09-29-2021, 10:35 PM | #2535 |
FT86Club Official Vendor
Drives: Miata, GT350, FR-S
From Laguna Seca last weekend. Our project car "Blub".
18x10 +35 offset. No spacers rear, 5mm spacer front. -5° front and -3.5° rear camber. No roll. 265/35/18 Goodyear SC3R
11-23-2021, 11:16 PM | #2536 |
Drives: FR-S RS 1.0 #1037/1500
Has anyone had any issues with rubbing against the parking brake line in the rear? Is there anyway to relocate the line? I’m trying to avoid running spacers so I don’t have to add more negative camber
11-30-2021, 04:02 PM | #2537 | |
Drives: Launch-Year Whiteout FR-S
https://static.ed.edmunds-media.com/..._toelink_a.jpg On many aftermarket control arms, the bracket is removed and the cable can get in the way when running wider fitments. Most people will simply use a few zipties placed strategically to solve the issue. Just be sure to not make them too tight and the cable still need to be able to move on the inside. -Ian |
03-26-2022, 11:49 AM | #2538 |
After going through the 182 pages I’ve learned a lot!!!
I am currently on stock suspension with no modifications on my 13 BRZ. Just bought some Option Labs R716 18x9.5 +35 offset. Looking to run them on 255/35/18 Firehawks Indy 500 Will these fit on stock suspension? After reading I know 38 offset will rub strut, but hopeful I’ll be ok with 35 offset |
03-29-2022, 12:39 PM | #2539 | |
-Ian
The Following User Says Thank You to APEX Race Parts For This Useful Post: | Tatsu333 (03-02-2024) |
03-31-2022, 11:05 PM | #2540 | |
04-02-2022, 09:36 PM | #2541 |
Drives: Some RX-7s
I just did mine!
265/35/18 A052 Titan 7 T-S5 18x9.5 +40 Tarmac 2 Clubsport, camber maxed out in the slotted hole Subaru conical washers Pedders offset front strut top mounts No other changes from OEM. Slightly rubs sometimes and throws rocks all over the place. I love it. |
The Following 6 Users Say Thank You to colinshark For This Useful Post: | ACT86 (04-03-2022), brandonblt2 (09-25-2022), JD001 (03-03-2024), PulsarBeeerz (04-03-2022), SuperTom (04-02-2022), Tatsu333 (09-24-2022) |
09-22-2022, 10:42 PM | #2542 |
Financial Distress
Drives: 2017 GT86 325WHP
18x9.5 +40 on 275/40/18 Nitto NT01
Ask me anything, here's the specs:
- Volk TE37SL 18x9.5 +40 - Rays Closed-End Lug Nuts - Nitto NT01 275/40/18 R - Nitto NT05 265/35/18 F - HKS Hypermax GTIV Coilovers Front: No modifications, zero rub, full lock, all bumps Rear: Pulled rear fenders, trimmed rear bumper inside and inner bumper clip, doesn't rub daily driving unless going over train tracks or a nasty bump, it will graze the rear bumper. Clears the fender 150% |
09-24-2022, 10:49 PM | #2543 | |
Drives: 12'250,16'bmw S1Krr,16' 636,16BRZ
this looks great. Do you have any close up pics of the areas you trimmed in the rear? |
11-28-2022, 11:50 AM | #2544 |
Financial Distress
01-15-2024, 04:50 PM | #2545 | |
Drives: 2013 FRS
Looks amazing. Make me feel better that my te37sl 18x9.5 +40s, with 255/35/18 all around will work hopefully without rolling or pulling the fenders. So the only suspension mods your running are coilovers? No lcas or anything? |
01-16-2024, 08:51 AM | #2546 |
Anti stance.
Not as meaty as some of you boys…
245/40/17 RE-71RS on Titan 7 17x9 +37 with extended studs and titanium lug nuts. Tarmac 2 and TRD sway bars. |
The Following 4 Users Say Thank You to Tokay444 For This Useful Post: |
01-16-2024, 11:35 AM | #2547 |
Drives: 17 Asphalt 86
17x9 +35 RPF1
RCE yellow+Bilstein B6/ pedders strut Mount 245/40R17 RS4 Roughly -2°F/-2°R camber Tires fit wide for 245s No rubbing issues, fitment pretty much perfect without running excessive camber for mostly street use. |
The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | Racecomp Engineering (01-17-2024), Tatsu333 (03-02-2024) |
03-01-2024, 11:38 PM | #2548 |
Drives: 2013 Subaru BRZ / 2013 Scion FRS
hello so I'm experiencing a slight problem, I finally upgraded my wheels and am now there is slight rub whenever I hit a small bump in the road.
Currently running 18x9.5 5x100 255/35 and I'm on Tien coils. And no I don't have my fenders rolled. Any thoughts on what might fix this? |
Similar Threads | ||||
Winter Tire Review Thread (Please contribute) | pastuch | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 344 | 03-13-2024 05:49 PM |
Wheel Directory: Forgestar F14 18x8.5 +38/18x9.5 +38 | ScionFR-S | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 97 | 09-09-2015 06:32 PM |
Meaty rubber on flush spoke rims? | red_comet | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 16 | 06-14-2013 12:21 PM |
Official wheel/tire fitment thread needed | empower-auto | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 4 | 06-22-2012 01:40 AM |
The Wheel and Tire Fitting Thread | EvoFanatic | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 2 | 03-15-2012 03:05 PM |
