06-06-2013, 01:54 PM | #211 |
Drives: Scion FRS, Raven
So, after 60+ miles of driving, no CEL. Seeing as I got a CEL with p0351 while leaving the dealership after my DI seal replacement (and many times subsequent), I think I can safely assume the issue has been resolved. If I had to guess, the breakdown of what causes this goes something like this:
1) Coil goes bad due to overheating (will know more once I take my old coil apart) 2) Bad coil causes overheating in the cylinder. This could be caused by a few things including misfires and/or ECU leaning the mixture in cyl #1 due to incomplete fuel burn. 3) Overheating causes premature degradation of DI seals. I would get the p0351 codes PRIOR to the seals having gone bad and the firecrackers starting. This tells me the issue is caused by the coils having gone bad. I have applied the JDM Transient Ignition Retard timings to my ROM via epifan's BRZedit software. Shout out to epifan for being on top of the many different ROMs out there and providing the JDM ROM to me for comparison and merging. |
The Following User Says Thank You to d4m45cuz For This Useful Post: | feldy (11-27-2013) |
06-06-2013, 02:17 PM | #212 |
Thupercharged
Just an update, I have a direct injector seal tool coming on its way to my house. Its the same part number as posted in the previous page of the thread, I might pull my injectors just to see how well the tool works and to check my injector seals for damage
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
The Following User Says Thank You to DJCarbine For This Useful Post: | CircuitJerk (06-06-2013) |
06-06-2013, 03:03 PM | #213 |
Drives: SWP BRZ
Great! keep us posted!
06-06-2013, 03:43 PM | #214 |
Drives: FRS
Keep us posted. Perhaps a DIY for seal replacement? I know every owner on earth would appreciate it.
06-06-2013, 03:51 PM | #215 |
I Love custom Turbo kits
Drives: Limited BRZ
Are you able to say where you got it and if there was a link it would be awesome.
06-06-2013, 04:13 PM | #216 | |
Thupercharged
Part# 09260-39020-01 sales@autotoolworld.com 1-877-570-6295
2013 FRS
The Following User Says Thank You to DJCarbine For This Useful Post: | Sportsguy83 (06-06-2013) |
06-06-2013, 04:14 PM | #217 | |
Drives: Limited BRZ
The Following User Says Thank You to Sportsguy83 For This Useful Post: | mad_sb (06-06-2013) |
06-06-2013, 04:15 PM | #218 | |
Drives: 2013 Asphalt FR-S
If you look at the per cylinder timing compensation maps, cylinders 1 & 2 have almost 4 degrees of timing pulled out from 3600 to 4800 .7 g/rev and up and 2.5 degrees pulled from 6800 to redline.... This could cause higher EGT's on 1 & 2 i think, or pehapse it's not enough retard to increase egt's and they are limiting power on 1 & 2 due to thermal concerns?????? It is very strange that #1 coilpack seems to go bad so often and the two could certainly be linked but I don't think the coilpack issue could cause detonation, but i am assuming the mode of failure is for the plug not to fire at all or very weekly when the coil pack has issues so.... I do agree that heat could be the major cause of coil pack failure and it's possible #1 gets the least air circulation or something.
~Namaste~ |
06-06-2013, 04:47 PM | #219 |
Drives: Moped
So now the latest possible way to fix this seal crap is:
1) New coils 2) Transient retards 3) Maybe new direct injectors (or seals if they haven't gone bad) Toyota/Subaru get your sh*t together |
The Following User Says Thank You to Lonewolf For This Useful Post: | wootwoot (06-06-2013) |
06-09-2013, 07:34 AM | #220 |
What's interesting about this issue, is the fact that many seals apparently did survive when people doubled the output by going FI (which is only possible with more pressure and with it temperature in the combustion chamber).
Maybe it's simply a manufacturing clearance/fitting issue (the tolerances given to the manufacturer(s) of the seals are not tight enough or the dimensions from seal to seal vary too much in the manufacturing process). Some seals simply have a looser fitting and those seals are now showing problems, since they can transmit less heat and can move more easily. |
06-09-2013, 10:20 AM | #221 |
Grip>Slip
Can any of you guys that have thrown the P0351 and are flashed with EcuTek check c:\Ecutek\proecu-SubaruBRZ.log (your filename may vary based on model) and do a search for P0351 to see if the code would show up when ProECU records and clears the DTCs after the flash process?
If it does, then others could check their logs to see if their cars have ever thrown it in the past (assuming they were reflashing somewhat regularly). |
The Following User Says Thank You to xjohnx For This Useful Post: | Astroboy (10-03-2014) |
06-10-2013, 12:19 AM | #222 | |
I am sure this just helped the failure accelerate. Also interesting to note it was also the longest drive I have done since installing FI an 1 hour and 15 minutes.
06-10-2013, 01:17 AM | #223 |
Drives: 2007 Mazda 3, New Raven FR-S 6mt
So your are saying if I am going to buy a Frs tomorrow it will have the fix of the popping sound just asking want to get good knowledge
06-10-2013, 07:00 AM | #224 | |
Drives: Scion FR-S
Sent from my SCH-I535 using Tapatalk 2 |
Similar Threads | ||||
Driver's side window seal/door seal | KAB-FRS | Issues | Warranty | Recalls / TSB | 255 | 01-01-2021 06:09 PM |
FRS-BRZ Port Fuel Injector (interesting) | Element Tuning | Engine, Exhaust, Transmission | 50 | 04-21-2016 04:26 PM |
Need Help - 2 codes thrown | jpit | Issues | Warranty | Recalls / TSB | 3 | 04-20-2013 12:41 AM |
Bulb codes | JDMenrique | Cosmetic Modification (Interior/Exterior/Lighting) | 1 | 02-17-2013 03:25 PM |
Dynosty FR-S/BRZ Fuel System Upgrades! Injector Dynamics ID850s! | Dustin@Dynosty | Engine, Exhaust, Bolt-Ons | 0 | 08-21-2012 05:03 PM |
