10-25-2018, 09:56 AM | #1891 |
Drives: 2016 Subaru BRZ Series.Hyperblue
12-20-2018, 09:19 AM | #1893 |
01-24-2019, 06:50 PM | #1895 |
Is anyone here running the Avo kit with a built motor? Just curious where this kits power limit is.
I'm curious at what point the curvaceous intercooler piping would become a restriction. And when their stage 3 turbo will run out of steam. Sent from my Pixel XL using Tapatalk |
01-28-2019, 01:44 AM | #1896 |
Remember me?
Drives: BRZ Series.Blue
Anyone else have an avo kit for sale?
01-31-2019, 01:37 PM | #1897 |
Drives: vrooom...
03-22-2019, 09:20 AM | #1898 |
Drives: 2012 Toyota 86 GTS (Orange)
Hey guys, I was going to get a Stage 3 AVO turbo kit for my 86 but ran into some confusion. I have been trying to figure out the difference between stage 2 and stage 3 turbo's and I am under the impression it's just a billet turbo that is rated for better flow? Can someone please confirm this for me. Also I am thinking of running low boost numbers as I am running on a stock engine. Would it be possible to tune it for flex fuel with boost varying from 8psi up to 13psi (using a GFB electronic boost controller)?
Also a very big confusion is what the car would feel like (in terms of spool time and where power comes on) in comparison to a stage 1 or 2 avo turbo. I only have this confusion as the kits have the same turbo but stage 3 is "billet". I am aiming at getting increased power but still have boost coming on as early as the other kit's turbos. |
03-22-2019, 09:32 AM | #1899 |
I hope someone answers you cause I have the same questions! Except I'm weird and I prefer the sensation of a more laggy turbo down low that surges up top
04-12-2019, 01:29 PM | #1900 |
Drives: CBS BLACK 2013 Subaru BRZ
Hope I’m putting this in the right spot ! So I’ve had a stage 2 kit for about 6 years and have just found a crack in the down pipe weld . Does anyone know where I’m supposed to order this and is AVO still have a rep in the US . If so how do you get ahold of him or her . Having to pull the engine soon and just want to have all the parts so I don’t have to do the work twice.
04-13-2019, 12:10 PM | #1901 | |
The Following User Says Thank You to Grady For This Useful Post: | nopocrakr (04-23-2019) |
04-13-2019, 12:12 PM | #1902 |
Would it be ok to just have the crack patched up by a welding shop? Would probably take them 2 minutes and save you some $$ ?
The Following User Says Thank You to jRuN For This Useful Post: | nopocrakr (04-23-2019) |
04-12-2020, 01:30 PM | #1903 |
Smartass
Drives: Toyota GT86 & Impreza STi
Boost Leak?
Hey guys,
having my AVO Kit now for 6 years and ~100k km / 63k miles it is still going strong. Recently I've noticed a loud surging noise when under load & boost. I haven't noticed a drop in power and also Torque doesn't indicate any loss in boost pressure (tuned to 0.6 bar / ~8,7 psi). But it does sound like a boost leak. I checked all the accessible tubing and tightened some of the clamps, but the noise is still there. So I removed the original airbox, connected an old can with a valve and put the whole system under pressure with an air compressor. Video: I've observed three things: 1. the tubing connecting the blow-off valve to the intake pipe seems to leak slightly 2. the system didn't hold the pressure, but I haven't cranked the engine to TDC, so the valves probably weren't shut 3. oil was burbling from the oil filter adapter probably due to 2. Now: is that leaky connection between the BOV and the intake piping an issue? Are there any known spots for boost leaks? Any other ideas on why I hear air surging while under boost?
Toyota GT86, Leather, JBL-Sound, Aero-Kit, inferno orange
MODS |O.Z Leggera 18 x 8,5|Front:Tarox B32|Rear:OEM+EBC GreenStuff|Braided Lines|Milltek CAT-Back & Overpipe|Motiv Concepts catted Frontpipe| AVO Turbo|AVO breather tank|Mishimoto Oilcooler|Exedy Stage 1 Clutch|BeatSonic Sharkfin|TRD Ducktail|TRD Aero cover|Valenti blinker |
04-12-2020, 06:41 PM | #1904 | |
Drives: Raven 2016 FR-S
Okay, after messaging Lee with AVO, he informed me that the billet turbo flows 25% better and is capable of 400 whp, but the upgraded intercooler and a 3" exhaust are needed to reach that number. Also, it has the same actuator (5 to 8 PSI) as the stock one. My Tuner had me buy a plug and play boost controller. I ordered the billet turbo and bigger intercooler, but I have a built engine that can handle 600 whp daily that is going in. As soon as my engine and kit is installed (I am not going to run boost on a daily stock engine), I will update with my numbers |
Tags |
avo, avoturboworld |
Similar Threads | ||||
Innovate (Sprintex) Supercharger Owners Topic | DarrenDriven | Forced Induction | 9139 | 12-29-2023 10:58 PM |
FA20Club Turbo Kit Owners Topic | pixel67 | Forced Induction | 1531 | 09-09-2014 12:36 PM |
OFF TOPIC: Spotted a Gallardo | markmatley | Hawaii | 4 | 02-24-2013 04:26 PM |
Not another need to drive topic | Sargy | Mid-Atlantic | 5 | 11-27-2012 12:18 PM |
Can you close the topic please? | Standardsuspension | Brakes, Suspension, Chassis | 14 | 06-26-2012 05:14 PM |
