Old 08-04-2014, 01:16 AM   #225
Jive Turkey
the tuna, no crust.
Jive Turkey's Avatar
Drives: 2014 Hachiroku of the year
Originally Posted by White64Goat View Post
When you made the 2 dash/radio trim pieces into one piece, did you reinforce the backside of it or just glue it together and bondo it?
plastic weld together plus a reinforcement strip on the back. a bit too thin to just glue IMO.
Jive Turkey is offline   Reply With Quote
Old 08-07-2014, 06:34 PM   #226
jason.h
Drives: Silver BRZ Limited
I used some high quality resin with some fiberglass bondo to smooth the top. Seems to hold quite well. I was able to twist/flex it without it breaking.
jason.h is offline   Reply With Quote
The Following User Says Thank You to jason.h For This Useful Post:
Jive Turkey (08-08-2014)
Old 08-07-2014, 07:11 PM   #227
asdf
Loading...████████] 99%
asdf's Avatar
Drives: #0517
Originally Posted by disgruntld View Post
I love the Voodoo shift knobs by Thompson Automotive. I had em in both my Miatas, my Mustang and now in my BRZ. For our cars they offer crinkle black, piano black, spun silver and pearl silver. It's a simple thread on ball, but they sit lower than most so I don't know if that's something you'll be interested in. http://www.thompson-automotive.com/voodoo.html
those look nice, but theres nothing for the reverse lockout...so just a ball won't work. its very similar to the knob i already have so i'll most likely re-spray the knob i have now. for now i'm swapping back to OEM, it flows a bit better.
the reverse lockout goes up into the shift knob (the opening is bigger than just the thread for the shifter). love mine!
http://www.ft86club.com/forums/showthread.php?t=9079
Love your interior! looks amazing
asdf is offline   Reply With Quote
The Following User Says Thank You to asdf For This Useful Post:
Old 09-09-2014, 11:27 AM   #228
Jive Turkey
the tuna, no crust.
Im thinking Red Alcantara shift boot next to kind of make everything POP.
The Following 2 Users Say Thank You to Jive Turkey For This Useful Post:
civicdrivr (09-28-2014), WhiteFRS69 (09-09-2014)
Old 09-26-2014, 08:52 PM   #229
Jive Turkey
the tuna, no crust.
The Following User Says Thank You to Jive Turkey For This Useful Post:
Old 09-27-2014, 06:10 PM   #230
TestaRossa
TestaRossa's Avatar
Drives: 2013 DGM BRZ
Really hope you can maybe work with a manufacturer and mass produce the door-strap. Been wanting something like that since day 1 of owning this car
Saorri for mah bad English
TestaRossa is offline   Reply With Quote
Old 09-29-2014, 08:17 PM   #231
sofargone561
Drives: frs
This is awesome!
sofargone561 is offline   Reply With Quote
Old 09-29-2014, 11:18 PM   #232
quality_sound
Drives: '15 BRZ Series.Blue
Did you have to extend the wires at all? I'm going to move my start button somewhere else and was curious.
quality_sound is offline   Reply With Quote
Old 09-30-2014, 03:20 AM   #233
NissanGuy
NissanGuy's Avatar
Drives: Strangely.
I still want that too! Jive, the next time you have your door apart, the people want pics!
Yes he did.
NissanGuy is offline   Reply With Quote
The Following User Says Thank You to NissanGuy For This Useful Post:
Teclis (01-28-2015)
Old 09-30-2014, 05:30 PM   #234
Jive Turkey
the tuna, no crust.
yes you have to extend the wires. i'm warning you all, the wires are EXTREMELY THIN.
this means that you should think about where you cut it to extend it, if you strip too much then you'll be screwed, i came very close to this.
also, to mount the button itself you NEED the little area its mounted into, you just need to cut it out and glue it to where you want it and then mold it, if you look through old photos, you'll see what i mean by this.
as far as the doors, its just something i did for myself, its still not perfect but it works fine. you have to pull the strap towards the front of the car, no towards the inside of the car, its hard to explain but once you use it you'll see what i mean.
i've actually contacted renspeed, who makes the OEM kit for VW's but they said they would not like to do this...so basically mine are and will be one off.
i am debating making something but i just don't have the time. the information in this thread is enough for someone to do this at home, i think i documented it pretty well, those go-kart cables are how mine is connected, there probably is a better way but it would take a bit more engineering, and there isn't that much room to work with here.
my pm box is always open to questions, i'd be happy to help.
i actually have a rattle in my driver door...if i take it apart to add more dynamat, i'll snap some photos for sure.
The Following 3 Users Say Thank You to Jive Turkey For This Useful Post:
quality_sound (10-06-2014), Teclis (01-28-2015), TestaRossa (09-30-2014)
Old 09-30-2014, 09:26 PM   #235
Kiske
Kiske's Avatar
Drives: RX-7 / BRZ
Meh on the red boot, just might be too big of an ammount, considered red anodized parts such as the hvac crontrols, reverse lockout?
The Following User Says Thank You to Kiske For This Useful Post:
Jive Turkey (10-01-2014)
Old 10-01-2014, 12:25 PM   #236
onefitz
Drives: 13 GBS BRZ
Sounds like you need some sort of pivot arm. So when you pull the strap out, it rotates and pulls the release cable forward. Add in a spring tensioner to get the reset right.
onefitz is offline   Reply With Quote
The Following User Says Thank You to onefitz For This Useful Post:
Old 10-01-2014, 02:03 PM   #237
Jive Turkey
the tuna, no crust.
we will see how the boot looks, i'm optimistic. it should go nicely with the Red STi button. if not i'll go back to my leather, it okay with it either way.
issue is the tiny amount of space that i have. but yea, something like that would be ideal, but its going to be hard to make. i've made countless trips to home depot/lowes/hobbystores/etc.
and the renspeed ones don't work here.
Old 10-06-2014, 10:58 PM   #238
quality_sound
Yes he did.
Thanks for the info. I want to move mine to the OEM key location. If I move the seat heater switches it'll be to install the controller for my processor.
DCW Carbon Fiber interior items! Center console Plaques / Interior panels doggy Interior Parts (Incl. Lighting) 143 10-11-2013 11:17 AM
LED interior conversion kits (interior), USA stock & warranty WTF Interior Parts (Incl. Lighting) 0 05-22-2013 10:17 PM
Video: Toyota FT-86 II Concept Design Explained by "Dezi" Nagaya (Design Manager) Hachiroku Scion FR-S / Toyota 86 GT86 General Forum 58 04-11-2011 09:03 PM
