Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack Specific topics relating to wheels and tires. |
09-12-2016, 11:35 AM | #253 |
Drives: 2014 Whiteout FR-S Manual
So with being lowered on coilovers and -2 degrees of camber, will it rub anywhere? Because tirerack stocks +45 and they mount for free, there's about a $200 price difference between these and +35.
09-13-2016, 05:14 PM | #254 | |
Drives: 2013 Raven FR-S
If you're interested in +35's, you could check Oakos. They usually have a good selection at pretty reasonable prices. I think they offer a discount if you PM them on here too. |
09-15-2016, 12:32 PM | #255 |
Enkei really nailed it with the RPF1, it is such a diverse wheel and looks right on so many platforms
09-15-2016, 01:03 PM | #256 |
Drives: 2014 GT86
I wouldn't care much about looks of RPF1, as far as wheel is not uber ugly, it's good enough. In my eyes main strength of RPF1 is not looks, but relatively light weight & reasonably low price. Many lighter then that = forged & expensive. Average cast ones = heavier.
09-15-2016, 04:42 PM | #257 |
Drives: 2013 Scion FRS firestorm
I guess it depends how low. I didn't rub when I was 1.5" or 1" lower and -2 camber.
10-10-2016, 12:12 AM | #258 |
Drives: GT86 GTS
Anyone having any issues with these wheels rubbing on the front anti-roll bar
10-16-2017, 10:39 PM | #259 |
Drives: 2017 Toyota 86 Halo
Currently have these on stock suspension, rubs the tie rod pretty noticeably at close to full lock. Does anyone know if for sure a 3mm spacer will solve the tie rod issue, or does it require 5-10mm.
11-04-2017, 09:27 AM | #260 |
Driver
Drives: 2013 Whiteout FRS
17x9 45
255 40 OEM struts with lowering spring. DSC_4167 by Apex 86, on Flickr DSC_4176 by Apex 86, on Flickr DSC_4164 by Apex 86, on Flickr
01-02-2018, 04:25 PM | #261 |
Driver
Anyone running coilovers with 245s? I just want to see how much sunken in the wheel look.
01-02-2018, 04:49 PM | #262 |
Drives: 2013 pearl white FR-S
01-02-2018, 05:15 PM | #263 |
Driver
It wasn't black magic, I had 10mm spacer with ARP extended studs
01-02-2018, 05:43 PM | #264 |
Wise old man
Drives: 86 GTS
i find that 17x9 +45 works really well, but i think that +35 does look slightly better, and increases track by 20mm.
i run a 245/40 AD08R, and its really nice, lowered as much as possible to maintain nice geometry , with -4.3 degree of camber on the front and -3 in the rear. lots of toe out on the front too. with coilovers of course. |
04-11-2018, 06:57 AM | #265 | |
Drives: 2017_86 2016_frs 2007_335i
after all the researching, here is my answer front enkei rpf1 17x8 +45 245x40 17 rear enkei rpf1 17x9 +45 245x40 17 the reason i want keep it +45 off set is this https://www.wheel-size.com/calc/?whe...cl=30mm&sr=0mm it will create a positive camber in front if i use 17x9 +35 so if i keep 17x9 +45 at front it will against the suspension finally i put 17x8 +45 , everything is right! but i dont know is there any BBK issues? if i am going to put a BREMBO GT FRONT 4 PISTON SLOTTED OR DRILLED BRAKE KIT from your website hope someone can help me out !!! |
Yesterday, 11:13 AM | #266 |
Drives: Mini Cooper S
Anyone here know of a brake kit that fits under these things?
Similar Threads | ||||
Wheel Directory: Enkei RPF1 17x9.0 +35 | D1cker | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 800 | 10-22-2023 12:00 AM |
Wheel Directory: Enkei RPF1 18x9.5 +38 | FRS8SIX | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 297 | 02-15-2018 03:50 PM |
Wheel Directory: Enkei Kojin 17x9.0 +45 | Clipdat | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 42 | 08-02-2016 04:18 PM |
