10-17-2016, 09:48 PM | #183 | |
Drives: BMW
10-22-2016, 06:41 AM | #184 |
Drives: 2017 Subaru BRZ Limited,Mazda Miata
I ordered the $20 cable below from Amazon. It came with v10.30.029 which installed and worked great on both a 32 bit Windows 7 and 64 bit Windows 10 machines.
https://www.amazon.com/gp/product/B0...?ie=UTF8&psc=1 |
10-23-2016, 06:06 AM | #185 |
Drives: Mazda3 2013 / Scion FR-S 2015
can we acess to the TPMS id and change it on the last version with the cable of TheRatsWon
10-24-2016, 05:22 PM | #186 | |
03-07-2017, 08:46 PM | #187 |
Can anyone help me out?
I purchased OE TPMS (Denso) sensors (picture below) and have tried resetting the codes via techstream. I keep on getting error for communication, even though I can see my OE TPMS sensor values and can access the ECU. Thoughts? |
03-07-2017, 09:06 PM | #188 |
Way out of my range of expertise here but what does the "Initialization Switch Off" mean? Shouldn't that e on to initialize?
03-07-2017, 09:27 PM | #189 |
Drives: 2016 Halo FRS
I been trying to set up techstream for months and gave up. Followed step and just can never seem to get it working
03-08-2017, 08:46 AM | #190 |
Isn't the TPS motion powered? How about shaking it to energize it and enter it in Tire 5 field
My 2016 Build thread TRD Exhaust with custom quad tips, TRD Lowering Springs,TRD Quick shifter,LED;DRL, Projectors, and turn signals. Re-badge, 86 Nanny, WinmaxW2 Pads, K&N Drop In, Antenna delete |
03-08-2017, 10:54 AM | #191 | |
1st86 Driver!
http://www.tirebusiness.com/article/...h-tpms-sensors
Visit my Owner's Journal where I wax philosophic on all things FR-S Post your 86 or see others in front of a(n) (in)famous landmark. What fits in your 86? Show us the "Junk In Your Trunk". |
03-08-2017, 11:30 AM | #192 | |
Drives: 2013 white limited BRZ
I had new TPMSs on my new wheels. What I was told by a tire installer and the Subaru service is that the computer on the car needs to "enable" these new sensors. The Aftermarket programming devices do not typically do this unless you get the ones that approaching $1k in cost. You can see that the car can read the sensors but will not use them until they are enabled. Took a while, but I got mine to work by having Subaru service getting them read in correctly. What took a while was one of the TPMS was bad and that just confused the issue even more on what the problems were. |
The Following User Says Thank You to Casey10s For This Useful Post: | Dadhawk (03-08-2017) |
03-10-2017, 12:54 PM | #193 |
Drives: GT86 C7P
03-23-2017, 10:46 PM | #194 |
Drives: 2019 Mazda Miata RF
So where is the latest hot ticket download link for Techstream software, which includes patching instructions? most links I tried are either broke, or didn't include the "fix".
Also, running Win10 64bit, anyone gotten the cable drivers to work on that? |
03-24-2017, 09:48 PM | #195 |
For those having issues with a serial number key, are you using Europe for the configuration?
Select Setup>Techstream configuration>Europe Version v10.30.029 works with Win10 64 bit, can't vouch for other versions. |
03-28-2017, 02:28 AM | #196 |
Drives: GT86 C7P
V10.30.029 Europe configuration worked well (with the procedure explained page 13).
But when updated the lastest version, ask me the key I feel I need back to previous version ... |
Similar Threads | ||||
TPMS Tools | developer | Wheels | Tires | Spacers | Hub -- Sponsored by The Tire Rack | 27 | 10-04-2021 01:28 PM |
anyone with a shop or tools | Tylub | Southern California | 0 | 05-14-2013 11:03 AM |
Tools? | Gost | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 35 | 04-03-2013 03:46 PM |
Tools for DIY maintenance? | F1point4 | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 19 | 08-08-2012 07:47 PM |
