01-26-2017, 10:56 PM | #183 |
Drives: 2013 Scion FR-S Series 10
If I could make this work and pass a plug in obd emissions I'd be all set. Sadly I don't believe it is possible with that Motec setup
Current Mods: Eibach Sportlines/ Borla UEL Header/ Invidia N1 Catback/ OFT Stage 2 UEL E85 Tune/ Enkei EDR9 18x7.5
01-26-2017, 10:58 PM | #184 |
Drives: 2013 FRS Whiteout
Why won't the link embed the video ?
01-26-2017, 10:58 PM | #185 |
Drives: 2013 FRS
The Following User Says Thank You to ft86me For This Useful Post: | Pure Automotive (01-26-2017) |
01-26-2017, 11:31 PM | #186 |
Fiebru
Drives: Scion FR-S and Integra Type R
Congrats, I love it!
Current Cars:
2017 White Platinum Ford Fiesta ST 2013 Raven Scion FR-S 2012 Spruce Mica Toyota Tacoma TRD Off-Road 2000 Phoenix Yellow Acura Integra Type R |
The Following User Says Thank You to Draco_PR23 For This Useful Post: | Pure Automotive (01-26-2017) |
01-27-2017, 07:29 AM | #187 |
will you guys be making a harness for the m150?
01-27-2017, 07:31 AM | #188 |
That Guy
Drives: 2013 asphalt FRS MT
I can't open it at work. :'(
01-27-2017, 08:16 AM | #189 |
Drives: vrooom...
Here you go embedded:
[ame="https://www.youtube.com/watch?v=YR_kQgv4lts"]Pure Automotive's Plug and Play 2JZ Swap Electronics Package - YouTube[/ame] |
The Following 7 Users Say Thank You to M1K3 For This Useful Post: | Calum (01-27-2017), ILLSMOQ (02-10-2017), Kris86 (02-17-2017), Pure Automotive (01-27-2017), R2RO (02-04-2017), SkAsphalt (02-09-2017), Sportsguy83 (01-27-2017) |
01-27-2017, 08:28 AM | #190 |
01-27-2017, 08:58 AM | #191 |
I only ask because I have a M150 already and was interested in the possible expandability for it.
01-27-2017, 10:18 AM | #192 |
Drives: 2013 Ultramarine FR-S
When linking youtube videos. Take the "S" out of "HTTPS" and it will embed.
The Following User Says Thank You to DustinS For This Useful Post: | Pure Automotive (01-27-2017) |
01-27-2017, 10:33 AM | #193 | |
I Love custom Turbo kits
Drives: Limited BRZ
I think it needs to be youtube dot com/etc..
The Following User Says Thank You to Sportsguy83 For This Useful Post: | DustinS (01-27-2017) |
01-27-2017, 10:51 AM | #194 |
Drives: 2JZ FRS
The a and b connectors on the 150 are mostly inputs and outputs, and the extra can bus channels. I have a 150 in my swap and only have a couple extra inputs going to those connectors. I could have gotten away with a 130 on mine and I have individual egt's, coolant pressure, exhaust map, etc
01-27-2017, 02:02 PM | #195 | |
01-27-2017, 03:19 PM | #196 |
Drives: 2JZ FRS
i was in the same spot, already had the 150 from my built fa20 when we started doing the 2j swap/package on this car and realized a 130 would work just fine and save some money. i need to match up the diagrams again but im almost positive the m130 connectors on our swap harness will plug right into c and d on the 150 ecu, then the a and b can be populated as you add more down the road. my initial harness only has c and d populated, i didn't add anything to a or b until later on.
Similar Threads | ||||
Budget V8 Swap (under $10,000) | wutsaiu | Engine Swaps | 146 | 06-11-2018 08:53 AM |
Pentosin Trans Fluid Swap | Motul 300 Diff Swap | Impressions | Dezoris | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 15 | 06-06-2017 10:54 PM |
WTB A/T BRZ/FR-S CA Budget 21k | Euan | Want-To-Buy Requests | 4 | 07-20-2015 11:50 PM |
$2K Budget. What Would You Do? | Skippman | Electronics | Audio | NAV | Infotainment | 46 | 02-22-2013 11:23 AM |
There goes my MOD'ing Budget | RedRocket | Scion FR-S / Toyota 86 GT86 General Forum | 35 | 10-19-2012 08:14 AM |
