09-16-2013, 11:23 AM | #1821 | |
Thupercharged
2013 FRS
Vortech V3 11psi Revworks UEL - PLM Overpipe - MOTIV catted frontpipe - Invidia Q300 2019 Series.Grey STI - Stage1+ SF |
09-16-2013, 11:27 AM | #1822 | |
The load created at 2000 rpm is 2 or 3 times what the stock NA car makes. This means the resolution of the load/timing/fuel table needs to be expanded. Toma couldn't believe the load generated. |
09-16-2013, 11:32 AM | #1823 |
Drives: 2013 FR-S Argento
For 'production ready' kits perhaps an RPM dependent switch should be part of the standard kit. When selling to the general public, I'm not sure you want to leave it up to them to be responsible for when they kick this in. I can picture a teenager damaging their motor with repeated low RPM WOT high boost peaks with this system, and then blaming the 'manufacturer' on these very forums. Just a suggestion.
The Following User Says Thank You to bfrank1972 For This Useful Post: | fenton (09-16-2013) |
09-16-2013, 11:34 AM | #1824 | ||
Drives: FR-S 10 #103 AT
“Sex is like Bridge. If you don't have a good partner, you'd better have a good hand.” - Mae West Papa said, "son there's a lot of evil temptations out there. Best to try 'em all so you know which ones to avoid." |
The Following User Says Thank You to mid_life_crisis For This Useful Post: | Calum (09-16-2013) |
09-16-2013, 11:39 AM | #1825 | |
If you purchase the system and run the stock tune you have to understand the risks and limitations of the system and Rob is going to make that very clear. The stock tune isnt made for boost, plain and simple, yes you can run it, yes it will work above a certain RPM but you really have to understand the limitations of doing so. The only reason they are working on the Vclamp for the MAP is because of people saying they didnt want to flash the ecu.... Rob wants to try and give those people a option if he can. |
The Following User Says Thank You to fenton For This Useful Post: | bfrank1972 (09-16-2013) |
09-16-2013, 12:04 PM | #1826 | |
That Guy
Drives: 2013 asphalt FRS MT
I agree completely. This much boost at a low RPM can do some real damage to connecting rods. @fenton, I agree that simple is good. But there comes a time when a system is too simple. I've said my piece before, wishing for even an optional smarter controller, but this one funtion seems like it should be mandatory for safety reasons. Just my .02, I'm not speaking for anyone else. |
The Following User Says Thank You to Calum For This Useful Post: | fenton (09-16-2013) |
09-16-2013, 12:44 PM | #1827 | |
If I have to limit the power gain slightly to keep my motor safe without a tune, then I'll do that knowing I won't be getting as much out of it as the guy who does get a tune. It'll still be a nice bang for the buck, just not as big a bang as the next guy.
09-16-2013, 01:22 PM | #1828 | |
09-16-2013, 01:29 PM | #1829 |
Exactly.
09-16-2013, 02:36 PM | #1830 |
Drives: MR Spyder/GT86
im a little confused.. so launching the car with this kit is unsafe? and you could break things?
I thought this kit dident make enough power and torque to start breaking things :/ |
09-16-2013, 03:03 PM | #1831 |
It's a bit different than other FI options out there since it's driven by an electric motor. I'm no engineer but here's my attempt (I *think* it works this way):
- When you go WOT, it closes a switch and the electric motor driving the ESC goes wide open. It's an all or nothing type deal, so in an open situation (not forcing air into a motor) it will deliver a fixed CFM. - The motor, on the other hand, has variable CFM requirement roughly proportional to RPM. In other words a motor may need twice the CFM at 4000 rpm than 2000 rpm (in real world this of course varies but to illustrate a point). -At high engine RPM, the ESC motor is able to flow a little bit more than the motor does at atmospheric, so you see maybe 1-2 PSI pressure above atmospheric at high revs. -At low engine RPM, the ESC motor is able to flow MUCH more than the motor at atmospheric, so it is capable of producing much higher PSI. In other words, the motor will *try* to stuff a fixed amount of air into the motor regardless of RPM. Since there is no 'wastegate' or other limiter, at very low rpm this thing could *potentially* boost to damaging levels. Other FI types don't really have this problem because they're limited by belt speed (RPM dependent) or wastegates (boost dependent). Experts please excuse if I'm over-simplifying things. |
09-16-2013, 03:27 PM | #1832 |
Drives: Raven FR-S
Did the AutoX event over the weekend. Unfortunately, I did not prepare the car correctly for the torrential down pour and finished in the bottom 1/3.
The one dry run I had with the ESC (if I did not miss the gate and DNF'ed) would have put me easily in the top 10. The autoX course was very small and max RPM in 2nd was 5-6,000, so use of the ESC ontight wet turns was limited at best. At the end of the day I was disappointed that we did not have dry weather this past Sunday in the NW. We have one (1) more event in October and hopefully we will have dry weather or I will be better prepared for rain. . . . More to come. |
09-16-2013, 03:29 PM | #1833 | |
Bogging the kit at 1000 rpm and going to 100% throttle will cause the car to not be happy in anything other than 1st gear. Launching is perfectly fine, rev up to 3000 or so and drop/feather the clutch and your fine. Anyone who thinks that they are going WOT at 1000 rpm I invite to go out to their cars right now and see how many times that happens. Even in stock NA form if you go WOT at 1000 rpm in 2, 3, 4th gear the engine sounds soooo bad(dont do it). The kit with a tune is okay to go WOT at 2000 or above.... although remember lugging the engine at 2000rpm in 6th gear is never going to be as good as just giving a quick downshift to 4th. I remember when i had my 11 STI and COBB said to never go WOT in higher gears below 2500 or so and that because the engine would load up so much would eventually start knocking. |
The Following User Says Thank You to fenton For This Useful Post: | GT86meMR2 (09-16-2013) |
09-16-2013, 03:35 PM | #1834 | |
Drives: Raven FR-S
Similar Threads | ||||
Circuit Motorsports - Vortech Supercharger FR-S Build + Full Perrin Exhaust & Extras | Circuit Motorsports | Member's Car Journals | 4 | 03-21-2013 04:45 PM |
Subaru BRZ : Full Throttle, powerslide, hard revving & ride | ESBjiujitsu | BRZ Photos, Videos, Wallpapers, Gallery Forum | 20 | 05-30-2012 06:43 PM |
86 Full Throttle Video + another. | Aus86 | FR-S & 86 Photos, Videos, Wallpapers, Gallery Forum | 2 | 04-02-2012 07:07 AM |
