02-06-2017, 10:12 PM | #155 |
Drives: 2015 Raven FRS
Just an up date. After installing my supercharger I had so much stacked up in front of the radiator I moved my engine and transmission coolers outward behind the now removed fog lights.
02-12-2018, 02:41 PM | #156 | |
BRZ Wannabee
Drives: 2013 Limited BRZ
Has anybody explored the addition of airflow like a fan on the stock AT cooler? Would that get you anywhere? |
The Following User Says Thank You to majixmatrix For This Useful Post: | Tristor (04-30-2018) |
03-17-2018, 02:28 PM | #157 |
Drives: Yellow FR-S Rs 1.0
Hey guys,
Was wondering what is the fluid direction of the lines from the transmission/auxiliary cooler? I had my trans cooler installed and looks like I am getting some abnormal noises from the lines. Just want to make sure it is routed correctly. |
05-26-2018, 08:47 AM | #158 |
Drives: 2013 Raven
Quick question: Is the hose from the auxiliary oil cooler and from the transmission the same sized 3/8" ID?
05-26-2018, 01:23 PM | #159 |
Drives: 2013 FRS
Trans fluid lines are 3/8...
Enkei TS9 18 X 8, Michelin Sport 4S 225 40 18, Flex Fuel, Edelbrock Supercharger, P & L header, Nameless front pipe, V1 cat back, Aluminum Driveshaft, pvc delete, med duck bill, KW V3, Whiteline 20 and 18 mm bars, Buddy Club and SPL control arms, Toe Arms, motor and trans mounts, Whiteline bushings, SHR stage II tune.
05-26-2018, 02:37 PM | #160 |
I'm sure the stock AT cooler is just a heat exchanger based off the engine coolant
The Following User Says Thank You to FRSBRZGT86FAN For This Useful Post: | KDad2 (05-26-2018) |
05-26-2018, 03:39 PM | #161 | |
Drives: 2013 FRS
I disconnect the "coolant lines" and just run the cooler. Seams ok for street use non boosted so far. Stock it would get hot after a few hard launches. I also flushed and went full synthetic redline mix of dextron IV "D6" and Dextron III "D4", the stock fluid heats up really quick the redline holds up much better and shifts harder. For track days I will need a to add a cooler...
The Following User Says Thank You to shr133 For This Useful Post: | KDad2 (05-26-2018) |
05-26-2018, 05:33 PM | #162 |
Drives: 2013 Raven
07-09-2018, 09:11 AM | #163 |
Drives: 13' FRS
So I'm thinking of adding a cooler to my dd/couple times a year track day car. I plan on running some open track days mostly and need a cooler that will be up to task. I saw the stark performance setup and I'm wondering if a bigger cooler wouldn't be better? Say a 6 25 row setup. I'm guessing that it won't fit behind the fog lamps/right side of bumper? I won't be running FI so I do have space in center bumper. What do you guys think? Anyone running a bigger cooler?
Thanks |
07-05-2019, 10:16 PM | #164 |
Drives: 13' FRS
Guys,
Does anyone have the manual for stark performance cooler, the installation guide? Thanks
'13 FRS ultramarina 6AT fully stock
- mods in progress |
07-06-2019, 08:03 PM | #165 | |
Drives: Moped
https://www.facebook.com/StarkPerformanceParts/ |
07-07-2019, 04:02 PM | #166 |
Drives: 2017 Subaru BRZ Limited
He's been active on the Forums and assisted me. You can also see my installation in my build thread, I also wrote a thorough DIY guide on the fluid exchange protocol.
The Following User Says Thank You to Tristor For This Useful Post: | Lonewolf (07-10-2019) |
07-10-2019, 03:24 PM | #167 |
Drives: Moped
07-10-2019, 08:19 PM | #168 | |
Looks like you found one of the threads already. The other was more of a question thread I linked from my build thread that discusses mounting the inline thermostat. Personally, given the fact I'm located in South Texas, I regret using the thermostat because it's one additional item to think about which is not really necessary in my climate. In your climate though it might be essential. http://www.ft86club.com/forums/showthread.php?t=129845
You can use my DIY thread which was spawned out of the above as well to get details on how to do the fluid changeover. I recommend Redline D6 ATF. Despite being a bit of an AMSOil fanboy, I found that the Redline D6 ATF worked the best under track use. Similarly I found that the Motul Gear 300 worked best in the diff over the AMSOil under track use. I believe AMSOil is more formulated for the types of high loads on diffs/ATs that occur from towing vs racetrack usage. Redline/Motul seem more oriented towards track usage and my butt dyno/datalogs seem to evidence that. I still run AMSOil for my engine oil. Also in another old ATF thread there's a quick n dirty guide on how to "flush" your AT. Never ever hook an AT up to a pressurized flush machine, these things are bad news. Instead you can "flush" it using the lines you have to pull from the factory AT heat exchanger to install your Stark Performance ATF cooler anyway. I didn't do this since my car was so new, but if you want to, I'd recommend doing a full fluid flush, then finishing the ATF cooler install, and then adding additional fluid for another PRNDM cycle before doing the leveling procedure to ensure you can fill the cooler (if you use the thermostat you'll need to get the AT up to temp to open the thermostat and then let the car cool before leveling). Quote:
Similar Threads | ||||
Automatic Transmission Fluid Change | jmaryt | Mechanical Maintenance (Oil, Fluids, Break-In, Servicing) | 169 | 08-26-2018 07:55 PM |
Automatic Transmission Cooler | RYU | Engine, Exhaust, Transmission | 9 | 11-14-2013 02:15 PM |
Automatic Transmission Cooler | KGFRS86 | Engine, Exhaust, Transmission | 14 | 08-26-2013 08:55 PM |
Automatic Transmission Cooler, necessary for autoX and Track? | BRZPDX | Engine, Exhaust, Transmission | 4 | 07-11-2013 07:13 PM |
topspeed difference between manual transmission and automatic transmission | torquemada | BRZ First-Gen (2012+) -- General Topics | 51 | 05-04-2012 07:54 PM |
