11-15-2015, 02:12 PM | #1835 | |
Grip>Drift
Drives: FRS
You need a front bar anyway. So I would start there. Sent from my iPhone using Tapatalk
The Following User Says Thank You to BlaineWasHere For This Useful Post: | swarb (11-15-2015) |
11-15-2015, 02:35 PM | #1836 |
The Stig's German cousin
As an alternative you could disconnect the rear sway bar, but you'll probably have a better car by upgrading the front.
The Following User Says Thank You to renfield90 For This Useful Post: | swarb (11-15-2015) |
11-15-2015, 05:56 PM | #1837 |
Detaching the rear bar is pretty common for Miatas, might make sense for you swarb just as a test, you should be able to reattach in between runs if it's bad. How low are you? Maybe the rear bar is preloaded creating some weird forces, adjustable endlinks might be the solution?
The Following User Says Thank You to strat61caster For This Useful Post: | swarb (11-15-2015) |
11-15-2015, 06:39 PM | #1838 |
I am lowered about 1.5-1.75 inches(I know too low, but I wanna look cool!).
The coilovers came with front end links about 2inches shorter. The rear ones are stock. They rear endlinks are pre-loaded a little too much sadly. How should I preload? 0 at static height? or slightly? I guess I will try a front sway bar and some rear end links. Anyone know a factory endlink(wrx?) that is slightly shorter than stock? Whiteline for sway bar or? I want an adjustable and probably just slightly bigger. |
11-15-2015, 06:57 PM | #1839 |
Grip>Drift
Drives: FRS
I ran stock endlinks for a bit with the Strano bar but because I so low (2 inches) I had to get whiteline links for clearance.
But I'm lower than you and I don't lift any tires ever. Sent from my iPhone using Tapatalk
11-15-2015, 07:37 PM | #1840 | |
Lots of variables at play here... Might also be driving style, still on the brakes to get weight up front whilst turning would make the car do this, but this isn't an FF or the stock suspension where you need to force the front to grip. Dialing back on the trail braking may settle the car better. |
11-16-2015, 08:58 AM | #1841 |
AutoX Nut
Drives: 2022 BRZ
Sorry to interrupt the technical discussion, but I just wanted to put in a plug for my Nameless header that is for sale in case someone is looking for some STX goodies for next season:
http://www.ft86club.com/forums/showthread.php?t=97529 |
11-18-2015, 02:45 PM | #1842 |
Drives: 2013 Firestorm FR-S
I think I've become addicted to buying parts that I don't plan to install for several more months. Perhaps I should start one of those build thread things....
"Shark_Bait88, the man who’s spent the most money modding his stock FR-S and it’s still stock." -@jdnguyen
11-18-2015, 09:19 PM | #1843 |
Drives: 2017 BRZ
The Following User Says Thank You to cjd For This Useful Post: | Shark_Bait88 (11-18-2015) |
11-18-2015, 10:43 PM | #1844 |
Drives: Ultramarine FR-S
Bought most of my STX setup last black friday, hurt to wait till around spring to get everything installed.
The Following User Says Thank You to 48Spoons For This Useful Post: | Shark_Bait88 (11-18-2015) |
11-18-2015, 11:45 PM | #1845 |
Yeah, the only other thing I plan to get before spring will be camber plates for the new coilovers. I'll figure out the sway bar setup after I see how the car feels with the new suspension at my first event next year.
11-19-2015, 01:25 PM | #1846 |
Drives: '14 BRZ
Fun. Our PAX jumps up by .005 to .836 next season. Thanks everyone.
http://solotime.info/pax/rtp2016.html |
The Following User Says Thank You to conedodging For This Useful Post: | justint5387 (11-19-2015) |
11-19-2015, 03:46 PM | #1847 | |
Drives: 2013 Red BRZ
But all street tire classes went up- the RE71 effect. |
The Following 3 Users Say Thank You to RedBRZ80 For This Useful Post: |
11-19-2015, 11:03 PM | #1848 |
btr.life
Drives: 2022 GR86
Yea, pretty much everything is up.
STX has gone up the last 2 years too, can't say I was surprised by another increase. I blame the twins coming onto the scene
Similar Threads | ||||
Thoughts on a "component" setup with a 3.5" dash and 6.5" door setup? | PatrickSAN | Electronics | Audio | NAV | Infotainment | 22 | 11-14-2012 02:12 PM |
SCCA sway bar rules | gmookher | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 0 | 09-01-2012 06:48 PM |
Suggestion for vendor rules... | Tainen | Site Announcements / Questions / Issues | 31 | 08-15-2012 01:53 PM |
Rules for posting in this section | Hachiroku | User/Vendor/Sponsor Reviews, Feedback, Comments | 0 | 06-25-2012 11:02 AM |
