad specific installation note.
Work Hard. Play Hard.
2016 Oceanic |
The Following User Says Thank You to ActionMaxon For This Useful Post: | jflogerzi (02-15-2020) |
#18 | |
Drives: 2013 FRS
Permatex 80653 Silicone Extreme Brake Parts Lubricant https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1
The Following 2 Users Say Thank You to bmacfrs For This Useful Post: | fminicooper (02-16-2020), jflogerzi (02-15-2020) |
#19 |
Drives: unlimited cheap build N/A track car
I have the same 4 piston Wilwood BBK. So far Iv'e just used the bp10 pads. I have never heard a squeal from them.
I have noticed a problem however. In the rain when the pads/rotors get wet I have almost zero brake friction for a second or two after I hit the brakes. It isn't a good feeling. Anyone else have this issue? |
#20 | |
Drives: FRS
- Until a little daily driving removes the bedding and the squeeeeeeel starts again. ![]() ![]() |
#21 |
Drives: 2014 GT86
In that case wrong pad choice for wrong type of driving. There is reason, why many use two pad sets, one for track, one for DD, switching for trackdays, to have pros at type of driving pads are meant/designed to, and to not having to suffer cons/deficiencies of those in driving they are not meant to. Obviously track pads designed for higher temp range don't get anywhere near heat/temps during daily driving, thus no transfer of pad material aka bedding happens, rather opposite, scratching off what got there during bedding. It's not pad fault. It's owner's not right parts for a job choice fault. If it was intentional, well, one should accept cons that come with that (noise aside, also might be a bit worse braking on non-bedded rotors, and quicker wear). Street pads have low working temp range .. it limits one on track .. but in most cases with stock pads able to rebed layer even with light braking characteristic of DD. Though as BBKs often have more thermal capacity and have more efficient cooling, in rare cases even with less track oriented pads it may get harder to keep brakes bedded. It may sound counterintuitive, but eg. i'd close brake airducts for DD for example
#22 | |
Drives: FRS
Except that the street pads also have to be bedded. Lots of track days - lots of bedding. Except for the great gobs of pad powder going into the ether and excessive wear on the discs. Sometimes it seems like I lose more pad material in bedding than duelling with Corvettes ! ![]() ![]() ![]() ![]() |
#23 |
Drives: 2017 Toyota 86
Are you running wilwood pads?
I've tried bp40 and they are extremely loud! Louder than train stopping behind my house. I would try different pad compound if you can't live with it. I kinda like bp40 because they are cheap and work just fine. |
#24 | |
Drives: 2013 FRS
Sent from my SM-G960U using Tapatalk
#25 |
I would try blank rotors. Im using dtc60 now but with the J hook rotors with the ap kit they are just as loud as wilwood pads but on stock size blank rotors they are almost quiet. Both have gone through same bed in procedure.
The Following User Says Thank You to ZZJ For This Useful Post: | bmacfrs (03-19-2020) |
#26 |
Drives: FRS Hot Lava
I am using BP40 with a very loud noisy result as expected, similar to others experience.
I tried the Permatex 24129 Silicone Extreme Brake Parts did not work a bit. Went with BP10 pads, problem solved, I will change pads for track with proper bedding. |
The Following User Says Thank You to fminicooper For This Useful Post: | bmacfrs (03-23-2020) |
#27 |
Just bumping this thread. Using carbotech 1521s and brakes are slient on street. Found carbotech xp10s and xp8s front and and rear for these calipers. Going to try these on track and switch between the 2. Nice thing I can use a single set of rotors and just switch pads
The Following User Says Thank You to jflogerzi For This Useful Post: | bmacfrs (11-07-2020) |
#28 |
Drives: 2013 FRS
I forgot to make an update to this thread...
I tried a set of G-Loc R10 front and rear. Great success with performance and significantly reduced noise. I have used them on many TT events and track days. Very consistent results. I rarely drive on the street anymore but that was MUCH better as well. I got a set of their AX pads for the occasional autocross so I can just swap the fronts. I have heard their compound is very similar to Carbotech. So maybe this is the best option for helping noise with these calipers. Sent from my SM-G960U using Tapatalk
The Following User Says Thank You to bmacfrs For This Useful Post: | bhmax (11-08-2020) |
Noisy Car | Flarpswitch | BRZ First-Gen (2012+) -- General Topics | 72 | 07-20-2019 04:29 PM |
Noisy MCS Shocks | Kuro86 | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 08-30-2018 09:28 AM |
Noisy a/c vent? | StraightOuttaCanadaEh | Issues | Warranty | Recalls / TSB | 19 | 03-20-2017 01:14 PM |
Anyone else got a noisy ECU? | ft_sjo | Issues | Warranty | Recalls / TSB | 11 | 04-16-2013 09:03 AM |
Engine is quite noisy | Rob_g | Issues | Warranty | Recalls / TSB | 9 | 10-14-2012 08:41 AM |
