03-19-2019, 11:29 AM | #169 |
Proud of Boxer
So I've spent the last week doing swap research only to be highly disappointed. After I pay $5k+ for Pure's Motec package how do I legally drive my car on the street?
So the real question still is when is someone going to figure out how to swap these cars and have them be actually inspect-able for all of us who live in states that have an OBD2 inspection, which is getting to be more and more states/counties, including the state Pure Auto is working in. Yes I'm aware that waivers are a thing, for now... |
03-19-2019, 11:32 AM | #170 | |
Drives: 2JZ FRS
03-19-2019, 11:47 AM | #171 | |
Drives: Q5 + BRZ + M796
03-19-2019, 11:47 AM | #172 | |
03-19-2019, 12:01 PM | #173 | |
03-19-2019, 12:10 PM | #174 | |
Obviously it's going to be at least some more work/aggravation getting the car approved. You could always just fly casual and don't tell the inspector that it's the wrong motor. Or buy a different car/mod the FA20. Obviously not ideal but if you don't think you can get it approved, don't start the project because you'll lose a fortune when you try to sell it |
03-19-2019, 12:10 PM | #175 |
03-19-2019, 12:37 PM | #176 | |||
Proud of Boxer
I'm fully aware of Cali law, which in many ways might be an advantage of sorts, you can take your functioning swap to a referee, prove it's as it should be and go on your way, no OBD2 nonsense required. Unless I misunderstand the process. (I'm not suggesting that's overtly easy, but it's doable and has been done). Quote:
My issue here is that the in MOST states that do inspect it's a simple OBD2 scan test on anything from 96 up. If you can get the the OBD2 to function properly you're in business, regardless of exact configuration (unlike cali). You pull in, plug in and go, if the VIN pull on the ECU matches and the monitors are good you're good. Is anyone working on getting the OBD2 "working" enough to pass that test? |
03-19-2019, 12:42 PM | #177 | |
I Love custom Turbo kits
Drives: Limited BRZ
Moving to a non testing county or state is your best bet
03-19-2019, 12:49 PM | #178 |
Identifying as a Member
Drives: 2013 FRS LS1
This swap has me droolin...
Are you guys going with a K20A or K20A2 head? |
03-19-2019, 01:02 PM | #179 |
So long as you aren't turning off codes you should be fine. I'm curious if a standard code reader will still operate with the standalone ECU though. I know the Nemesis at least works partially because you can take it to the dealer for problems with the ABS and SRS systems. Things that aren't controlled by the primary ecu
03-19-2019, 01:05 PM | #180 | |
Drives: Limited BRZ
With Motec ABS, SRS work off independently and can still be accessed through OBD2. No standalone provides obd2 monitors CEL or readings for the engine ecu.
The Following User Says Thank You to Sportsguy83 For This Useful Post: | Irace86.2.0 (03-19-2019) |
03-19-2019, 01:34 PM | #181 | ||
Proud of Boxer
I'm not trying to fool it, I'm trying to get it functional enough to work for the purpose of state mandated OBD2 testing on MY96+ vehicles. Your other statement doesn't even merit anything more than an acknowledgement that it was made and it was pointless. Quote:
Again, completely aware that a standalone won't work, which is why it's incredibly odd to me that it's being hailed as "The SOLUTION" to all our swap ills when it's very clearly not. It's just a really expensive motorsports solution that works well for motorsports. I don't want a track only car, I want a BRZ with a K24 that I can use just like I use my BRZ now. Has anyone done ANY swap that will pass an OBD2 inspection test? |
03-19-2019, 01:38 PM | #182 | |
@s0sl0w |
The Following User Says Thank You to Ashikabi For This Useful Post: | Four_wheel_drifts (11-07-2021) |
Similar Threads | ||||
Pure Auto's Swap Compilation Thread - 2JZ and LSX ! | Pure Automotive | Engine Swaps | 29 | 01-10-2018 01:20 AM |
SwapYour86.Com Pure Automotive 2JZGTE Billet Intake Manifold For 2JZ FT86 Swap | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:57 AM |
SwapYour86.Com Pure 2JZ MoTeC Plug & Play Wiring For FT86 !! | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:49 AM |
SwapYour86.Com Pure LSX MoTeC Plug & Play Wiring For FT86 !! | Pure Automotive | Engine Swap | 0 | 12-01-2017 11:23 AM |
Pure Auto's 2JZ Swap Thread - The DRAGFRS | Pure Automotive | Engine Swaps | 153 | 06-20-2016 06:33 PM |
