08-31-2012, 10:37 PM | #15 |
Drives: Whiteout FR-S
What size are your wheels and tires? I have some Tein H Techs waiting to be installed but I'm thinking I want these instead.
09-01-2012, 09:10 AM | #16 | ||
Resident HoneyBadger
Drives: Toyota Tacoma TRD Off-Road
Walk like a King, Be like a Sir, Swag it out like a Boss |
09-01-2012, 10:14 AM | #17 |
Curious cat.
Drives: 86 GT base M/T - Red
Two questions:
- Why didn't you go for more front camber? - Why the clunking? Your install looks just fine so that worries me. I was hoping that the Com-Cs would be a pretty robust, clunk-free solution. Oh, and thanks a ton for the excellent post. Looking forward to your driving impressions.
2013 Toyota 86 GT M/T
2009 Renault Clio Sport R27 Team F1 Edition (sold) 1991 Mazda MX5 Miata (sold) 2007 Mitsubishi Evo 9 RS (sold) 2006 VW Golf R32 (sold) |
09-01-2012, 11:10 AM | #18 |
86-er
Drives: BRZ tS
on the com-c...question on that. are they rubber based, where the mount sits on the spring? if its solid, it could be the cause of the clunking. I think... Ive had several issues with solid mounts.
2018 Subaru BRZ ts 020/500 - My Daily, work car, and track car
09-01-2012, 01:51 PM | #19 |
Corner Junkie
Drives: 13 BRZ, 11 STI, 99 RS
The interface between the tophat and the upper spring perch is the same as stock. I think the OP should double-check the top nuts, as mine isn't clunking. Granted it's only been about 75-100 miles.
09-01-2012, 02:18 PM | #20 | |
Drives: 2013 Subaru BRZ
09-01-2012, 02:33 PM | #21 | |
86-er
Drives: BRZ tS
yup, Ive had that issue too where the top hat nut is not properly tighten. Could be that then
09-01-2012, 09:14 PM | #22 |
Drives: Silver AT Limited
Update on the Popping Issue: It is more of a popping sound that a clunking sound. This happens when I have the wheels more than 40% turned. It's not loud but is definitely noticable by me. None of the instructors noticed it though when I was driving, or maybe they thought it was a normal sound to hear and never pointed it out.
I just did a Skills Day with the Porsche Club here in Seattle. The car handled even better with the RCE Springs and the alignment. Slalom: The car felt more settled and was better at keeping the backend in check. It allowed me to go faster through it. Skid Pad: I was less prone to understeering and oversteering. It needed more gas to get the tail end loose. Handling Oval: Tires were definitely the weak point as I am still on the Stock Tires. Entering the corners with heavy braking is good, but you still need to feather very lightly the gas as you unwind the corner. Also having too much speed on the turn causes understeer. (This was the case even before the suspension upgrade) AutoX: People were saying I was staying flatter than the other Stock BRZ doing the course today. DD Ride Comfort: I did not feel any difference with the Stock Springs Truline quoted me a price and not by the hour. They did keep the car overnight though. For the Camber, I'm not the suspension expert, truline are the suspension experts and that is what they said would be reasonable compromise for a DD and AutoX. |
The Following User Says Thank You to mechaghost For This Useful Post: | rs999 (08-21-2014) |
09-01-2012, 09:15 PM | #23 |
Top nuts are secure. The car is handling perfectly so I need to figure out what is causing it. Tuesday will bring answers when I bring the car in
09-01-2012, 09:39 PM | #24 |
I had my gf turn the wheels for me while I look at it. The popping is coming from the Top Mounts
09-01-2012, 09:58 PM | #25 |
Make sure the springs are properly seated. They definitely shouldn't make any noise.
09-01-2012, 10:34 PM | #26 | |
have you guys heard of the same issues with other installs? |
09-02-2012, 04:15 AM | #27 |
Drives: Ultramarine FR-S
Gonna get my RCE springs installed this Wednesday. Looking forward to it...hope the popping sound isn't an issue.
BTW, i'm in Seattle for PAX...
6.4.12 | Ultramarine | SoCal
09-02-2012, 10:53 AM | #28 |
Corner Junkie
While someone turns the wheel, check to make sure the nuts in the tophats are turning. Also, again while someone is turning the wheel, look at the upper spring perches and see if they are turning also.
Similar Threads | ||||
White n' Yellow. | Asterisked Accolade | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 33 | 08-02-2015 04:01 AM |
Yellow fog tint looks awesome! | DookDookDGM | BRZ Photos, Videos, Wallpapers, Gallery Forum | 37 | 11-07-2012 03:40 AM |
RCE YELLOW Performance Lowering springs intro buy! RCE Suspension Starter Pack! | Racecomp Engineering | Brakes, Suspension, Chassis | 141 | 10-07-2012 08:12 PM |
Amber Turn signals to yellow? | deedz | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 08-01-2012 02:44 AM |
FT86s at Megaweb (more footage of the yellow 86) | ESBjiujitsu | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 16 | 05-26-2012 02:08 PM |
