01-21-2013, 01:23 AM | #15 |
Drives: Moped
I guess nothing ever came of this...
01-21-2013, 02:42 AM | #16 |
Drives: 2013 BRZ Limited 6MT GBS
I want it!
2014 infiniti Q50 Daily 1996 Mazda Miata Racecar
SOLD -> Galaxy Blue Silica Subaru BRZ Limited 6MT SOLD -> 2003.5 Infiniti G35 Sedan Emerald Mist |
02-04-2013, 12:45 PM | #17 |
Drives: 1996 Integra LS 4DR, 2013 Scion FRS
Thanks for the interest and I finally managed to get around to it. I will be posting up a DIY soon. Love how unobtrusive it looks. Next best thing to shaving the stock antenna off.
The Following 26 Users Say Thank You to Enigmus For This Useful Post: | Anthonytpt (03-01-2013), B L U E S L A T E (05-06-2013), BabyPubes (07-25-2013), Bones36 (02-07-2013), CrazyWookiee (03-02-2013), fatherfork (02-27-2014), geezerbrzeezer (03-05-2017), hotpanda1 (04-22-2014), J-W (04-04-2014), JustBoostin (03-03-2014), Kiske (10-12-2013), Lonewolf (04-07-2013), M-17 (03-05-2014), mx5 2nr (06-20-2014), Nguyenstreak (10-12-2013), OICU812 (05-08-2013), Retro86 (02-05-2013), saj (05-01-2016), SnapOv3st3r (03-04-2014), Spidey (05-12-2013), Surok (02-10-2013), tbrocato (03-03-2014), TIE Pilot (02-12-2013), TommyFive (02-10-2013), troek (06-18-2014), WhiteRose (08-25-2014) |
02-04-2013, 01:03 PM | #18 |
Looks good.
02-04-2013, 01:06 PM | #19 |
Drives: argento frs at
how's the signal strength on these as oppose to the shark fins ?
The Following User Says Thank You to tnt For This Useful Post: | sato (07-24-2014) |
02-04-2013, 09:04 PM | #20 |
Drives: 13 BRZ
Looks much better than the shark fin IMO. Any idea if it will fit the BRZ? I know the base is slightly larger due to the navigation.
02-04-2013, 09:14 PM | #21 |
where did you get the antenna you used?
02-04-2013, 09:27 PM | #22 | |
As for signal strength the connections were a bit different but looking right in the plug they're very similar just the connector housing is different. I can splice the corresponding male plug when i get the chance. I lost slight radio signal but I mainly use pandora from my phone anyways. I'll get around to figuring out how to correctly wire it up.
The Following 10 Users Say Thank You to Enigmus For This Useful Post: | Anthonytpt (03-01-2013), bobpuffer (03-17-2013), Bones36 (02-07-2013), civicdrivr (02-04-2013), DNAPoPo (05-01-2013), enjoi23 (10-13-2013), fatherfork (02-27-2014), Lonewolf (02-04-2013), SirBrass (02-27-2014), wheelhaus (02-24-2013) |
02-04-2013, 09:32 PM | #23 |
The hole where the antenna is mounted through should be the same in both the brz and frs which is a little more than an inch wide. Essentially any other oem satellite antenna can be used in theory. I ordered this antenna for a little under $50
02-04-2013, 11:37 PM | #24 |
Drives: Moped
Awesome ingenuity on your part! I want this antenna (plug and play of course) and the grazio jeweled tails something bad!
02-05-2013, 09:03 AM | #26 |
Grip>Slip
The BRZ GPS antenna is in the dash, i believe (at least judging by the TSB info). The reason the BRZ's base is wider is because of the Satellite radio antenna.
02-05-2013, 11:22 AM | #27 |
Drives: '85 AE86 Sprinter Trueno
I eagerly await a write up for this... that looks amazing.
02-10-2013, 05:04 PM | #28 |
Drives: Ae86,X2 , Scion FRS
ight i see you have a la tag if your from nola we need to get togeather
Similar Threads | ||||
Tom's antenna shark fin | Hanzo | Cosmetic Modification (Interior/Exterior/Lighting) | 15 | 10-28-2012 12:44 PM |
Flat black BRZ | BRZranger | Cosmetic Modification (Interior/Exterior/Lighting) | 6 | 06-27-2012 03:23 PM |
Flat Black BRZ | Toods | BRZ First-Gen (2012+) -- General Topics | 4 | 06-20-2012 12:25 AM |
Beat-Sonic USA Shark Fin Antenna for Subaru BRZ, DOES NOT FIT! | xcelir8brz | Electronics | Audio | NAV | Infotainment | 2 | 06-04-2012 11:44 PM |
I'm going to try my hand on a flat 4 | 4agze | Other Vehicles & General Automotive Discussions | 2 | 04-08-2011 07:46 PM |
