03-05-2018, 12:23 AM | #16605 |
Drives: '13 FR-S
03-05-2018, 12:31 AM | #16606 |
Drives: Celica, Frs
They’re close to stock comfort but definitely a little stiffer.
Instagram @machine_type
03-05-2018, 11:49 AM | #16607 |
Drives: 2013 WRB BRZ Limited
Finally got the chance to install the Always-On Module for Subaru BRZ (USDM) Diode Dynamics. I'm liking it so far. I'm thinking about getting the led from Diode Dynamics for the fog light to match the headlights.
03-05-2018, 12:06 PM | #16608 | |
Just the tip
Drives: 2017 DGM BRZ
I also got a shift knob from him that fit just as poorly and stacked a bunch of leather pieces inside until it was oriented correctly at full tightness. Pretty disappointing to have to do this after 5 months of waiting for the damn thing. Turns out I hate the feel of a heavy shift knob so I'm back to stock anyways. |
The Following User Says Thank You to wolffbite For This Useful Post: | Tonezorz (03-05-2018) |
03-05-2018, 06:47 PM | #16609 |
Drives: 2018 WRX STI
I threw on Pilot Sport A/S 3+'s. And by "I" I mean "somebody else"
(I also gave away the stockies for the promise of beer) |
The Following User Says Thank You to OfficeWorker For This Useful Post: | Is Always Angry (03-16-2018) |
03-05-2018, 06:53 PM | #16610 |
helmholtz resonator
Drives: '15 ultramarine
The Following User Says Thank You to Sapphireho For This Useful Post: | Tonezorz (03-05-2018) |
03-05-2018, 06:57 PM | #16611 |
Drives: 2017 BRZ
Sounds like a good price on the stockies, I may have to find somewhere around here that will give me that for them when I swap mine out. Planning on having it done sometime in the next couple months.
03-05-2018, 07:10 PM | #16612 | |
But I can't complain...I really disliked the stock rubber and I am glad they are gone. |
The Following User Says Thank You to OfficeWorker For This Useful Post: | Brink (03-05-2018) |
03-05-2018, 08:09 PM | #16613 |
Drives: '14 981CS, '99 NB1
The Following 3 Users Say Thank You to johan For This Useful Post: |
03-05-2018, 11:03 PM | #16614 |
Drives: 14' E85 BRZ
UEL headers, dual resonated front pipe, nvidia n1 exhaust, new tune. Cold start is loud af I need to turn it down a bit but honestly couldn't be happier. Loud when you want it and quite when you need it and doesn't sound ricey at all.
03-06-2018, 12:39 PM | #16615 |
Drives: 2019 WRX
03-06-2018, 02:54 PM | #16616 |
Drives: 2015 Subaru BRZ Series.Blue CWP
Bought and installed a new battery after mine died last night.
03-06-2018, 06:38 PM | #16617 |
Drives: 13 BRZ, 18 STI
Today I replaced my oem battery with a Braille B2015 AGM battery, and a Ptuining battery mount kit. Saved me somewhere in the neighborhood of 15lbs.
Install wasn’t as straightforward as I would have liked though. Only because the radium catch can is a little too close to the battery to connect the negative terminal the normal way. Ended up having to mount the negative terminal sideways to clear it. Unfortunately that created another issue. The grounding wire that comes off the negative wire, which normally attaches close to the strut tower, would no longer reach the standard mounting point. I ended up sandwiching the grounding wire between the two plates of the battery mount.
Racecar spelled backwards is racecaR, because RacecaR
03-06-2018, 08:03 PM | #16618 |
Drives: 2017 860
added a sho-n-go removable plate frame holder and rear louvers. here is the video of the plate mount
The Following User Says Thank You to ctmandu For This Useful Post: | e30kawi (03-06-2018) |
Similar Threads | ||||
Saw My First FR-S Today | Marrk | Scion FR-S / Toyota 86 GT86 General Forum | 26 | 05-15-2013 12:40 PM |
Got my new FR-S today. | Boosted2.0 | Scion FR-S / Toyota 86 GT86 General Forum | 51 | 06-03-2012 10:35 PM |
Sat in a FRS today!! | Ladnerd | Scion FR-S / Toyota 86 GT86 General Forum | 12 | 04-30-2012 01:48 PM |
Got my VIN today... | Enemies | BRZ First-Gen (2012+) -- General Topics | 63 | 04-12-2012 10:19 PM |
sat in a BRZ today | NESW20 | BRZ First-Gen (2012+) -- General Topics | 8 | 03-31-2012 08:53 AM |
