07-10-2017, 02:08 PM | #183 | |
pessimistic skeptic
In that case, isn't it better to use a vacuum check valve on the intake manifold exit? Don't you think there can be pressure loss at the catch can and two pieces of hose connections before the PCV valve. |
07-10-2017, 02:12 PM | #184 | |
Drives: 2014 BRZ
I would suggest deleting the PCV valve entirely and running a barbed fitting in place. Not sure when I posted that, but I soon found out that STI valve was a piece of shit too.
JDL Auto Design///Turboback///Enkei///Tial///RSR///HRI Tuned
The Following User Says Thank You to Amputechture For This Useful Post: | mrg666 (07-10-2017) |
07-10-2017, 02:14 PM | #185 | |
Drives: Toyota GT86
Sent from my Pixel XL using Tapatalk |
07-10-2017, 04:05 PM | #186 |
I Love custom Turbo kits
Drives: Limited BRZ
I also ran a VTA catch can for years, using the top manifold PCV port (the one Kris is using for his boost gauge) as boost signal to a vacuum manifold for gauge and BOV signals. Setting up the PCV that way is OK to keep the stock PCV as it won't see boost.
Also the Fuel Pump should not be putting any different fuel pressure than stock. The FBM 485 pump kit just replaces the fuel pump, it still uses the stock fuel regulator inside the tank pump canister.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | Kris86 (07-10-2017) |
07-10-2017, 07:01 PM | #187 |
Drives: 2013 Asphalt FRS
that will work fine since you don't have a return system. go out for a drive and watch when you are at idle and wot make sure it stays around 56 pounds
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
07-11-2017, 03:20 PM | #188 |
Drives: RHD Gt86
looking to try and borrow a new MAF sensor and see also. don't know if this would be related to my problem, but just want to scratch everything off my list of possibilities
Toyota - Making Dreams A Reality
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission |
07-11-2017, 08:06 PM | #189 |
Drives: RHD Gt86
So got a MAF sensor to borrow out a car belonging to a friend.
It did NOT make one difference. so I decided just for the hell of it I'll unplug the MAF sensor and see what happens, it started up perfectly and idled perfectly in the "warm up" map at around 1500rpm, and then gradually came back down to around 900-1000 With the sensor plugged In I noticed that the wide band reads around ~17.~ which I think is why it won't idle because it seems to be starving for fuel, when I unplug the MAF sensor the car fires up and idles with the wide band reading ~11.6~12.1~
461hp on 91octane - JDL turbo GTX3076r GEN 2 - Mazworx CD009 transmission Last edited by Kris86; 07-12-2017 at 09:24 AM. |
07-11-2017, 11:55 PM | #190 | |
Drives: Toyota GT86
The Following User Says Thank You to BRX For This Useful Post: | Kris86 (08-22-2017) |
08-22-2017, 10:56 AM | #191 |
Drives: RHD Gt86
Hey guys,
so little update, been out of it for a while. I sent out my GDI injectors to be cleaned and tested at South Bay Injectors, also to have the seals replaced, turned out one of my GDI injectors were "not working the way it should be". so I went ahead and bought a brand new one and installed my 3 refurbished injectors and one new injector. my vacuum is reading quite a bit better (.37-.40 bar at idle), guess the seals did need changing. BUT, I STILL HAVE THE COLD START/NOT WANTING TO IDLE WHEN IN COLD START MAP PROBLEM. it would sometimes try to idle around 500rpm and then every now and then the rpms would jump up to 1700ish rpm and then back down to 500rpms and eventually stalling. once the car comes out of the cold start map, the car would idle perfectly. starts perfectly when hot also. I also notice that while free revving, the engine has a lean spot and a misfire around 2000-2500ish rpm. really getting frustrated now, haven't been able to enjoy my car for 8 long ass months now
08-22-2017, 11:00 AM | #192 |
Drives: Toyota GT86
Do you get any codes? I upgraded my injectors last week and when I tried to start it, it kept stalling and when it fired up it kept revving from 500-1500 like you mentioned. It threw a code, P062D, my direct Injector ECU wasn't grounding through the factory bracket for some reason. I wired it to one of the the ground bolts next to the battery and it started fine. I would check your Direct Injector ECU as it might be the culprit. It might be grounded but some wires or plugs might be loose.
08-22-2017, 11:25 AM | #193 | |
Drives: RHD Gt86
NO, I do not get any codes what so ever. I've thought about the direct injector ecu also, but I've back checked and triple checked and made sure to inspect all grounding points. U think I should try running a ground wire from the ecu bracket to the battery to try for the sake of it ? Just not sure because I never got this kind of code
08-22-2017, 11:29 AM | #194 | |
Drives: Toyota GT86
08-22-2017, 11:47 AM | #195 | |
Drives: RHD Gt86
so you do not have your Direct Injector Ecu mounted into the stock location anymore? or am I just seeing your picture from a weird angle? were your idle symptoms only when in the cold start map also?
08-22-2017, 11:49 AM | #196 | |
Drives: Toyota GT86
Similar Threads | ||||
Who's tired of the "Pedal Dance" and wants to be in real control of their car? | FT-86 SpeedFactory | Tracking / Autocross / HPDE / Drifting | 61 | 10-01-2015 07:44 PM |
I drive fast because the car feel "slow" | fang_gt86 | Scion FR-S / Toyota 86 GT86 General Forum | 65 | 05-04-2015 01:06 PM |
Most effective ways to make a "fast" NA car | Kronos | Engine, Exhaust, Transmission | 68 | 02-16-2014 01:59 PM |
XSXV: Nissan R34 Skyline from "Fast and Furious" | goat_cheese | Cosmetic Maintenance (Wash, Wax, Detailing, Body Repairs) | 29 | 10-25-2012 04:15 PM |
come and hoon they say.... it will be "like Fast and the Furious", they say... | davey90 | AUSTRALIA | 5 | 10-23-2012 12:11 AM |
