05-12-2020, 08:06 AM | #169 | |
Here is a good example where I would use 3rd gear. Even though I short shifted the speed mid/end of slalom is significantly better than holding it in 2nd
Kyle H. - #89 STX
The Following User Says Thank You to M0nk3y For This Useful Post: | strat61caster (05-12-2020) |
05-12-2020, 03:46 PM | #170 |
Drives: STX FRS
Jumping in this thread as I just bought what seems to be a slutty FRS that's been with a few STX autocrossers
Its on Ohlin single adjustable with 400lb springs all around and typical boltons, 17X9 RPF1s with 245 Rivals. Edit, question since the last RWD Autocross car I've had is a NB Miata. Why is it that we don't want the rear brakes doing much on the FRS/BRZ? From previous owners, it has AP Racing BBK in front with good Ferodo pads but only the Hawk HPS mickey mouse pads in rear. On a NA/NB Miata we purposely put more aggressive pads in rear. It has HP+ rear and Stop tech sport front on sport package brakes. Last edited by Spade; 05-12-2020 at 04:40 PM. |
05-12-2020, 04:40 PM | #171 | |
Drives: 2013 FRS
Sorry couldn't help it. Congrats. I'm sure you'll have a blast. What's it got for sway bars and brakes? Sent from my SM-G960U using Tapatalk
WIFE: "How can there be anything left to buy?"
05-12-2020, 04:51 PM | #172 | |
Drives: STX FRS
I have another bigger sway bar in box. What's the going ideal set up? Brakes are AP Racing BBK front with good Ferodo pads. Hawk HPS (shoe leather) rear. I was told the rear shouldn't be doing much in this car which conflicts with my usual knowledge |
05-12-2020, 04:55 PM | #173 |
The Miata rear brake thing is to try to mitigate front lock up when driving a non-ABS car aggressively.
Brake kit for just the front and rear sway bar disconnected sounds a little, uh, atypical for an STX setup. |
05-12-2020, 06:49 PM | #174 | |
Staggered pads is unusual though, the factory brake system likes to add rear brake pressure to reduce rotation under braking, I could see that being an issue in Street class that a prior owner liked the staggered pads instead of the pedal dance and just didn't revisit after building STX. I've found when the suspension is happy I get all the rotation I need under braking with same pad compound front and rear and that seems to be the common consensus. https://www.ft86club.com/forums/showthread.php?t=25494 Unhooked rear bar isn't super common, but it's pretty weaksauce to begin with. I'd like to try disconnecting it as a rain setup and softening the front. The car likes a stiffer than factory front bar, I've heard 20mm to 25mm, 22mm solid adjustable seems most common. The car is sensitive to alignment, some choices with toe and camber can drive the owner to compensate in other areas such as spring rates, damping, and sway bars, it might have been a factor in the brake choice too. |
The Following User Says Thank You to strat61caster For This Useful Post: | Racecomp Engineering (05-13-2020) |
05-13-2020, 08:40 AM | #175 |
I'm looking at rear lower control arms and wanted to make sure I understood the rule correctly - as long as I have a solid non-metallic bushing (that is, not a spherical of any kind) all the various aftermarket arms are legal, yes?
If that's true, then setting aside cost what's your preferred choice? I'd like something that's light and easy to adjust.
-- Bryan Blackwell --
2020 Hakone 86 -- KW V2 6k&9k/Karcepts Sway Bars/SPC&Diftech RCLA/SuperPro bshngs/17x9 RPF1/255-40-17 RT660/Hawk5.0 Pads/RacerX MC Brace |
05-13-2020, 09:41 AM | #176 | ||
Perhaps PO's thinking on the rear pads were trying to prevent the rear brakes from screwing around with the LSD, as they do clamp in some instances during yaw even with stability control completely off. Honestly, don't overthink it just match the rear pads and drive the car. I've run AP Racing BBK with 2500s all around for the past 2 years. It works. The rear pads are so small to begin with the last thing I'd want to do is shift bias more up front with an HPS pad. Quote:
Kyle H. - #89 STX
05-13-2020, 09:42 AM | #177 | |
Drives: 2016 Toyota 86
05-13-2020, 10:20 AM | #178 |
I guess what I was thinking was to get a set of used arms with a rod end and then swap the rod end for something like this:
https://www.summitracing.com/parts/cee-6152 So long as I do that, I think the arms themselves are legal. Am I missing anything?
05-13-2020, 01:31 PM | #179 | |
Drives: FR-S - STX
Sent from my Pixel 2 using Tapatalk |
05-13-2020, 03:55 PM | #180 | |
When I went to 350# rear I was still on 22mm soft, Mann Bar. Now I changed a bunch of things and went with a Karcepts bar and that gets changed around about every event
Kyle H. - #89 STX
05-13-2020, 04:09 PM | #181 |
Drives: Miata
The Following User Says Thank You to racingfool For This Useful Post: | strat61caster (05-13-2020) |
05-13-2020, 04:13 PM | #182 | |
I like the threaded adjustment too, but even buying used parts I think it'll be hard to beat the value of the Whiteline/SPC LCA with a legal bushing pressed into it. Once you figure out what toe/camber you like back there for stability and tire wear odds are you won't want to touch it. https://www.ft86speedfactory.com/whi...E#.XrxUc2hKhPY Be aware on the arms that provide multiple adjustment holes or static lowering, not ST* legal, but I think they have OE positions so as long as you bolt the damper/swaybar into the right hole it should be fine. |
Similar Threads | ||||
SSC setup thread | conehead | Tracking / Autocross / HPDE / Drifting | 26 | 06-06-2023 02:21 PM |
Vortech Owner Thread & Setup Questions | reyruiz191 | Forced Induction | 340 | 05-17-2022 12:44 PM |
STX setup sharing thread (2019) | CoolHandMoss | Tracking / Autocross / HPDE / Drifting | 110 | 02-17-2020 11:27 AM |
STX Set-Up Sharing & Results Thread | race2win | Tracking / Autocross / HPDE / Drifting | 76 | 02-16-2017 11:30 AM |
Official Roll Cage/Bar Thread **Show off your setup!** | slava | Suspension | Chassis | Brakes -- Sponsored by 949 Racing | 4 | 01-02-2015 10:05 PM |
