Old 12-16-2013, 12:04 PM   #15
vividracing
vividracing's Avatar
I also contemplated this same scenario with my car. In the end I just invested in some stance coilovers. If money plays some kind of factor hit me up and I can make sure you get your money's worth no matter what direction you go.
vividracing is offline   Reply With Quote
The Following 2 Users Say Thank You to vividracing For This Useful Post:
1086 (12-16-2013), suaveflooder (12-16-2013)
Old 12-16-2013, 12:09 PM   #16
suaveflooder
Originally Posted by ericmpena View Post
I kind of wish I went with a Pro-Kit instead of Sportlines. From what I've read you don't really need to upgrade your shocks if going with a Pro-Kit. My problem with the Pro-Kit is that some pictures they look great, and then other pics I see you can't even tell the car is dropped. I think it all depends on the tire you use.
Pro kit and the Yellows have this similar problem. They literally "take the edge" off the height of the car while improving handling. With a minor drop, there probably won't be issues with the shock failing or blowing, but life will probably be decreased. The good news is that with the spacers the car will look a little lower anyway….at least mine did when the rear tire was no longer tucked. I went with a 20mm spacer in the rear only.
@1086, another thing you might want to think about is wheels. If you ever want aftermarket wheels, 9.5 inch wheels (which is what I'm looking at) won't fit with the stock perch. I bought my springs a month after my car and LOVE how it handles and looks, but I want some wide wheels and they won't fit on the current set up. Like mentioned, don't cheap out, if you decide to go coil over.
suaveflooder is offline   Reply With Quote
Old 12-16-2013, 02:07 PM   #17
1086
1086's Avatar
Drives: UM86 - 6MT
If I were to get wheels, I would probably only go 8 inches width max. For now I am happy with the stock wheels though.
So did you add the 20 mm spacers first before dropping it with the eibachs? or did you add spacers and added shocks at the same time?
Would you agree that if I go the route of stock struts + eibach pro kit + 20 mm spacers all around that I will be fine, especially on relatively harsher turns? I just don't want any rubbing or something to eff up is all.
Plus, if I have to replace the stock struts with Konis eventually, that is completely fine.
1086 is offline   Reply With Quote
Old 12-16-2013, 02:46 PM   #18
fooddude
Drives: 04 Toyota Tacoma Prerunner Reg Cab
I've been curious on the Tein's cheaper offerings/models too as compared to Lowering Springs + Koni's/Tokico's.
Specifically: Are the Tein Street Basis shocks/struts short-stroke???
If, yes, then I would assume that the cheap Tein Basis setup would be much better than a lowering spring (eibach, tein, etc. etc) + koni/tokico combo for this reason alone; and would also be in a very similar price range to each other.
fooddude is offline   Reply With Quote
Old 12-16-2013, 03:04 PM   #19
suaveflooder
Actually dropped the car for awhile before adding the spacers. You will have no issues with rubbing.
The Following 2 Users Say Thank You to suaveflooder For This Useful Post:
1086 (12-16-2013), brz408 (12-16-2013)
Old 12-16-2013, 04:51 PM   #20
zooki
Drives: waiting on a 2021...
I have Eibach Pro's on stock struts. 40K on the car and no problems. I have aftermarket rims, but with any rim flush in the wheel wheel it definitely makes the car look lower.
2016 4Runner Tail edition
2020 Camry 2020 RAV4
2013 Chevy 3500 4x4 Duramax
1999 Ford F250 Powerstroke, the tow rig
1969 Mustang, the fast car....(:
zooki is offline   Reply With Quote
The Following User Says Thank You to zooki For This Useful Post:
brz408 (12-16-2013)
Old 12-16-2013, 11:38 PM   #21
Racecomp Engineering
IMO with a lower end coilover you are making big sacrifices in the quality of the damper itself. That is the most important part and with a koni set up you get good solid valving. No height adjustability, but I'd rather better valving and a preset drop.
- Andy
Old 12-17-2013, 01:49 AM   #22
1086
1086's Avatar
Drives: UM86 - 6MT
So you think it would be OK to go with the Eibach pro/RCE on Stock struts or is it safer to go with the Koni + Eibach Pro/RCE?
Old 12-17-2013, 04:18 AM   #23
car_roll
Drives: Nuisance BRZ
Option 2 sounds the best. As racecomp said, you really want your dampers to be up to par. I know others recommend BC BR coilovers but from my personal experience, they aren't great, at all. For looks yea they get the job done but I didn't like the valving (dual adjustment one knob bs). I couldn't seam to get it to feel the way I wanted. ST coilovers is a great other option as it's made by KW. They will also most likely give you the best ride quality out of the sub 1k coilovers.
#teamnuisance
I do like, YouTube or something, IDK.
Shameless Plug
car_roll is offline   Reply With Quote
Old 12-17-2013, 04:23 AM   #24
OICU812
Just a dude
OICU812's Avatar
Drives: Scion FR-S 2013
Another thing to note is Konis don't come as a bolt in strut, you need to mod with existing struts. To some that dont have the tools or know how that is something to consider. If you were to go coils and budget minded based on all you've said then go with STs or The lower line Bilstein (or) save up and go a little bigger. As mentioned the "cheap" lines of chinese types coilovers are not going to give you a great ride that you'd be happy with.
Old 12-17-2013, 10:46 AM   #25
Both are fine. We've had TONS and TONS of test miles putting the car through hell and we've got owners with them on the car since the car came out. They can handle it. Remember the stock car rides on the bumpstops...we only do a mild drop and shorten the bumpstops. We know the stock strut can handle it. Lots of people that lower much more than us too and the shock is fine. The car doesn't handle or ride great that way though...
The Konis are an improvement for sure but a mild pain to install since the fronts are inserts. I'd be tempted to wait for Bilsteins. I'd prob run Yellows on stock dampers and then put the Bilsteins on when they're out.
- Andy
The Following User Says Thank You to Racecomp Engineering For This Useful Post:
brz408 (12-19-2013)
Old 12-23-2013, 01:27 PM   #26
nyfries
Drives: 14 FRS Whiteout
Does this mean u rather lose the adjustability you get with the BC racing? I'm consider either the bc or the st. Adjustability and not needing oem top hat seem appealing
Sent from my iPad using Tapatalk HD
nyfries is offline   Reply With Quote
Old 12-23-2013, 01:50 PM   #27
I'll take good preset fixed damping over crappy adjustable damping. Every time.
There's a lot more to it than just "soft" and "stiff".
- Andy
Old 12-23-2013, 02:10 PM   #28
wparsons
wparsons's Avatar
^^ This, plus just because they're adjustable doesn't mean you have the know how to properly adjust them. I'll take something tested that I don't have to mess with unless you're willing to spend time doing proper testing to see what works well with the damper settings.
flickr
Weight Reduction (budget diet) for daily/spirited driving 1086 Scion FR-S / Toyota 86 GT86 General Forum 86 03-22-2015 01:18 PM
New to me daily driver.. 95 M3. Dave-ROR Other Vehicles & General Automotive Discussions 58 07-17-2014 02:05 AM
FRS as a Daily Driver? Pake1 Scion FR-S / Toyota 86 GT86 General Forum 104 08-15-2012 11:48 PM
Will the BRZ be your daily driver WRXGuy1 BRZ First-Gen (2012+) -- General Topics 47 05-23-2012 12:15 PM
BRZ as daily driver? Pakjk89 BRZ First-Gen (2012+) -- General Topics 81 03-22-2012 09:50 AM
