10-17-2017, 01:55 PM | #15 | |
Meh, I'll take a healthy NA 6 cylinder over a high-strung 4 cylinder any day. |
The Following 3 Users Say Thank You to funwheeldrive For This Useful Post: |
10-18-2017, 11:30 AM | #16 | |
Drives: '12 C63 P31, '23 GRC
Current: 2023 GRC Circuit Edition, 2012 C63 AMG P31
Past: (2) 2000 MR2 Spyder, 2017 GTI Sport, 2006 Porsche Cayman S, Supercharged 2013 BRZ-L, 2007 Honda S2000, 1992 Integra GS-R |
The Following User Says Thank You to WolfpackS2k For This Useful Post: | strat61caster (10-18-2017) |
10-18-2017, 01:07 PM | #17 | |
imho it's not all it's cracked up to be, yeah the dyno numbers look impressive but the lack of responsiveness is underwhelming to me. Riding the 'boost wave of torque/power' is certainly fun but that's not what I enjoy out of a car and certainly not what I would buy a Porsche for (despite the 930's reputation). If I ever own a turbo car I probably won't do more than a catback exhaust, which on some cars opens up a noticeable amount of power. |
The Following 2 Users Say Thank You to strat61caster For This Useful Post: | nikitopo (10-19-2017), WolfpackS2k (10-19-2017) |
10-18-2017, 05:49 PM | #18 | |
Drives: 2014 Scion FR-S Monogram
That wasn't even the end of it as just by putting in a cat delete, bigger injectors, and an e85 tune the tuner quoted it as making 250chp and over 300ctq now if a 80hp and 130tq bump from very simple bolt ons and tune aren't impressive I don't know what you will think is.
Raven OFT Stage 2 UEL E85 | Tomei UEL Headers | Catless FP | Greddy Revolution RS Catback | HKS Air Filter | Toyota Badge Swap |
The Following User Says Thank You to Detroiter For This Useful Post: | funwheeldrive (10-18-2017) |
10-18-2017, 05:52 PM | #19 | |
10-18-2017, 05:59 PM | #20 | |
I doubt how rewarding and fun it is to drive around a corner when you've got monster lag to get back to maximum power. |
10-18-2017, 07:46 PM | #21 |
Only users lose drugs.
Drives: All the time
If it's the stock turbo, there's no more lag with an aggressive tune than there was when everything was 100% stock. In fact, there may be less. There may be more perception of lag simply because running more boost results in higher peak power, but there's no reason running more pressure from the same compressor would somehow result in more lag.
"To know a thing well, know it's limits. Only when pushed beyond its tolerances will true nature be seen." Amtal Rule
10-18-2017, 08:04 PM | #22 | |
There's no lag to the original boost/power levels, but you've likely upgraded the grip available as well which means that no-lag to stock boost/power is irrelevant, it's now the lag to the increased power that's of concern. It takes longer to spool to the new maximum boost than the old maximum boost, you can't break the laws of physics no matter how good the tune is. Edit: A different driving style makes this not a problem, early back to the gas, left foot braking while still on the gas to keep the boost up, whatever, I just don't really like it. Some do, that's fine, but I bought into the hype of 'just crank up the boost, it's great!' until I tried to drive fast with a car tuned like that. I just didn't really like it and I think it's worth asking when someone starts beating that drum. It's one of the reasons I'm very happy with my FR-S. Last edited by strat61caster; 10-18-2017 at 08:23 PM. |
10-18-2017, 09:36 PM | #23 | |
Weight Weenie
Drives: 15 FR-S
I think, I've finally decided to boost the Fr-s and you post this... |
10-18-2017, 10:23 PM | #24 | |
The Following User Says Thank You to strat61caster For This Useful Post: | Tcoat (10-19-2017) |
10-19-2017, 01:57 AM | #25 | |
I actually think it equates very well to a motor like the fa20 where all the power is at redline. Rather than feeling the power build as you push to the limiter you feel it build in the mid range just quickly and then it eventually dies off up top (downside of a small fast spooling turbo). At least in my driving it was felt like a similar sensation especially with slightly bigger turbo like in my friends sti. The longer amount of lag allowed the torque to build up in a natural and smooth way just like a high sprung NA motor just earlier on in the power band.
10-19-2017, 06:08 AM | #26 |
Weight Weenie
Drives: 15 FR-S
What you wrote rings true to my ears. Unfortunately, I still feel the car is lacking, just a tad...I'm not sure if a header/tune will get it where I'd like it to be. The only way to find out is to go for it. I should go test drive a MY17/18 first.
The Following User Says Thank You to new2subaru For This Useful Post: | funwheeldrive (10-19-2017) |
10-19-2017, 07:01 AM | #27 | ||
Old Guy
Drives: 16 STi, 22 MX-5 RF BBS, 04 OBS RPA
For example, for this same pricing, you can get a c5z06. In general, it is cheap to maintain. However, compared to a BRZ, the amount of oil used, clutch reservoir maintenance and 3x more expensive tires make the running costs far exceed the BRZ. Also, while I don't have direct experience with the Cayman, I am going to assume the gearing per gear is very wide. This just means the experience you are going to get on the street is going to be very different. All the updated power you aren't really going to be able to use.... or be able to use legally for long. This is something you have to do beyond the honeymoon-phase to understand what the difference really means. Good luck in your quest. Quote:
10-19-2017, 08:28 AM | #28 |
Drives: 2013 FRS / 2013 427 Vert
I'd be curious to see the dyno curves overlaid between the 718 and 981. I would imagine the difference in low and mid range torque would be substantial. Whether or not you care for the aural aspects of the modern turbo 4's you can't deny the improvement in acceleration capability. Lap time magazine comparisons really illustrate the difference.
Lighting Lap: 2014 Cayman S 3:02.6 2917 Cayman S 2:58.3 2017 Honda Civic Si 3:14.6 2017 BRZ 3:19.7 Tuning just increases the disparity if you are willing to roll the dice. I have an APR tune on my wife's TTS and the car runs 0-60 in 3.8 seconds on a V box and will pull bus lengths on my supercharged FRS. Honestly I'd love to have the power delivery from my Audi 2.0l available in the Scion.
[SIGPIC][/SIGPIC]
2013 FR-S Asphalt BC Coils/Rev Works UEL header/HKS Front Pipe/Racing Brake BBK/Shorai LW Battery/ACT 6 Puck Clutch/FBM Radiator & Oil Pan/JR Oil Cooler/Jackson Racing High Boost C30/Rev Works Built Motor 2016 Audi TTS APR Tuned |
Similar Threads | ||||
BRZ vs Cayman/Corvette | Norcalkid | FR-S / BRZ vs.... | 128 | 01-31-2017 12:36 PM |
Twins vs Cayman/Boxster 211 | botbs | FR-S / BRZ vs.... | 15 | 10-06-2014 10:09 AM |
2013 981 Cayman | ironchef | Other Vehicles & General Automotive Discussions | 49 | 12-09-2012 07:03 PM |
FR-S vs Cayman | colganc | FR-S / BRZ vs.... | 102 | 09-13-2012 04:17 PM |
GT86 vs. 370 vs. Cayman S | wrxgoose | FR-S / BRZ vs.... | 0 | 08-27-2012 11:26 PM |
