05-28-2023, 01:19 AM | #225 |
Off to the track!
Drives: '14 Lava 86, '13 WRB BRZ
Car came back from alignment and wheel bearing jail. Fresh axles in the rear, new tires mounted, Whiteline bump steer kit (ball joints + outer tierods), and new wheel bearings. Before heading to the track, swapped rotors for blanks and put in the track pads + full nut & bolt check.
Went out to Strawberry Creek today, great day at the track. Spent all day messing with damper settings to balance with the aero package and dusting off the cobwebs. By the end of the day times were pretty consistent back to back and quicker than last season, so that is a win. Changes since 2022: fresh tires, fresh drivetrain fluids, aero package, header with flex fuel kit. |
The Following 7 Users Say Thank You to villainous_frx For This Useful Post: | autoracer86 (05-28-2023), Dzmitry (05-31-2023), jongers (05-28-2023), NoHaveMSG (05-29-2023), RedReplicant (05-28-2023), RToyo86 (05-29-2023), Ultramaroon (05-28-2023) |
06-18-2023, 11:08 AM | #226 |
Off to the track!
Did some autox yesterday, the splitter definitely did not help. Collecting cones all day due to the extra 1.5" it sticks out from the bumper on the sides.
Course was a pretty quick and flowing ~50 seconds, 11 runs (6+5). After the first two drift sessions on a super cold course clocked in a number of 49xxx back to back, and after lunch a 48.5xx. Fun was had by all, so that's what matters to me. On the drive home I think an exhaust gasket gave up the ghost, as suddenly my feet were a lot louder. Going to check over the whole system while watching F1 today. |
The Following 3 Users Say Thank You to villainous_frx For This Useful Post: |
06-18-2023, 07:13 PM | #227 |
Off to the track!
Pulled most of the exhaust off the car and cleaned all the flanges and then threw it back together with new gaskets. No leaks thus far.
Header gasket off cyl 4 gave up, looks like the bolt got about 1/8 turn loose. While everything was apart I started cleaning the oil leaks off the block and installed some brand overpipe I got a few months back in an effort to solve some rattling from the OEM one. I can confirm it did infact do this... not sure if it's the bends being slightly different or just the angle it sits without a heat shield. After that, drove down to Lugnutz and did a quick oil change. 5w30 oil pressure is comically higher than 0w20 just cruising down the highway at temp. |
The Following 4 Users Say Thank You to villainous_frx For This Useful Post: |
07-16-2023, 08:21 PM | #228 |
Off to the track!
So the rattle mentioned in last post moved and was the bent exhaust tip. You know the one...
Chopped both tips off and replaced with Blitz VSR clamp on replacements. Also acquired a slightly better condition rear bumper to wrap over. |
The Following 6 Users Say Thank You to villainous_frx For This Useful Post: | Dzmitry (07-19-2023), KMA KiCKz (07-17-2023), RedReplicant (07-17-2023), RToyo86 (07-17-2023), Ultramaroon (07-17-2023), Wally86 (07-21-2023) |
07-24-2023, 12:16 AM | #229 |
Off to the track!
Car works. Laps were quick, sun was hot, TT2 Lotus pitted next to me was a good sight.
Was having issues getting the car to rotate :/. I believe this is due to cranking the damping stiffer to compensate for the wing. I suppose the next logical thing would be stiffer rear spring to allow me to soften the suspension a hair. Always something with cars. |
The Following 7 Users Say Thank You to villainous_frx For This Useful Post: | Code Monkey (07-24-2023), Dzmitry (07-26-2023), jongers (07-29-2023), KMA KiCKz (07-27-2023), RedReplicant (07-24-2023), Ultramaroon (07-24-2023), Wally86 (07-25-2023) |
07-30-2023, 01:45 AM | #230 |
Off to the track!
I should probably wash this car. Probably
The Following 2 Users Say Thank You to villainous_frx For This Useful Post: | KMA KiCKz (07-30-2023), RedReplicant (07-30-2023) |
07-30-2023, 11:48 PM | #231 |
chicken tonight
Looks plenty clean to me
07-31-2023, 05:18 PM | #232 |
Drives: frs
07-31-2023, 07:20 PM | #233 |
Drives: 17 Asphalt 86
I see 7 dirts
Time to part out. |
The Following 2 Users Say Thank You to RToyo86 For This Useful Post: | NoHaveMSG (07-31-2023), villainous_frx (07-31-2023) |
07-31-2023, 07:31 PM | #234 |
chicken tonight
lol
07-31-2023, 08:19 PM | #235 |
Off to the track!
The bugs on my front bumper remind me of the last time I passed through the US.
"Do you have any livestock or animals in the car?" "Nope, just the dead bugs on the front bumper" "Sir, please pull off to the side and bring your passport inside" |
The Following 5 Users Say Thank You to villainous_frx For This Useful Post: | new2subaru (08-04-2023), NoHaveMSG (07-31-2023), Racecomp Engineering (08-01-2023), RedReplicant (08-01-2023), Wally86 (08-03-2023) |
08-06-2023, 09:18 PM | #236 |
Off to the track!
8/6 Day in Edmonton.
The Following 2 Users Say Thank You to villainous_frx For This Useful Post: | Ultramaroon (08-06-2023), Wally86 (08-07-2023) |
08-12-2023, 10:23 PM | #237 |
Off to the track!
Did a full nut + bolt check for a track day later this week.
Also picked up a TRD Duracon shift knob from YAJ. I like the shape, however it sits lower than the Vertex ones I have. Earlier in the week I acquired the new Blitz shift knob. Don't love the hand feel, weight, or the height. One for the collection or another car. |
08-12-2023, 11:52 PM | #238 |
chicken tonight
It should light up when it's time to shift.
Similar Threads | ||||
Beginner STX Build Whiteout FRS Build Thread | Hachi86Roku | Tracking / Autocross / HPDE / Drifting | 21 | 03-31-2020 07:52 PM |
[B is for Build] BRZ resurrection build | im_topher | Member's Car Journals | 49 | 03-05-2018 09:41 AM |
HKS stroker kit build going onto edelbrock SCd e85 FRS - build questions | Corradooo | Engine, Exhaust, Transmission | 2 | 11-25-2017 07:16 PM |
Superpenguin's "Not Another Build Thread!" Build Thread | superpenguin | Member's Car Journals | 7 | 06-17-2015 04:00 PM |
No build date on passenger side sticker, how to determine build date? | BBYZILA | Scion FR-S / Toyota 86 GT86 General Forum | 5 | 01-20-2015 10:14 PM |
