12-31-2016, 06:38 PM | #24753 | |
chicken tonight
12-31-2016, 06:41 PM | #24754 | |
12-31-2016, 06:44 PM | #24755 |
chicken tonight
Meh, as long as you get the idea the way you get there doesn't really matter. Just need to forward bias the diode through an ammeter, preferably a digital one.
You should check forward bias voltage before you disconnect any of them. Fire it up and measure the voltage across 1 and 2.
12-31-2016, 06:53 PM | #24756 |
12-31-2016, 06:54 PM | #24757 |
chicken tonight
http://www.mouser.com/Chemtronics/To...120p?P=1z0zl9n
...and a hot soldering iron. I suggest the chemtronics 80-3-5. Fluxed is better for wicking. Chemtronics is good stuff. Hand operated solder suckers suck ass. Electric ones are better than wick but they're $$$.
12-31-2016, 06:56 PM | #24758 |
chicken tonight
The Following User Says Thank You to Ultramaroon For This Useful Post: | humfrz (12-31-2016) |
12-31-2016, 06:59 PM | #24759 | |
I got it off by jumping back and forth while applying pressure |
12-31-2016, 07:07 PM | #24760 | |
chicken tonight
Also, those components are cheap enough that you might consider getting a few different ones and test them for suitability. At least get extras for when you fuck up. Ok, so get diodes that forward bias at 3 Volts.
12-31-2016, 07:14 PM | #24761 | |
12-31-2016, 07:50 PM | #24762 |
Wayward Member
Drives: Hot Lava 86
This shit seems too technical to be random.
The Following 2 Users Say Thank You to Nevermore For This Useful Post: | Allch Chcar (01-01-2017), finch1750 (01-01-2017) |
12-31-2016, 08:22 PM | #24763 | |
Drives: Feet
12-31-2016, 08:25 PM | #24764 |
Drives: Neptune GR86
#prebuiltpeasants
The Following User Says Thank You to Andrew025 For This Useful Post: | Phijkchu (12-31-2016) |
12-31-2016, 08:26 PM | #24765 |
The Following 3 Users Say Thank You to Ashikabi For This Useful Post: |
12-31-2016, 08:50 PM | #24766 |
chicken tonight
did you connect one of the test leads to either 1 or 3, and the other test lead to one of the pads on the PCB? Make sure you are set to measure current.
Similar Threads | ||||
Language Rant Part Deux | MuseChaser | Off-Topic Lounge [WARNING: NO POLITICS] | 43 | 04-23-2017 07:55 PM |
Random thoughts thread | MrVito | Off-Topic Lounge [WARNING: NO POLITICS] | 37188 | 02-25-2016 10:00 AM |
Random Rubber Part | OoLong | BRZ First-Gen (2012+) -- General Topics | 8 | 01-28-2014 10:31 AM |
Crew Carshow : Part Deux 9/7/13 | saiyajinimports | Great Lakes | 0 | 08-17-2013 05:18 AM |
