12-16-2015, 02:35 AM | #155 | |
Drives: 2013 Asphalt FRS
Nitrous is the F/I during the molecular level its at when it enters the cylinder in a stable form. When it vaporizes, nitrous oxide provides a significant cooling effect on the intake air. When you reduce the intake air temperature, you increase the air's density, and this provides even more oxygen inside the cylinder. creating a F/I condition. Chemical F/I
Instagram FT86PROJECT9S
Facebook FT86PROJECT9S 710whp |
12-16-2015, 02:36 AM | #156 | |
Drives: 2006 Pontiac GP (SOLD), 2014 FR-S
"Project cars are like New Years Eve. Endless preparation, hype, a sleepless night of fun, followed promptly by massive headaches and regret." - Anonymous
12-16-2015, 02:38 AM | #157 | |
12-16-2015, 02:43 AM | #158 |
Drives: 2013 Black FR-S
It's the tune.
12-16-2015, 02:45 AM | #159 | |
Edit: What are you looking to get hp wise
12-16-2015, 02:51 AM | #160 |
Nice! I want to find some one to custom make me a Vband twin scroll manifold. Who did your motor, also sleeve & Oring? Which rods? I was initially going to go even crazier and go 13:1 and keep it an alcohol only motor, but a few people who's opinion I trust a lot strongly advised against it!
The Following User Says Thank You to #maverick# For This Useful Post: | CSG Mike (12-16-2015) |
12-16-2015, 02:55 AM | #161 | |
The Following User Says Thank You to FRS Justin For This Useful Post: | #maverick# (12-16-2015) |
12-16-2015, 03:17 AM | #162 | |
I see your pissed and that's ok I will gladly come to cali this summer and we can go to the track and compare notes. I will gladly drive 1300 miles for you to school me on this
12-16-2015, 03:31 AM | #163 |
I smell a good old fashioned grudge race brewing!!
12-16-2015, 03:38 AM | #164 |
It wont be much of a race....
12-16-2015, 04:15 AM | #165 | |
But, that's not how a nitrous system works. Atmospheric air has about a 21% oxygen concentration. Nitrous Oxide, on the other hand, breaks down into 33% oxygen concentration. Furthermore, when Nitrous Oxide decomposes, the reaction is exothermic. In other words, when (2)N2O decomposes into 2N2 + O2, it ADDS heat to the intake charge (technically already under compression in the cylinder, and igniting). You confuse spraying liquid N2O into the intake tract, which cools the intake charge from evaporation, the same way fuel injection does. The reason N2O adds power, is because it displaces atmospheric air with a molecule of higher oxygen content, which can be readily broken down to O2, and then combusted with fuel. |
12-16-2015, 04:19 AM | #166 |
Wait, is this going to a drag strip or a track? Because if it's going to a track, I'm in too
12-16-2015, 04:25 AM | #167 |
Definitely drag brother I have no business on a circle track.
12-16-2015, 04:45 AM | #168 | |
Like a firecracker if you unwrap a firecracker it just fizzles if you compress the powder it will explode. The increased amount of oxygen & fuel in the combustion chamber results in the assorted molecules being more tightly packed than normal. Does this help I don't know how else to explain that a more dense charge will (lack of a better word) weigh more than a less dense charge in the same volume. [ame="https://www.youtube.com/watch?v=r6wzTRLPDOc"]nitrous express at pri - YouTube[/ame] its not just getting sucked in there its F/I Either way you still have a chemical process that happens that Atmospheric air has about a 21% oxygen concentration. Nitrous Oxide, on the other hand, breaks down into 33% oxygen concentration. Putting 33% of oxygen in the same volume as 21%( N/A) takes some type of F/I whether its chemical(NOS) or Mechanical(turbo-S/C) its F/I that creates a tremendous force on the rods. I know you've seen nos cars blow the intake right off from a back fire in a video or somewhere that's not because of a standard 21% o2 cylinder charge. know what I mean, Your getting there but your just not all the way there yet
Facebook FT86PROJECT9S 710whp Last edited by FRS Justin; 12-16-2015 at 06:44 AM. |
Tags |
kill brain cells, not facts |
Similar Threads | ||||
FlexFuel and Facts | Shiv@Openflash | Software Tuning | 69 | 10-16-2019 01:08 PM |
Anyone Else? Hearters Blowing when off. | Kiske | Issues | Warranty | Recalls / TSB | 7 | 04-09-2014 05:22 PM |
How cold is your a/c blowing? | jermyzy | Issues | Warranty | Recalls / TSB | 68 | 08-18-2013 03:29 PM |
Supra Blowing Up | radroach | Off-Topic Lounge [WARNING: NO POLITICS] | 2 | 07-21-2013 09:14 PM |
Facts you may or may not know about your GT86/BRZ/FR-s | FiRStsc10n | Scion FR-S / Toyota 86 GT86 General Forum | 41 | 07-09-2013 03:05 PM |
