05-16-2024, 02:20 PM | #24613 |
Geo Tyrebighter Esq
Drives: '13 scion fr-s
"Lower to da groun' " is an aesthetic affectation that has ruined more cars than you can count on the 5000 fingers of Dr. Terwillager.
It's something you take on if you're using it only on a track with known deviations. Then you take it home and refurbish the worn CVs and set it up for the next known racetrack. It's not a rational thing to do if you're driving it everyday on publicly maintained torture tests.
"I gotta rock." -- Charley Brown |
The Following 3 Users Say Thank You to bcj For This Useful Post: |
06-06-2024, 01:17 AM | #24614 | |
Drives: 17 Asphalt 86
I'm sure Andrew @Racecomp Engineering can chime in. My setup always looks monster truck at 86 meets but I can use the car basically anywhere without low car problems. Last edited by RToyo86; 06-06-2024 at 09:43 AM. |
The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | Racecomp Engineering (06-06-2024), StraightOuttaCanadaEh (06-06-2024) |
06-06-2024, 01:23 AM | #24615 |
On that subject... I swapped some 215/45 RS4s on stock wheels to autocross and track with.
Reduction in meat is real. Also did whiteline diff bushing inserts. Intially didn't think there was much NVH but there definitely is living with it. Going to try pulling one of the bushings out as recommended. |
The Following 3 Users Say Thank You to RToyo86 For This Useful Post: |
06-06-2024, 09:56 AM | #24616 | |
I'm at about 20/25mm lower than stock on my coilovers with OEM top mounts. Low enough to not look stock but not low enough to be a problem where I drive. Living in the city means compromises. The potholes, constant construction, and rippled pavement is a legitimate clearance concern if nothing else. But I can walk to get excellent tacos so... We've got plenty of travel on our coilovers so you could try a bit lower, but you certainly don't have to! - Andrew |
06-06-2024, 10:26 AM | #24617 |
helmholtz resonator
Drives: '15 ultramarine
I had about a qt too much oil in the engine, so I got one of those $7 pumps from Harbor Freight and took a bit out thru the dipstick tube. Runs much better now.
06-06-2024, 01:59 PM | #24618 | |
Wes
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | Racecomp Engineering (06-06-2024) |
06-06-2024, 02:46 PM | #24619 | |
Drives: 1993 Caterham HPC Evo
Living life on the edge, less crowded, better view!
2018 tS Still in the family. |
06-06-2024, 03:20 PM | #24620 |
Wes
Yes sorry, I should have specified that I would also combine the smaller rim with a "meatier" tire. But I was also implying that the larger diameter wheel/tire combo is heavier and is detrimental to comfort.
Instagram: @gt86ws
The Following User Says Thank You to StraightOuttaCanadaEh For This Useful Post: | Stephen W. (06-06-2024) |
06-06-2024, 08:48 PM | #24621 | |
Drives: 2020 Toyota GT86
I did this myself going to 16" wheels and the ride comfort is massively improved.
This post sent using 100% recycled electrons.
The Following 2 Users Say Thank You to bucketfoot For This Useful Post: | StraightOuttaCanadaEh (06-07-2024), Wally86 (06-06-2024) |
06-06-2024, 10:52 PM | #24622 |
Tire choice can make a difference as well.
ECS02 ride surprisingly good for a UHP tire. RS4... Not so much |
The Following User Says Thank You to RToyo86 For This Useful Post: | StraightOuttaCanadaEh (06-07-2024) |
06-07-2024, 09:15 AM | #24623 | |
Drives: 2017 BRZ series.yellow
It's been a while since I put my RCE T2's on and set ride height, so I don't remember exactly, but I thought I set them close to RCE's recommendations. This is how she looks with 17x9 +35 wheels, 255/40 tires and -4 camber up front, -2 in the rear. I presonally think it's great and not monster truckish at all. |
The Following User Says Thank You to Breezio For This Useful Post: | Wally86 (06-07-2024) |
06-07-2024, 12:48 PM | #24624 | |
Wes
Yours looks good
Instagram: @gt86ws
06-07-2024, 03:45 PM | #24625 |
RCE yellows on 17x9, 245/40
Next to my brother's new red BRZ on unknown spring, maybe sport lines. My car looks monster truck next to anything not stock |
The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | Breezio (06-08-2024), StraightOuttaCanadaEh (06-07-2024) |
06-08-2024, 12:31 AM | #24626 |
The Following User Says Thank You to Breezio For This Useful Post: | StraightOuttaCanadaEh (06-09-2024) |
Tags |
:popcorn:, :popcorn: funny tags, nsfc, rice rice baby |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got My Car Today!!!!! First 86!! #81 | Juanito08 | Scion FR-S / Toyota 86 GT86 General Forum | 7 | 05-22-2012 04:54 PM |
If my FRS was here already, today I would... | bestwheelbase | Scion FR-S / Toyota 86 GT86 General Forum | 101 | 05-12-2012 06:20 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
